Thread: Tko 600 hp
    Oct 2013
    Default Tko 600 hp
    Is anyone currently running the TKO 600 with more than 600 ft lb and 600 hp like they are rated for? thanks
    Houma, Louisiana
    Default
    I have a TKO 600 in my 70 Nova with a 572 - 620hp@650 ft lbs torque. No problems so far with approx 4-5k miles on this combination.. Being traction limited probably helps though. I have a spare 572 that I recently dyno'd and it put down 647hp out of the box with no jetting changes so I am sure the one in my Nova exceeds the 620 factory rating. Only problem I have had is the 2-3 shift but it may be me. Other then that its all good.
    Bill Haynie
    1970 Nova 572/620 TKO600
    2013 Boss 302 Laguna Seca
    Oct 2013
    Default
    Thanks for the feed back. Im having a 496 built and the builder figured it would be around 700 hp and 635 ft lb. Its going in a 69 Camaro with 335 rear tires. Its not going to be a race car but it will do the occasional smoke show.
    May 2006
    Barrington, IL 60010
    Default
    FYI: The TKO 600 is a good solid tranny for street use...but be aware you cannot 'blast' 3rd gear; it is the weak link. A friend grenaded his at LSFest.
    Rich
    'Wicked Witch'...1969 Camaro, Mast Motorsports LS-3, Magnum T-56, DSE suspension & BFG Rival-S on Forgeline wheels.
    A herd of stock #'s-matching '69 Camaros.
    Houma, Louisiana
    Default
    Even though I do have the TKO 600, the T56 probably would have been a better choice but I am happy with what I have.
    Bill Haynie
Posting Permissions
  • You may not post replies
  • You may not edit your posts
