    Page 5 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
    Results 81 to 100 of 179
    1. #81
      Jul 2015
      Winfield MO
      Finally got the fittings to finish the SS HP line from the pump to the rack, Finished installing the rear brake ines, and mounted the rotors and calipers to measure flex lines to front brakes
    2. #82
      Jul 2015
      Winfield MO
Size:  97.8 KBName:  IMG_0868.JPG
Size:  96.1 KBName:  IMG_0865.JPG
Size:  93.3 KBName:  IMG_0874.JPG
Size:  113.1 KBName:  IMG_0876.JPG
Size:  98.3 KB Installed emergency brakes on rear, Installed MC reservoirs and run brake lines
    3. #83
      Jul 2015
      Winfield MO
Size:  82.0 KBName:  IMG_0884.JPG
Size:  90.6 KB Finished fitting interior sheetmetal
    4. #84
      Jul 2015
      Winfield MO
      Mounting Dry Sump tank and welded up condenser linesName:  IMG_0899.JPG
Size:  83.5 KBName:  IMG_0902.JPG
Size:  86.5 KBName:  IMG_0901.JPG
Size:  100.4 KBName:  IMG_0900.JPG
    5. #85
      Jul 2015
      Winfield MO
      Mounted dry sump and welded in condenser lines
    6. #86
      Feb 2017
      South West of France
      Country Flag: France
      Dang! You work nice & clean... I just re-read the whole build, just for the hell of it, it just makes me smile.
    7. #87
      Jul 2015
      Winfield MO
      installed 3rd member, fire suppression system, and routing oil lines
    8. #88
      Jul 2015
      Winfield MO
      Working on body, Installing trunk panels Installed sway bar
    9. #89
      Jun 2015
      Country Flag: New Zealand
      very cool build,cant wait to see it finished ,regards
    10. #90
      Jul 2015
      Winfield MO
      Mounted fuel pumps and run fuel lines Install rear deck lid and made mounts for gas cylinders . Couldn't find a clamp for the dry sump lines that gave me the backside clearance I wanted so I made my own. little cleanup, little polishing and they will good to go to the anodizer
      (Once I get my hoses routed correctly.)
    11. #91
      Jul 2015
      Winfield MO
Size:  181.2 KBName:  IMG_0973.jpg
Size:  194.1 KBName:  IMG_0972.jpg
Size:  173.5 KBName:  IMG_0971.jpg
Size:  192.1 KBName:  IMG_0970.jpg
    12. #92
      Jul 2015
      Winfield MO
      Installed the C02 bottle and meth pump. Working on building the meth tank. Installed the oil cooler and mocked up oil lines on the right side of the motor. Waiting on the filter mount to finish the oil lines on the left side of the motor. Installed the AC unit starting to mock up lines
    13. #93
      Jul 2015
      Winfield MO
      Finally l got my fuel tank and started mounting it but of course fittings were install improperly. so it has to go back. Installed the hidden wipers and then installed the fire nozzles in the engine bayName:  IMG-0947.jpg
Size:  181.8 KBName:  IMG-0944.jpg
    14. #94
      Phoenix, AZ
      This has been quite impressive to watch the progression. Nicely done.
    15. #95
      Jul 2015
      Winfield MO
      Mocked up the meth tank and intake pop offs.
    16. #96
      TEXAS
      Very Nice Work
      How do you find time to do all the work on the car and still have a job? Nice work indeed, love the direction you are taking the car.
      Quote Originally Posted by UDOIT View Post
      Burn em’ while we have em’. Fossil fuels and rubber tires till the end!
    17. #97
      Jul 2015
      Winfield MO
      Finally received the new block. Working on fitting the remote oil filter
    18. #98
      Metamora, Illinois
      Just amazing craftsmanship!
    19. #99
      Beautiful work!
    20. #100
      Jul 2015
      Winfield MO
Size:  158.8 KBName:  IMG-1045.jpg
Size:  165.8 KBName:  IMG-1047.jpg
Size:  152.3 KBName:  IMG-1049.jpg
Size:  170.5 KBName:  IMG-1050.jpg
      Finished up the meth tank and plumbing to the pump. Fit the doors and started working on correcting gaps. Installed wheel tubes and will start finishing the rest of the trunk kit. Will put the rear end back in next weekend. Thanks for all the nice comments. Having a real job 4 days a week out of town and working at the shop most all the weekend. Helps the have a understanding wife also. About a month ago I lost my fabricator which will slow the process down quite a bit unless or until I find someone else. If anyone is interested or knows someone looking contact me
