Results 1 to 20 of 57
01-29-2014 #1Registered User
- Feb 2011
- 32
Locker vs Truetrac / Torsen / Wavetrac on Road Course - track time comparison?
I've got a nascar locker in my car right now, and I'm considering 'upgrading' to a worm gear differential. Thoughts on how much 'better' it would be? Say, on a 2.9 mile road course? On 'street' tires.
I'm hoping to find input from someone who has swapped from one to the other and has lap times to share on what the change netted in performance.
The biggest deficiency in my car right now is me. If my money is better spent on additional track time and tires at this point, then that's what I'll do. But at the end of the day, I want to run with well driven modern cars, and that means my car needs to be there as well.
Car:
01-29-2014 #2Registered User- Join Date
- Dec 2010
- 169
I have run a Detroit Locker, a Torsen and a Salisbury in a fairly light car (2340 lbs). The Detroit softloc was way too violent when it would lock and unlock and actually upset the car. I don't think that would be a problem with a heavier car say 3000 lbs though. When you throttle up the rear end locks and may cause some understeer depending on your set up. The Torsen would spin the inside tire exiting a corner if I had much rear roll stiffness, it was very smooth but I pulled it because of wheel spin. The Salisbury has a set of clutch disks with belleville washers to preload the clutches, the spiders are also set up on v ramps so it really locks up if you have traction. I like this system the best because it always smooth locking and unlocking and it does not spin the inside tire with a stiff rear bar. I think you would really have to be on top of your game to see much time difference on a road course with any of these differentials to answer your question. Seat time is always a good investment vs spending money on your car.
01-29-2014 #3
