Results 1 to 20 of 33
Thread: 1991 Camaro Z/28 LS1 - T56
04-30-2014 #1New to Pro-Touring
- Sep 2011
- 58
FALL PRICE REDUCTION: $12,000
(Front splitter was scraped driving on the grass to a car show, so I will either have it resprayed or deduct $250 from the price.)
DEAL DID NOT GO THROUGH CAR IS AVAILABLE AT NEW PRICE OF $13,000
(This video was shot on a cold start after the car was sitting for a couple weeks)
5/28 PRICE REDUCED TO $14,000 OR BEST OFFER
1991 Camaro Z/28 with a built LS1 and T56, full coil-over suspension, twin plate clutch, etc.
I purchased this car from the original builder in January of 2013 through this forum, but didn't put it on the road until this Spring. It is incredible to drive, but my plans have changed, so it is now for sale. The build thread can still be found at http://www.thirdgen.org/techboard/lt...8-ls1-t56.html if you'd like to see the time and effort put in by the previous owner. This would make a great track day car, but is easy to drive on the street. The twin plate clutch has a light pedal, the rack and pinion steering is well balance, and the ride is surprisingly good. The car pulls very hard, and shows good oil pressure and normal operating temps. There is a very small amount of smoke from the exhaust on start-up, but the engine has less than 200 miles since it was built. Local mechanic whose helping me with a few odds and ends believes this will subside as the rings are seated.
Since I purchased the car, I had new headers and a 3" stainless exhaust with a Magnaflow cat-back installed. The drivetrain was removed with new motor mounts installed, and a couple wiring issues sorted. I'm having a few miscellaneous items taken car of next week (brake lines secured, rear view mirror installed, etc.), but I've put 150 miles on the car with no issues. The ride height has been raised slightly, to account for our roads.
The interior is functional, but could use some finishing depending on a new owners intended use. A 4th gen dash and complete wiring harness have been installed, but the A-pillars and door have not been matched (see picture). When I bought the car, I planned to finish off the interior or reinstall a 3rd gen dash. After driving the car, I don't even notice it.
The body work is very straight, with one minor knick on the front splitter (see picture). The paint is well above average other than the fiberglass hood, and a couple of minor spider cracks in the body skirts. Very hard to notice, but I want to be clear the paint is "high quality driver", and not a perfect show car. The build thread shows the body work in process. This is a very clean, zero rust 3rd Gen with hours and hours spent prepping and painting.
The suspension and drivetrain are detailed below. I pulled this equipment list from the original ad, and nothing has been changed other than the headers, exhaust, and steering wheel. The exterior pictures were taken yesterday, and I apologize the car was not very clean. If it ever gets above 45 degrees, I will get it cleaned up, waxed, and post new pictures.
The car is located in Northern Michigan, and I am asking $16,500 or best offer. Trades possible, but would have to be close in value, and for complete, running vehicles only. Thanks for looking, and please contact me with any questions. IM through this site, and I am usually able to respond the same day.
Equipment List from 2013 Listing:
Tubular K-member: custom made piece from PA Racing, strengthened for road racing and incorporates mounts for a Ford rack and pinion
Front tubular control arms: Made by BMR
Spindles: Fabricated by Racecraft inc, incorporate a 2" drop and have a shortened steering arm for the rack and pinion
Struts: made by Koni and are adjustable
Upper strut mounts: Made by Spohn, large improvement over stock
Front coilover kit: Made by Spohn, allows for adjustable ride height
Outer tie rods: they are a bump steer kit made by Baer brakes
Rack and pinion: stock piece made for a ford Thunderbird
Front brakes: Brembo 4 piston calipers with 14" rotors
Brake lines (all): Made by inline tube
Radiator: new aftermarket replacement
Rear end: stock unit from the donor car, but was rebuilt with new bearings and seals, Torsen diff and Richmond 3.73 gears
Rear shocks: Koni adjustable
Rear coilovers: made by Koni
Panhard bar: Made by UMI, tubular, rod ended, fully adjustable
Panhard relocation: Made by Founders inc, offers more room around the axle for exhaust to be routed
Exhaust: fabricated with mandrel bends and a pair of Borla S type mufflers
Wheels: Made by Forgestar, lightweight, fronts are 19x9 rears are 19x11
Tires: Hankook ventus V12 Evo, fronts 275/30/19 rears 295/30/19
Engine: LS1 block, fully machined
Rotating assembly: Mahle forged pistons, Mahle file fit rings, Scat rods, new oem crank, Clevite bearings, fully balanced
Camshaft: Lg Motorsports G6X3
Lifters: LS7 racing lifters
Oil pump: new ported LS6 oil pump
ARP Head studs
Crane roller rocker arms
Push rods: Comp cams
Heads: stock casting 799 heads, with patriot gold dual valve springs, titanium retainers, and locks
Gaskets: all new and oem
Intake manifold: Fast 90mm
Throttle body: Nick Williams 90mm
Fuel rails: Fast billet rails
Injectors: OEM gm 32#
Trans: stock t56 speed gear box
Clutch: Textrailia twin disc clutch
Hydraulics: New OEM clutch master and slave cylinders
Shifter: New, made by B&M
Hood: Made by VFN and is an ultra light weight fiberglass piece
Weatherstripping: All new and OEM GM
Carpet: new, made by ACC
Seats: New racing style with openings for racing harness
Roll bar: New, made by Comp Engineering
Steering wheel: New made by Momo, suede wrapped
Fuel lines: New, custom braided lines
Power window motors: New, OEM pieces
Belt moldings: new, OEM
Engine photo shows old headers which have since been replaced. I will post updated engine pics, got rained out yesterday.
