    View Poll Results: In your PT or Track Car, do you plan to run ...
    Voters
    128. You may not vote on this poll
    • No roll bar or cage
      21 16.41%
    • Roll bar without door bars
      33 25.78%
    • Roll Bar with door bars
      36 28.13%
    • Roll cage
      38 29.69%
    Results 81 to 92 of 92
    1. #81
      Jul 2010
      Sacramento, CA
      Quote Originally Posted by alphaenvirmgt View Post
      I would like to see a thread on installing a fire suppression system on a street-driven car that is autocrossed on weekends. I have seen several NICE cars burn to ground at drag strips due to fuel leaks. I'm thinking a system with nozzles mainly in the engine compartment and maybe around the fuel tank area. Cannot be any harder than running a new fuel system.
      Conrad
      http://www.speedwaymotors.com/Cold-F...tem,57527.html
      Completely street safe and easy to install and service yourself.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
    2. #82
      Jul 2010
      Sacramento, CA
      So, 2 seconds after posting that I checked on another board and found this video:
      Apparently the fuel return line on the subie came off and sprayed on the excuahst at the end of the course. The driver got out of the car but left the ignition on, so the fuel was still spraying. They emptied seven 5lb dry extinguishers. I think a good 30lb dry extinguisher strategically placed can save someone, and should be readily available at every event.
      -James
    3. #83
      May 2002
      Northern California
      I like that cold fire kit. Very nice. Gonna have to talk Geatano into a 2 liter kit.
      When I design and plumb a fuel system and routing I do a few things to try to make it safer.
      I run as much hard line as I can.
      Switched from Inverted flare to AN fittings.
      We no longer use steel braided line. Kevlar or nomex shielded teflon line is now the norm for us. Lighter, flash fire resistant and easier to service.
      fuel pump, regulator, filter and fuel log covers or enclosures.
      On the cage or no cage poll, I say it would depend on usage. AutoX maybe a harness bar and front strut for rigidty. Wheel to wheel, defi need a cage with door bars.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
    4. #84
      Aug 2012
      Peoria, AZ
      I came across this story and pictures while reading about the new Chumpcar\USCA story and thought it would be relevant to post in this thread.
      Well built high performance car running on Hallet, a somewhat supposedly safe road course.
      Driver loses it in corner. Final result
      Here's how it got like that...
      Look closely at that last picture... See the bolt in roll bar base plates sticking up through the floor of the car?
      **shudder**
      The Mustang is one of three Hallett CarFX project Mustangs on the cover of the December issue of 5.0 Mustang magazine. The Hallett CarFX Mustang wrecked while putting in some track time in Jennings, Oklahoma. The entire wreck was captured by a photographer in a sequence of photos. The driver of the Mustang lost control and smashed through a tire wall. The horrible part comes next as the Mustang does a front flip landing on it's roof completely collapsing to the body of the car. The amazing part about the whole ordeal is the driver and passenger were not injured in the wreck. The Mustang did have a bolt-in roll-cage but it was driven through the floor board when it landed upside down. Let this be a lesson to all who have a bolt-in roll cage, go get it welded in properly.
      I've been told that Hallet is safer to run on than Heartland Park Topeka (a track I've spent some time on with my car) because there aren't any concrete walls around Hallet to run into if you run off course.
      I'm happy the driver and passenger in the car above didn't get seriously hurt, still not sure how they didn't... But regardless, it just shows that even with the best of intentions, things can go horribly wrong very fast on a road course.
      Lance
    5. #85
      May 2013
      Colton Ca.
      I don't see how they survived but I'm glad to hear they did. That's why I personally never liked roll bars. To me the minute you decide to take your car onto ANY track you need a properly built roll cage. Just my opinion.
    6. #86
      corona,ca.
      Quote Originally Posted by Build-It-Break-It View Post
      Roll bars are safe,only if there welded in not bolted in.my wife and i spoke about this when we were at sema thursday,there was a green 2nd gen camaro with a tiger cage that was all bolt/clamped full roll cage,and my wife said shouldnt that be welded in?even she felt its not a safe set up.im not smack talking on brets product just not feeling its safety .
      72 chevelle.
    7. #87
      Wichita, KS
      **shudder**
      holy crap that was Hallet!? i never realized that, thats the only track i have ran on so far, That corner there has a name actually...."THE BITCH" now i see why. And yes Heartland park doesnt have as much run-off i heard. my friend totaled his car on that track last year from hitting the wall.
      67 GTO, LS2, T56
      WILWOOD, FORGELINE, RIDETECH
    8. #88
      Nov 2012
      Sacramento, CA
      The new "Safety for Pro-Touring Track Cars" thread is UP.
      Click HERE.
    9. #89
      Mountain View, CA
      That was not a well built car. It had a bolt-in Autopower "bar" that was improperly installed. In addition it had reclining seats, also a bad idea for a track car. In this case, the mistake of putting in a reclining seat saved the driver from the other mistake of poorly installing a bolt in "bar".
      True T.
      My blog
    10. #90
      May 2013
      Colton Ca.
Size:  106.1 KBName:  IMG_20140320_173214_381.jpg
Size:  107.4 KBHey Ron, I'm going to be installing a fuel cell in my 68 Camaro so I'll be cutting the trunk floor. My question is about adding to my roll cage in the trunk area. Currently it has an NHRA legal 10 point cage 1 3/4 tubing and .134 wall. I was curious as to what size tubing, wall thickness and how/ where should I install the rear bars to protect the fuel cell? I looked up NHRA rules but couldn't find anything. My idea was to run bars straight back toward the bumper and then a cross bar to tie the two rear bars behind the seats together. Your help is appreciated.
      Ahmad
      Ahmad B.
    11. #91
      Nov 2012
      Sacramento, CA
      You can get a pretty good idea looking at the photo of the green structure around the cell near the bottom of Post #2 in this safety thread. https://www.pro-touring.com/threads/...ing-Track-Cars
    12. #92
      Dec 2013
      Jacksonville, FL
      I am very interested in all of the above. I hope to drive something at/on Daytona next year-USCA. Both candidates have roll bars. I haven't bought any safety equipment yet but have been researching and pricing my options. This would be very helpful and perfect timing. Thanks, Bill.
