    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 21 to 40 of 71
    1. #21
      Dec 2010
      Fredericksburg, VA.
      David,
      What is the WMS to WMS measurement on that IRS? Just curious if it is similar to a stock rear end width or narrower.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Given sufficient initial acceleration, even pigs can fly!
    2. #22
      Santa Clara, CA
      David,
      According to the AME catalog, the IRS is available in 4 track widths: 55.5", 57.5", 59.5" and 61.5" (wheel mounting surface to surface width)
      Half dozen ratios between 3.54 and 5.13
      Brake options: 12.4" rotor with floating caliper, Wilwood 14.2" with W6A caliper or 14.4" with OEM Brembo caliper
      Minimum whel size: 17" with 12.4" brake rotors, 18" with Wilwood brakes (only certain wheels will work)
      Steve
    3. #23
      Mar 2012
      Orange County, California
      You got a lot done David. It is looking great. Probably a little easier after doing Mary's.
    4. #24
      Central CA USA
      This was lots easier & I'm better at it now that I've done Mary's. I'm doing trunk close out panels now.
    5. #25
      Lake Ontario, NY
      David,
      That part of your signature should be bigger...much, much bigger.
      lol
      Skip
    6. #26
      Dec 2009
      Carson City, NV
      Quote Originally Posted by compos mentis View Post
      David,
      lol
      I think he's afraid Mary will see it if its any bigger
    7. #27
      Central CA USA
      Quote Originally Posted by ChevelleNV View Post
      That was my intention. I tried to sneak it in to see how long it took for Mary to notice. It took a long time!
      Rod, nice tank! What do they do inside for fuel slosh?
    8. #28
      Central CA USA
      Trunk nearly done. Mini tubs are next.
      Trunk cut.
      The lower trunk floor, I bent up a flange for strength and to give me something to weld the filler piece to.
      View from underneath
      I found there would be no room for my hands to reach the cradle mount bolts, so I cut out a triangular area on each corner & will make filler panels.
      Test fitting the corner filler pieces. I Made them raised but dropping down towards the center so I could have a little extra room underneath for access to the cradle attachment nuts.
      Name:  trunk corner.jpg
      Filler panels
      Nearly finished trunk. I pushed the front portion up to make room for the rear cradle. On Mary's 73 Camaro, I made a whole new piece but it was very difficult to get in there to weld the forward edge. This way it's still attached & less work.
    9. #29
      It looks great David. Very interesting install.
    10. #30
      Auburn, WA
      David,
      It's 59.5", so basically stock. This is mainly done for packaging reasons, as it allows the UCA to clear the frame rail well. I know some like a little more dish in the wheel, but having a little wider track width is easier on the wheel bearings and reduces bushing deflection under power.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
    11. #31
      Oct 2007
      Newark DE
      Great, now Mary will be even faster Guess a lot of driving school is in my future.
      Thank you for all the info and great write up. Very informative. Guess Matt did an awesome job as usual since Mary ran leaf springs forever!
    12. #32
      Mountain Springs, Texas
      Any updates David?
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    13. #33
      Did a test fit of the IRS and wheels on my 69. 12 inch wheels with minitubs and I am stretching the rear quarters by a little over an inch to get a little margin. Planning on a 345 tire.
      Don
    14. #34
      Central CA USA
      I've done the left side quarter stretch by installing a replacement "skin" panel. Working on the right side now.
Size:  200.5 KBName:  image.jpg
    15. #35
      I knew my post would bring you out David. Good to see your photos. Have you decided how to run the brake lines etc?
      Don
    16. #36
      Lawrenceburg, TN
      Quote Originally Posted by david pozzi View Post
      i've done the left side quarter stretch by installing a replacement "skin" panel. Working on the right side now.
      awesome!!!!!!
    17. #37
      Central CA USA
      Don,
      I'll probably run them down the sides, thru the crossmember, then up the rear floor with a bulkhead fitting on each side like I did on Mary's car below.
    18. #38
      Mar 2012
      What rotors did you decide to run? I want to stick with the stock Brembos. Does a ZO6 rotor match the stock Camaro in rotor hat e-brake and Brembo cast in abutments?
    19. #39
      Central CA USA
      We run on 18" rims, so went to Baer 14" rotors & their 6R calipers. The E brake works. Morrison sells a Willwood setup for it.
      The Camaro has a metric bolt circle where the Corvette hubs used are the old Chevy bolt pattern. I think the two are super close. The Corvette hubs used have a larger center register than the Camaro. I had to bore the rotors to fit. AME normally uses a Willwood kit to fit with everything modified. I'm using Baer 6R calipers and 14" rotors. Baer came up with this kit to fit the AME IRS for us, since we wanted to stick with their products. It's extra work to squeeze 14" brakes inside a 18" rim, using the 5th gen Camaro knuckles.
      I may route my brake lines to in front of the fuel tank. It would allow me to remove the calipers with lines attached, hang them by wire, then drop the IRS out. The way it is on Marys car, the brake hoses must be removed, but there is less motion of the hose by following the lower forward link.
    20. #40
      Mar 2012
      Quote Originally Posted by David Pozzi View Post
      I may route my brake lines to in front of the fuel tank. It would allow me to remove the calipers with lines attached, hang them by wire, then drop the IRS out. The way it is on Marys car, the brake hoses must be removed.
      What radial mount did you use to put the Baer 6R onto the GM 5th gen Camaro rear knuckle? I talked with Baer and the only kit that have uses a 15.5" rotor. I'd like to stay stock 14.4 Camaro with the internal e-brake.
      I can confirm that the bolt patterns are super close. I put Corvette wheels on the Camaro hub, since the Camaro rotors would not fit over the Z06 hub.
