      Carson City Mi.
      Gen 5 seats in first Gen Camaro (how to mount)
      I just purchased some Gen 5 seats and console would like to install these in my 67 Camaro,need ideas on how to mount seats. Do I cut off factory brackets or do I try to utilize them. I see people using these seats but cant find any info on how they are mounting them. Any help would be appreciated it would be nice to be able to get these mounted so I can actually seat in my car and pretend I'm driving it. Thanks
      Aug 2015
      charlotte
      It can certainly be done, many people have done it, many people have also tried and given up. it takes a little bit of work as they are quite wide and also quite tall, so they need to be mounted as low as possible to the floor, I don't believe the 5th gen components can be used for this reason. I'll be doing it but haven't started that fab yet.
      Carson City Mi.
      Thanks for reply if I get it figured out I will post some pics so maybe it will help you out.
      Jan 2011
      Pennsylvania
      I have the same question but for a 1970 GM A body. What is necessary to install 5th gen seats in one or does someone have an example? Thanks
      Jonesboro, Arkansas
      I put seats out of a 2014 Mustang GT in my '68, I just cut off the original mounting brackets and set the seats in the car and decided what I was going to do to make them work. They really turned out really well, and all the electrics work as well.
      Carl Wilson
      Oct 2015
      EDMONTON ALBERTA CANADA
      6th gen seats and console
Size:  116.9 KBName:  IMG_20151010_103208.jpg
      Jan 2015
      How did you guys mount the center console? Picking one up tomorrow. Idk how or what to do in install it
      Aug 2015
      charlotte
      I've gone ahead and installed the entire trans tunnel, this will allow it to fit easy and also the handbrake.
      Others have managed to get just the required brackets removed from a wreck, or you can make your own mounts entirely.
