    Page 40 of 80 FirstFirst ... 30 35 36 37 38 39 40 41 42 43 44 45 50 ... LastLast
    Results 781 to 800 of 1589
    1. #781
      Apr 2014
      Quote Originally Posted by rohrt View Post
      Thanks to this Google Chrome extension I can see all your older PB pictures again.
      https://chrome.google.com/webstore/d...fegnfnflicjjgj
      That is awesome! thank you for sharing!
      Pat
    2. #782
      Aug 2014
      What's the extension called? When I click on it, it just takes me to the store, not a particular extension.
      Jay
    3. #783
      Apr 2014
      Quote Originally Posted by JayinMI View Post
      Jay
      Jay,
      Type in photobucket, and you will get a few options one of them is dedicated to the third-party usage
      Pat
    4. #784
      Apr 2014
      Sprayed the last coat of primer on the car and ready for the 320 blocking
      Pat
    5. #785
      Apr 2004
      Cedar Rapids, IA
      I like how you curled that paper back on the top.
    6. #786
      Apr 2014
      I used a level with a straight edge to help to find the center of the style line for laying out tape on the body line. When level, sliding the straight edge will leave a mark dead center of the body line. I'm sure there are many other ways of doing this but I found this work good for my old eyes ;-)
      Pat
    7. #787
      Pretty slick!
    8. #788
      Sep 2013
      sw Kansas
      Pat, I REALLY understand about the "old eyes" comment. Are you going to shoot the car in your shop?
    9. #789
      Apr 2014
      Yes, when all the blocks sanding is done we will blow the car apart, take it out of the booth and do a thorough cleaning of the walls, ceiling, lights, and floors then bring the parts back in and paint the hood, doors, and the fenders off the car.
      Pat
    10. #790
      Apr 2014
      With the body lines taped I blocked sanded the top 1/3 and bottom 1/3 of the sides with 320 grit sand paper. Then using the 1st tape line as a guide, I ran tape above or below the first tape line so I could block sand the center section of the car. This creates straight but sharp body lines that need softened. After removing all the tape I went back over both sides with 400 grit sand paper softening the body lines.
      600 grit paper is next one step away from sealer :-)
      Pat
    11. #791
      It look good Pat nice job. I remember when I did mt 73 Z/28 with 600 before buffing, Man what a job. I can't even imagine doing a car that big 3 or 4 times already. This is going to be slick! Nice work.
    12. #792
      Sep 2013
      sw Kansas
      I sure hope your arms don't fall off! Who would run the paint gun?
    13. #793
      Apr 2014
      I had a few people ask what materials I was using for primer, filler and paint so I thought I would pass this information on here as well.
      Starting with all the paint stripped I sprayed the bare metal with Cromax epoxy DTM primer #2599S (DuPont product). From there I used all Evercoat products for the filler and high build primer. Evercoat Rage ultra body filler #100125 was used for the first layer over the Cromax epoxy primer, except for any edges or corners I used Evercoat Everglass #100622 Next was a skim coat of Evercoat polyester glazing putty #100400.
      With all the filler sanded to 220 I sprayed 2 layer of Evercoat Super build primer #100730. Block sanded that down with 220 grit paper and sprayed two coats of Evercoat Finish Sand #100738. Sounds like a broken record but I block sanded that back down again with 220 grit paper.
      Then last two coats of Evercoat Finish Sand #100738 and started block standing at 320 then to 400 grit paper.
      For the sealer, basecoat and clearcoat I will be using all PPG products.
      I will use PPG's DP90LF epoxy primer sealer. Then PPG Omni basecoat. And then we will follow it up with PPG's DC4000 clearcoat.
      Pat
    14. #794
      Sep 2013
      sw Kansas
      I wish I was close to you. I would have enjoyed being around on this whole project. I know that it's great when it's finished but I will miss watching your thread. When my 51 was finished, it was great and sad at the same time. LOL
    15. #795
      Apr 2014
      I'm sure I would've enjoyed your company, but all the BS we would do would add another year to do this project ;-) When this car gets painted and I start seeing light at the end of the tunnel then I'll start
      thinking about the next project. I always tell my wife my favorite car is the next one.
      Pat
    16. #796
      Apr 2014
      Ok, this is the 4th and it will be the last primer coat! The 3rd coat was very close but not for black.
      Pat
    17. #797
      Sep 2013
      sw Kansas
      I'm smiling for you.
    18. #798
      Me Too!! Nice!
    19. #799
      Apr 2014
      Me Too!! Nice!
      :-) right back at you
      Pat
    20. #800
      Apr 2007
      Utah
      This car is going to be so nice when completed. Nice work.
      Sam
      Northern UT.
      '68 Camaro "Bodacious"
      '56 210 2dr "Buckshot"
