Results 1 to 11 of 11
Thread: vibration & no solution...2
04-20-2014 #1Registered User
- Sep 2010
- Germany
- 40
Notice a high speed vibration if i get into the +80mph (4000 rpm)range with my 65/455- conv. / TH400
I notice it came from behind, and i´m not sure if i hear a "DDDDRRRR" that stops if i slow down, or if its only the pulsate of vibration that cross the car?? .....soooo i checked the drivline angle first, notice the Trans was 3,5 down,as long as the Pinion was 0,5 up ( digital Tool) -*
so i corrected Pinion to 3,5 up to be equal !!
NOTHING!! Vibration start at the same speed.
Change the Tires ( I talk to myself, maybe the big 295/50 are shake )
NOTHING!! Same speed same Vibration!!
The parts below are changed and now installed:*
-again new Motor mounts
-againTrans mount
-weld brackets to the boxed frame to minimize swinging from the Trans- crossmember
-new balanced driveshaft (5500 rpm)
-new U-Joints
-Transm.angle 3,5 deg.down / Pinion angle 3,5 up as i say
-Rear end overhauled /Posi-Gears-Timken bearings-old shafts!
-UMI´s rear Uppers with spherical rod ends
-Stock reinforced lowers with poly
NOTHING...NOTHING..NOTHING....still the Tiger in the Trunk
I was thinking to check
- if maybe a axle bent
- if Converter not installed correct*
- U-Joints or maybe on more time the rear end
(backlash-play-POSI Clutch-bearing???)
any input...any idea..let me know
sorry for my English
04-21-2014 #2
