      Nov 2009
      Ca
      I need lifters!!!
      I need to buy a set of roller lifters for my Pontiac 400 build.
      I can not decide on Comp or Lunati. There is a pretty good price difference between the two.
      Is one really better then the other?
      Can anyone give their experience/thoughts?
      Thanks!
      Mar 2011
      Ca
      i've had Lunati solid rollers break on me under normal street driving conditions, the bridge snapped and the lifter rotated in the bore, all kinds of bad happened after that. i'll never use lunati lifters again.
      Jun 2006
      Katy,TX
      You nee some with positive oiling. Comp's Enure-X or Crower. Isky and Crower have some without needle bearing to fail with bushings but they are pricey. Had Comps in two motors one before they had the oiling feature.
      1965 GTO project car
      2004 Pulse Red GTO
      Nov 2009
      Ca
      Quote Originally Posted by Skip Fix View Post
      Thanks for the info! I guess I should of said i'm looking for a set of hydraulic roller lifters. I think the comp Enure-X are only for solid rollers???
      Fredericksburg, VA.
      What cam are you going to run? Why not same brand lifters?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Jun 2006
      Katy,TX
      Correct- no one makes a forced oiling for regular blocks. LPI (Luhn Performance) has a tall one though for the KRE or IA blocks.
      Lots of guys have had issues with HR lifters in Pontiacs. The Comp 857S are their newest version that seem to have less issues.
      2004 Pulse Red GTO
