07-14-2014 #1
SBO timing cover crank seal runout tolerance
So I decided to make a aluminum timing cover for my SBO. Now I'm wondering about how spot on the crank seal hole needs to be I haven't measured it yet so I don't have any numbers for you guys to compare. Basically what I'm wondering is if I need to make the part the seal presses into bolt on or does the seal have enough tolerance factored in that if I just weld the hub piece on it will still seal. I placed it against the factory steel one it it's pretty close but the factory one isn't very round and this one was laser cut so it's really round.
07-29-2014 #2
07-30-2014 #3Registered User
- Oct 2006
- Chicago
- 289
Interesting. Any reason you decided to make one?
Luke
'63 Chevy II wagon - project
08-03-2014 #4
The steel one had a lot of pitting where the gasket goes so i needed to replace it. Was looking for a aluminum one and found they were around 225 for a stock style and felt that was a little high so i set out to make my own. I do engineering and design work using Autodesk inventor. At my work i have access to Lasers for cutting and CNC machines and lots of left over material. Outside of that no real good reason.
