Thread: Door pannel clips 1969 camaro
01-30-2014 #1
Having problems with the clips on door pannels popping back out. Have new inserts and clips? Standard door pannels. Any ideas?
Dan
1969 rs, bbc, tremec 600, 12 bolt, mini tubs, dse a-arms, springs, iforge wheels...
02-07-2014 #2Registered User- Join Date
- Aug 2008
- Iowa
- 304
are you using the wire clips? Those are nice if you remove the panels a bunch, but if you need something to stick, try the plastic threaded ones. They are usually only good once because when you pull them out it strips the threads, but the stick damn good.
02-08-2014 #3
