    Results 61 to 71 of 71
    1. #61
      Aug 2014
      I assume the 3d printed adapters are "proof of concept," and you'll make them out of something else later, right?
      The more I see, the more I want a 3d Printer. lol
      What did you print them out of?
      Jay
    2. #62
      Aug 2014
      Jay
      Correct.
      It was printed out of ABS. Will go to 6061 when the time comes. I used the printer at work to print it, and it took 22 hours... Sheesh!
      Ryan
    3. #63
      Aug 2014
      A little update.
      Twin turbo headers by Armageddon for the 2014+ Mustang fit perfect on a coyote swapped VIC frame.
      Twin Precision 6266 Ball bearing turbos ready to go. Dual V-Band inlet/outlet .82A/R
      Started working on the motor mounts as well.
      And I put some 295 wide M/T SS Drag Radials on the Charger... first gear is usable in the car now! Woo!
    4. #64
      Aug 2014
      Quote Originally Posted by redmist View Post
      Master of the Xacto knife. lol
      Jay
    5. #65
      Aug 2014
      Milled down the stock frame tie ins for the Crown Vic. I was going to fabricate some sheet metal ones, but decided to put the "Little Big Mill" to use.
      Had to make a clearance pocket on the one side.
      Ended up working great! Looks cool as well.
    6. #66
      Feb 2011
      Indpls, IN
      Awesome!
    7. #67
      Aug 2014
      Turbos getting mounted this weekend.
      Passenger side set in place.
    8. #68
      Aug 2014
      A little more on the hotside.
      Also mounted my PS reservoir right on the bracket for the front runner kit! Worked perfect.
    9. #69
      Aug 2014
      Update.
      Cab is in place, looks like I can move the engine back a couple more inches.
    10. #70
      Jan 2017
      Looks like you are going to run into the problem I'm at right now, can you turn those big tires in the front? What's your plan to make it work?
    11. #71
      May 2010
      Phoenix AZ
      Cool Build! I have 6 1966 Trucks in various stages. Would love to have a new 10 spd behind a Coyote in one of them.
