    Results 1 to 20 of 83
      Ventura, CA
      Goodguys 2015 Giveaway C10 by Scott's Hotrods
      Scott's Hotrods is pleased to announce the official build for the Goodguys 2015 giveaway C-10.
      We have had a great relationship with Goodguys over the last 15 years. We have had the opportunity to build a handful of giveaway cars in the past, but unfortunately the timing was never quite right to do one for Goodguys. I'm very excited that we are doing this one. Great truck, and great timing.
      We are determined to make this the best C-10 we've built to date.
      Goodguys has already done a lot of the hard work in determining the look, having the rendering done, and aquiring a lot of the hard parts. Our job will be to execute the plan and rebuild this truck form top to bottom. There is not a piece or panel on this truck that will go untouched.
      Here's the synopsis of the build:
      Scott's tube chassis
      Tube x-member
      Body mounts
      100% TIG welded
      Scott's standard ifs
      New power rack
      Tubular upper and lower a-arms
      Cnc machined rod-ends
      Modular dropped C-10 spindle
      ridetech SA coil-overs
      Torsion bar style sway bar.
      Wilwood 14 inch slotted rotors
      Wilwood W6A Caliper
      Scott's LSX motor mounts
      Scott's transmission mount
      Brake lines plumbed s.s
      Fuel lines plumbed s.s
      Scott's standard 4-bar
      Scott's Watts link
      Moser fabricated 9-inch
      Wave track 3:73
      33 spline axles
      Wilwood W4A caliper
      Scott's fuel tank with efi pump
      Wheels
      Billet specialties
      Rear 20x12
      Front 20x10
      Motor
      Built L-s 3 motor
      TCI automotive transmission
      Headers and Exhaust
      Custom S.S headers made by Scott's
      S.S mandrel bent exhaust by Scott's
      Ride height on truck will be 4 1/2 from ground
      Overall height on C-10 will be 56 1/2 to the ground
      Body mods
      Several custom modifications to many to list
      There will be a ton of build pics for you all to see
      Paint
      Palmer's customs to lay down one of his stellar jobs
      Interior
      Ron Mangus to do one of his one off interiors
      Our goal hear is to build a truck that you all will remember for years down the road
      Completion of this build will be early Spring 2014
      Here's a few pics to start.
      We started on the tear down and quickly realized that this cab was in fairly poor shape. Lots of hidden rust that needed to be addressed before we could get started. Rather than have it dipped (we've had bad luck with that) we sent it out to be media blasted. Our shop lead Brycen has taken the reigns on this project.
      Ventura, CA
      Ventura, CA
      Sep 2011
      Southern Ontario
      Thanks for doing this and thanks for posting the build!
      Aug 2002
      Sweden
      Country Flag: Sweden
      Quote Originally Posted by Tech@Scotts View Post
      Great body work! What are you using to grind the welds? I have some hours in in body repair, but I've never got it THAT nice after grinding... I must be using the wrong tools.
      Ventura, CA
      TIG welder, grinder, and a DA. It's not so much how it's welded, as how it's prepped, fitted, and finished. You can achieve similar results with a MIG welder. It also helps having guys as talented as they are doing the work. (while I type about it in the office, LOL)
      Aug 2002
      Sweden
      Great progress!
      I mostly use 120 grit paper on a angle grinder, but eventhough my body prep looks OK, it's far away from what's shown here!
      It's probably easy solution - I don't have the same experience and I lack patience...
      Lol! You nailed it - I don't have any talented staff. ;)
      Ventura, CA
      Ventura, CA
      Ventura, CA
      Here's a few more for you guys. The rear of the cab is just about done.
      Ventura, CA
      Just a little holiday delay, LOL. Back at it.
      back is finished, now on to the front.
      Ventura, CA
      few more for today..
      Justin decided he wanted a cool detail to run the perimeter of the engine bay, so he came up with this belt-line. It will run along the inner fender wells as well as the core support cover.
      Ventura, CA
      Here you can see where the kick panel is moved forward 5 inches. This really makes a difference with leg room.
      Only thing left now on the firewall is a whole lot of grinding...
      Ventura, CA
      Chassis was finished up this week. Finally got around to setting it on.
      The Goodguys trailer mandated that the overall height on the truck be no taller than 57". Right now we are sitting at 57.5" Once we chop the truck it will put us right where it needs to be.
      Here it is sitting on a set of mock up rims. Enjoy the pics.
      Jul 2010
      OREGON
      Awesome build I bought some wilwood parts from you guys great service and you guys build some killer rides... Please take the slotted wheels off the suburban and put them on this truck since the suburban dont look like it has progressed in awhile..
      Ventura, CA
      Quote Originally Posted by FRENCHBLUE72 View Post
      Thanks for the business! The wheels stay on the 'Burb though, it's the bosses. Unfortunately we've been too slammed with customer jobs to work on it the last year. Well, I guess I should say fortunately we have been too slammed. This truck though, already has wheels sitting here ready to go on it. You'll like them once you see them on. It fits really well with the build.
      Jul 2008
      ohio
      wow....... i like looking at all this fab work.....one reason is i know how much skill and time is involved now after doing the work on my car......keep up all the good work
      Jul 2010
      OREGON
      Being slammed with bussiness is good justin took good care of me.... I do have a question about moving the lower kick panel forward as more leg room in these trucks is needed. But how close are your wheels at full lock to the firewall now? Did you guys move the wheelbase forward to compensate for this?
      May 2009
      The front wheel base was moved forward and there is plenty of tire clearence and full compression and when the tire is turned lock to lock
      Justin
      Sep 2013
      sw Kansas
      How much time was involved in welding the rear cab panel in with cool down inbetween welds? Great parts. I love it when a garage or trailer dictates a build.
