Results 1 to 20 of 39
Thread: 1965 Mustang Coupe Ecoboost 3.5L
10-01-2016 #1Registered User
- Oct 2016
- 19
I'm restoring my 1965 Mustang coupe. This was my first car restored in the 1990s by my dad and me. Some of the panels we should have replaced finished rusting out and so I had to restore the car again. I've posted it on another forum and I have a blog, but looking for some suggestions on making this motor fit.
This restoration is already in progress and I'll update as I can with some throwback posts to other work I've done.
I have rebuilt the front end including new frame rails and inner fenders. I also added a new firewall. I haven't attached the firewall to the car yet so I separated it from the car to test fit the engine.
I'd like to use a 3.5L Ford Ecoboost engine in this build. They're pretty light 350-375lbs and compact. In stock form, they hit early and hard with torque and max out at 420lb/ft. Torque is what makes cars fun, so it's a logical choice.
I'm having some trouble making it fit and looking for input and suggestions.
The oil cooler is the first thing to go. It's in the way of the tower on the rack. I was then able to lower the engine in place in the compartment. I would really like to tuck it tight and low in the engine compartment so I'm looking for opinions.
When it's tucked where I want it, the master cylinder and steering linkages will be tight but I think they'll work. I may have to do some work to the firewall though to gain clearance for the bellhousing.
When I pull it up higher and forward, it will make exhaust and transmission clearance easy, but the crank pulley wants to sit where the rack has to.
Anyway, here are pics.
First pics show the Ford Ecoboost 3.5L weight. The first motor is mostly complete with the missing parts laid on the intake. The second motor is cleaner and has wiring and engine mounts on it.
374lbs for a complete engine with turbos is pretty light. fordperformance lists it as 417lbs. I'm not sure where their extra weight comes from.
10-01-2016 #2Registered User- Join Date
- Oct 2016
- 19
Here's a shot of the engine dropping into place. The oil cooler was the first thing to go.
10-01-2016 #3Registered User- Join Date
- Oct 2016
- 19
Here's a few more shots of the engine bay with the motor sitting low and as far back as I can get it. There's a coolant tube that touches the firewall. Realistically, I will probably have to smooth the firewall and open the tunnel a little bit to accommodate the engine and transmission so far back.
10-01-2016 #4Registered User- Join Date
- Oct 2016
- 19
The EB engine should hopefully give me enough room to route the steering and a brake booster. I may mount it slightly biased to the right side of the car to give just enough space for a hydroboost and the steering linkages. If I don't, I will have to use aftermarket manifolds and relocate the turbos.
10-01-2016 #5Registered User- Join Date
- Oct 2016
- 19
I centered the engine over the front crossmember. It will contact the rack and pinion and need to be raised slightly to accommodate it. But with it this far forward, I have a lot of space at the rear to route exhaust and for the transmission to sit.
10-01-2016 #6
