Thread: T56 not shifting to 4th
08-12-2016 #1Registered User
- Sep 2004
- Near Dayton, OH
- 547
Quick question. What is causing my T56 to not want to into 4th gear at wot and high rpm?
I've had my car on the road for a few weeks now and it's a blast to drive but I've noticed that if I try shifting at anything north of 5500rpm the trans wants to grind tering to go into 4th and ultimately I have to coast for a bit before I can get it into gear.
I've read it could be the stock master cylinder and a lot of guys do the "drill mod" which fixes it.
I'm using a stock LS1 style master cylinder however I have an aftermarket braided line that I thought got away with the need to do the drill mod.
Setup below:
Stock T56 from '96 SS Camaro
Weir Hot Rod Products hydraulic throwout bearing
GM LS1 master cylinder
Centerforce DFX clutch
Would an aftermarket master cylinder like the Tick Performance unit solve this issue or is more internal to the trans?
Thanks,Andrew
1987 Olds Cutlass Supreme FE3X Clone
EFI455/T56/9" w/ 4.30 gears
__________________________________________________ __
08-15-2016 #2
