      Apr 2007
      Odenton MD
      which one is better for small boost
      Well I have a iron 6.0 and a aluminum 6.2 that been bored 005 over with forged pistons and mild head work (basically three angle valve job and milled)...
      6.0 cam is a gt2-3 cam and the 6.2 is ls9 cam
      For boost I have a p1sc 8 rib running about 8 - 10lbs boost...
      Exhaust is 1 7/8 kooks mid length....
      Going into a third gen Camaro (6.0 is in there now)
      Intake is stock ls1 6.0 or stock ls3 6.2 with 80lbs injectors
      Transmission is tick built t56
      Any input will help.... Is it worth the work to swap to the 6.2 or is the 6.0 stonger will take more beating ect.... I personally don't mind doing the work and like the idea of having the 6.2 in the iroc....
      Southern Indiana
      Alum block is lighter, sounds like fresher, built engine. And no replacement for displacement. Just $02 worth of advise in time when its not worth much.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Apr 2012
      Woodstock, IL
      The iron is stronger than aluminum of course. But with only 10lb boost you won't have problems with the 6.2L aluminum. I'd go with the 6.2 if it was me!
      -Dale
      SchwartzPerformance
      Jan 2013
      Cypress, California
      I agree. At that boost level it makes no difference. Go with the 6.2L block.
      Lowell, MI
      6.2 for sure. Iron is for boat anchors.
      Turbo Charged LS1/T56
