Results 1 to 11 of 11
    Jul 2013
    Minnesota
    Default deadener on doors worth it?
    i have a 69 camaro and i just finished laying dynamat on the back seat area, tubs, partition, and entire floor, i have just been wondering if it is worth it to do the doors? i do not have any speakers in them and if i should do them, which areas should i cover?
    Default
    I think it makes a big difference. I did it on my 69
    Project FNQUIK http://www.pro-touring.com/showthrea...ghlight=FNQUIK
    Jul 2013
    Minnesota
    Default
    did you do it on the inside of the outer skin or just the outside of the inner part?
    Apr 2012
    Woodstock, IL
    Inside of the outer skin is flatter which makes the "tin" sound, it's most needed there. Dynamat type deadener is what I'm talking about.
    -Dale
    SchwartzPerformance
    Tacoma, Wa
    Same. Works really well. Gives that door shutting "thud".
    Brian
    68lovebuzz
    68 Camaro, LS6, TKO 600, Moser 12 bolt 3.73 W/Eaton LSD, hotchkis/bilstein, KORE3 C5 brakes, RUSHFORTHs and a few other tweaks ; )
    Jonesboro, Arkansas
    Default
    If the Dynamat is installed on the inside of the door (outside panel, but inside the shell) wouldn't it tend to hold moisture?
    Carl Wilson
    1968 Camaro - T-56 6 speed - 383 Stroker, 2014 Mustang GT seats
    Feb 2011
    dallas, tx
    Default
    Sorry for the late answer I did it on the door skin.
    Jul 2013
    Minnesota
    Default
    Thanks guys looks like that's where I'll put it then
    Nov 2007
    Seattle
    Default
    I put Dynamat on the inside of the inner door panel since I too was concerned about moisture. It helped a lot.
    Apr 2010
    Pittsburgh, PA
    Default
    Mainly the ccd matting like dynomat is for taking away vibration resonance from speakers or perhaps downpipes.
    And you only really need 25% coverage.
    To Combat heat takes a different matting
    Same with air Bourne noises...MLV and ccf om wheelwells help with that
    Def good to get moisture out like mentioned
    72 buick skylark
Posting Permissions
  • You may not post replies
  • You may not edit your posts
