      Oct 2012
      Engine building philosophy. rocker or cam
      All else being equal, for the sake of argument, is it better to increase lift at the cam or at the lifter via ratio?
      1980 AMC Spirit
      406 SBC ( blown up )
      2004r CK Performance
      Ford 8.8 rear 410 gears
      Southern Indiana
      build the cam to the engine spec, ie design it right, THEN you use a different roller rocker too tune the engine. See basically you attempt to design an engine as best you can, but you cant cover every contingency, so you use different things to tune.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Jun 2005
      Grapeview, Wa
      I hate to say this, but it depends on:
      -The cylinder head
      -The valvetrain geometry inherent to the cylinder head
      The current theory in many racing applications is to use milder lobes with a higher rocker ratio, but again, it really depends on the head.
      Tad
      '73 Camaro RS in progress.
      L-D 3-link (working on the front end, too), SCP spindles, Wilwood brakes. I'll be working on it for A WHILE!
      Illinois
      Depending on the engine platform... Most like to keep the cam profile as less aggressive "as possible" and allow the rockers to increase lift.
      This is especially helpful in a engine like a traditional pontiac ... where the lifter bore area of the block is not the strongest.
      Beebe
      A link to some pictures of my Firebirds and other toys
      http://community.webshots.com/user/ponchoman69
      Oct 2013
      Country Flag: Norway
      Engine building is all about compromises and you make different compromise for different use.
      For endurance engine for example, I'd stay low ratio rockers because the higher ratio the more guide wear, valvespeed etc.
      If I wanna squeeze every little pony out of it and run 1/4mile at a time I wouldn't mind playing with rocker ratios.
      Mar 2011
      Ca
      like others have said it depends on the engine and its intended use, if you're looking for a more streetable cam but want more lift then i'd use the rocker ratio, but if its a max effort race engine thats going to see alot of sustained high rpm id use a larger cam profile, and don't forget to check for proper geometry after new rocker arms, you probably need to change your pushrods also.
      Feb 2014
      Memphis, TN
      http://www.knowyourparts.com/technic...r-arm-history/
      This is an interesting read. When I first read this thread, I thought of which would require less effort to do its job. This is the article I read about it. Seems the higher ratio requires less effort.
      Just something else to think about.
