      Jun 2011
      69 Camaro LS1/T56 Magnuson TVS2300
      Wondering what your thoughts are on this set up?
      LS1 stock bottom end- ARP rod bolts
      317 Heads by Advanced Induction, ~71cc chamber
      Brute speed Blower cam stg 2
      Cam specs are:
      Dur @ .050 232 int 240 exh
      Lift .595 int .608 exh
      Lobe Sep 115.0
      Magnuson TVS2300 set up for 9-10lbs (will the TVS2300 fit under stock cowl hood?)
      Ford 9" rear end with 3.89 gears
      Just trying to get some information together and input on this set up as this is planned to go on the car starting this fall.
      Thanks in advance.
      -Sid
      It sounds like a hell of a fun ride to me!
      Aug 2013
      Id suggest a lower gear..I had a 3.27, fbody transmission in a car with a procharger and it would light the tires up pretty easily
      May 2013
      Quote Originally Posted by Tictakman View Post
      Agreed on the lower gear. With the roots blower you are going to have instant torque. I think you'd have traction issues at low speeds with that gear.
      I'm sure you'll have fun whatever you decide though.
      Jun 2011
      Quote Originally Posted by blu72nova View Post
      Ok guys I will definitely keep that in mind.
      On a side note: I just picked up HPTuners for this thing....gonna try tuning it up myself. Bring on the hours of thread reading!
