    Results 1 to 13 of 13
      Jun 2014
      Harrisburg, PA
      Would this cam cause my lack of vacuum??
      I am running a 383 stroker in my 72 Camaro. I am only pulling 8" of vacuum at idle. Timing is locked at 42* and am running a Comp Cams HYd Roller with the following specs.
      Adv Dur 294 300
      Dur @050 242 248 lobe seperation 110
      Lift .540 .562
      Looking for input on if the cam is the culprit or is something else at play here.
      Dec 2010
      Fredericksburg, VA.
      Holy crap, why so much timing?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Given sufficient initial acceleration, even pigs can fly!
      Jun 2014
      Harrisburg, PA
      when they had it on the dyno that is where they got the best numbers...
      That's a lot of cam, and is certainly the cause of your low vacuum. That's a lot of timing too, but with that big cam and a lot of overlap, I can see how it might be OK.
      Instagram @projectgattago
      Dr. EFI
      Apr 2013
      Louisville, Ky
      Hey Andrew
      yea, it's your cam. keep in mind a carb can take a lower vaccum signal (110 lsa). also i agree that 42* is a bit too much total timing, maybe try for around 32-36*.
      Anthony Hammond
      Dec 2009
      Carson City, NV
      put a vacuum gauge on it, and adjust the timing till you get the best vacuum signal.... probably end up around 32-36*
      Jun 2014
      Harrisburg, PA
      Quote Originally Posted by ChevelleNV View Post
      I thought backing off timing would decrease vacuum...I think I will back it off a bit anyways. I was never thrilled with 42* but the guy builds a ton of great motors so I figured who am I to question it.
      Thank you for all the feedback..
      Dec 2009
      Carson City, NV
      Quote Originally Posted by 72RS View Post
      Put a gauge on it, I bet you will be surprised at what happens
      Jun 2014
      Harrisburg, PA
      will try it...thanks...
      Jun 2014
      Harrisburg, PA
      This may be a dumb question but I won't do any harm to the engine or effect its performance by backing the timing off will I, being that it was dynoed at 42*
      Like I said earlier I always thought 42* seemed like a lot.
      Dec 2009
      Carson City, NV
      Just cause it was dynoed at 42* backing it off is not gonna hurt the motor, worst that will happen is you will gain little drive-ability and loose a little performance. when they dynoed it, they set it up for maximum performance which almost always kills drive-ability and gas mileage.
      Mission Viejo, CA
      I had the exact same cam specs in my 464 Pontiac and it had rowdy idle, and only pulled about 12" of vacuum. With 80 fewer cubic inches that wont be real street friendly. If you were to run a cam with a wider LSA of 112 it would pull more vacuum and be more streetable.
      1973 Hurst Edition Pontiac Grand Am: 430 CI of ERL built LS7, Tremec Magnum T-56 6-speed, Global West / Speedtech Suspension, Custom rear coil-over suspension, QA1 double adjustable shocks, Wilwood 6/4 piston disc brakes, Modulare C1 19" concave wheels. Shooting for 625 HP and 20 MPG!
      Southern Indiana
      OK, so yo guys are all wrong on timing.
      Tuning for best power on dyno, you dial in initial for best power, then keep speeding up the rate of centrifugal advance till engine makes best power THEN hook vacuum advance to manifold vacuum.
      As for total timing minus vac advance, if the heads have a slow burning chamber the may NEED more timing.
      I have tuned hundreds of engines for street and track duty and soooooo many are low on timing.
      36-38 deg is a cliche timing point used by so many. I have seen vortec heads require so little timing over regular heads. Also I have found some aluminum heads take some really messed up timing curves.
      NEVER assume anything about a persons tune unless its tune is causing an issue.
      Now if you really want more vacuum, try a little extra cam advance.
      I really like using cam advance to build best cylinder pressure, thus making best torque.
      Old trick but it does work well.
