      Jan 2010
      NY
      Gauge Cluster help!
      How do you mount this gauge cluster without drilling holes in the plastic cluster? I installed Autometer gauges and they mount nicely but I don't know how I can mount it to the dash without putting screws through the cluster. What can I fabricate to hold it in place?
      Jacksonville, FL
      I assume it should fit like the factory bezel, it should slip onto the top mounting and then secure n the bottom using the 2 factory screws like the factory one did.
      Chris
      1968 Chevy Camaro SS
      LS3/T56 DSE suspension
      Jan 2010
      NY
      Gauge Cluster help!
      There is nothing for it to slip into on the top. I can put fender clips on the bottom but what can I use for the top? Any suggestions?
      Jacksonville, FL
      See my post in this thread- https://www.pro-touring.com/threads/...all?highlight= There is a piece that attaches to the dash and thats what holds the bezel in place. Hope this helps!
      Chris
    Tags for this Thread
