    Results 1 to 13 of 13
      marina ca
      78 trans am hi flow cats,cutouts, x pipe, hemi super turbos under axle
      Here is the first exhaust I've built. 2.5 inch mandrel bent with electric cutouts, x pipe, 20 inch case hemi super turbos.
      i wen under axle because of the 20 inch case wouldn't fit with out cutting he passenger floorboard. I Also have air suspension fully extended should have almost 6 inches of clearance and fully compressed 1.75 inches of clearance
      Feb 2007
      Tinley Park, IL
      Is this at ride height, or fully extended?
      Attachment 110609
      Nick ~
      1969 Cutlass
      Apr 2012
      Woodstock, IL
      Quote Originally Posted by Mr Nick View Post
      Attachment 110609
      There's nothing holding the rear axle up, looks like full droop to me!
      -Dale
      SchwartzPerformance
      Florida
      "I Also have air suspension fully extended should have almost 6 inches of clearance and fully compressed 1.75 inches of clearance "
      I don't think 1.75"will be enough because the mufflers are not directly under the axle. They'll probably hit even the shortest of speed bumps and driveway lips before the rear tire gets to the bump to raise the car.
      marina ca
      Quote Originally Posted by Schwartz Performance View Post
      -Dale
      You are correct only thing holding the axle up is the shocks
      marina ca
      Yeah I'll just haven't to add some air around speedbumps and driveways
      Feb 2007
      Tinley Park, IL
      -Dale
      That's what I thought. You put that car on the ground and the rear end comes up to ride height... will those mufflers be hanging totally below the diff?
      Nick ~
      1969 Cutlass
      marina ca
      Most cars the mufflers hang totally below the diff
      I'll report back when I drive it hopefully next week
      marina ca
      Drove the car the other day and had zero scraps driving out on my incline driveway
      May 2011
      thanks for following up. I'll probably end up doing the same thing.
      marina ca
      On a air suspension car I would recommend it
      On a leaf spring car you would be scraping allot
      Ridgeland, Ms
      Those mufflers are unique in that they are very quiet while still having great air flow. And they are affordable. For a powerful cruiser and keeping neighbors happy, they are awesome. Many Buick GS guys run them (the GS Club's motto is "Going Fast With Class".
      Jeff Peoples
      marina ca
      Quote Originally Posted by BuickGS View Post
      I had flowmater 40s and 50s on be for but hated the drone. On this rebuild I wanted the best of both worlds. Quiet while puttering around town with the super turbos. Flip the cutouts open and get som attention.
    Tags for this Thread
