      left coast
      -6AN fittings and hardlines
      Gonna be dropping in my carb'd SBF in my 66 coupe and need to plumb the fuel lines. My question pertains to -6AN tube fitting using compression fittings. My preference is to hardline between fittings rather than use braided hose, I understand whats traditionally done is use braided, its a preference to hardline the runs unless someone can recommend not doing it. I was looking at the Summit's tube adapter fittings, http://www.summitracing.com/parts/sum-2200075b . Looks very similar to Aeromotive, but can't get a psi rating for the Summit fitting. Realizing this is carb'd, maybe 10psi from the mechanical fuel pump, how tight are these fittings and what's the psi rating. Are they a bear to seal given the fittings are aluminum and the line will be 3/8" stainless?
      Beach Park IL
      They are just like any other compression fitting, there is a brass ferrule that crushes when tightening and that forms your seal. I use tube nuts and sleeves with a flare but those are fine.
      Donny
      Apr 2012
      Woodstock, IL
      They do hold up to a lot of PSI, we've used them on EFI systems. 10psi is nothing, and as Donny mentioned they're the same setup as most compression fittings which are also rated for high PSI. If it leaks, tighten it a bit and it'll usually conform well.
      -Dale
      SchwartzPerformance
      Jan 2014
      Sacramento, California
      They require 37 degree flaring not a standard 45 degree
      Jan 2014
      I'm running the same setup on my car pm me If you have more questions
      Aug 2011
      North Platte,NE
      Be careful which hardline you use in aluminum, the Russell stuff is high pressure rated but a lot of the Summit,Jegs etc. brands are not.
