Page 27 of 34 FirstFirst ... 17 22 23 24 25 26 27 28 29 30 31 32 ... LastLast
Results 521 to 540 of 670
  1. #521
    Mar 2015
    Anaheim, Ca
    Default
    http://image.hotrod.com/f/96474012+w...daytona-24.jpg
    Anyone know what the C7R corvette splitter is made out of? Seems pretty long to not have any supports, I'd like to run something with out the struts because I don't like the look on my car. Hopefully it's strong, cheap and light! Lol
    JORDAN
  2. #522
    Dec 2013
    Default
    Quote Originally Posted by Ron Sutton View Post
    Glad the analysis made sense.
    Frankly, for me to go spend time with CFD, I'd have to have a client project funding me to do so. Even though I am "semi-retired" ... yeah right ... LOL ... I am staying crazy busy these days with my workshops, suspension & chassis designs for commercial clients, suspension set-ups for individual clients, Track Warrior parts & complete cars, brake designs, etc, etc. I don't have any major clients hiring me for aerodynamic design. So, I'll just share what I already know on these forums.
    Hmm, that gives me an idea that could be a fun pro-touring.com project...
  3. #523
    Dec 2013
    Default
    Quote Originally Posted by 1BADBET View Post
    Carbon.
    Remember, direction and type of weave matters as well as the overall shape. That thing was engineered to not need supports. It couldve been made to flex a certain amount too. The extreme being F1's flexiwings.
  4. #524
    Mar 2015
    Anaheim, Ca
    Default
    Well carbon is a little rich for my blood lol, I've searched for ideas and haven't been able to find much. Anyone know of good splitter and wing material? (Sorry to be a little off topic)
    JORDAN
  5. #525
    Nov 2012
    Sacramento, CA
    Default
    Carbon fiber, aluminum & fiberglass are all good materials for wings/spoilers. Almost the same for splitters, except I'd add ABS plastic. We've made a lot of lost cost splitters out of 1/4" thick black ABS because it is tough & inexpensive to replace. But it's not as strong as Carbon fiber, so you'll need to support it if you extend the lip beyond 1.5".
    Feel free to chime in or ask technical questions. I am here to help where I can.
    Ron Sutton
    Ron Sutton Race Technology
    Your One Stop, Turn & Go Fast, Car Building Resource Center for Autocross, Track, Road Racing & Triple Duty Pro-Touring Cars
    Check out our 412 Page Car Building Catalog HERE
    Features: Suspension, Chassis, Cages, Brakes, Rear Ends, Engines, Transmissions, Aero & Much, Much More!
  6. #526
    Mar 2015
    Anaheim, Ca
    Default
    How thick for an aluminum splitter without struts? If I'm going to put the end of the splitter even with the end of my bumper (and the same shape for looks) how long should I make it? The longer the splitter gets the farther back the air dam will be, I'm just not sure where the sweet spot for compromise would be, splitter length vs air dam closer to the front.
    JORDAN
  7. #527
    Nov 2012
    Sacramento, CA
    Default
    You're on the right track. Make the the leading edge of the splitter flush with the leading edge of the bumper ... and place the vertical airdam back a few inches behind both.
    I apologize Jordan, we have wandered into an area I don't have much experience at. I never tested materials, thicknesses & lengths of splitters to see how long I can build one without supports. I "almost" always ran supports. Once a 1.5" splitter, made out of 1/4" carbon fiber, we ran no supports, and it worked well. But I've never gone longer without supports. So you'll need to experiment with this on your own & let us know.
    As far as length of splitter, the longer you make it (assuming it's not flexing) the more front downforce it creates ... but it is a decreasing reward per inch. When I'm looking for all the front downforce I can get & have no rules limiting us, I run the splitter out about 5". Frankly, it is only about 22% more effective than running it 3" ... so it depends on if you're going for good, better or best downforce.
    Ron Sutton
  8. #528
    Mar 2015
    Anaheim, Ca
    Default
    So with a splitter of 5" long and about 80" wide how much down force in lbs could I expect roughly? My thought is to block up a piece of aluminum and if it's 200lbs of downforce I would just stand on it and see if it bows lol not very scientific I guess, but maybe it will work. I know that my weight would be concentrated in one area so maybe I could do a little math and figure out how far to set my feet apart based on splitter length and estimated downforce. My thinking is to make a nice rigid aluminum splitter. 3 1/2" - 4" long then use a 1"- 1 1/2" ABS end piece that's attaches with flush mount screws so if it gets chipped, scraped or busted it's easily replaced
    JORDAN
  9. #529
    Nov 2012
    Sacramento, CA
    Default
    Too many factors at play to guess how much downforce you will achieve. But the target should be 300#+ at high speeds. So think about laying lead blocks on top of the splitter all the way around. You're looking for minimal deflection (1/16") ... or we're giving up downforce.
    Ron Sutton
  10. #530
    Mar 2015
    Anaheim, Ca
    Default
    Would spill plates just where the back window is help anything? I don't think they would look good on the roof but I have to shim up the back glass to make it flush anyway so maybe some clear L shaped plastic to set the back glass on would kill two birds....
    JORDAN
  11. #531
    Nov 2012
    Sacramento, CA
    Default
    Oh yeah !
    I know you're not running them ... but spill plates on the roof help the airflow over the roof end up on the back glass, deck & wing or spoiler ... as opposed to rolling off the edges of the roof.
    Spill plates on the back glass do the same & "can do" more. If they're tall enough ... the spill plates on the glass act like strakes ... straightening the airflow. This preps the airflow to work better over the decklid & spoiler or wing. Frankly, if they're really tall (too tall to look good) they literally create side force when cornering. You can see the TALL clear plate on this NASCAR Cup car shown here ...
    I am posting a photo of an oval track car ... just because it was handy. But look at the 4 strake type spill plates leading up the spoiler. Those actually catch side draft airflow when cornering ... creating what is known as side force ... helping the car to have a little more rear grip on corner entry.
    Name:  Modified Spoiler with 45 Wicker - Side View.JPG
    Ron Sutton
  12. #532
    Nov 2012
    Sacramento, CA
    Default
    Hey Guys!
    I'm stepping away from the keyboard for about 10 days. I've got a shock development track day Friday ... then a camping/quading trip for 10 days with my family. I'll be back on here after June 6th.
    Ron Sutton
  13. #533
    Mar 2015
    Anaheim, Ca
    Default
    How tall would roof and back glass spill plates have to be to make a considerable difference on a PT car? I've seen some pretty short looking ones on bonniville cars....
    JORDAN
  14. #534
    Mar 2015
    Anaheim, Ca
    Default
    Not sure if I'm going to be able to keep my engine under a flat hood but if I can't should I run the cowl induction sccop the whole length of the hood or keep it as short as I can more like a stock 70 chevelle or a TA firebird shaker?
    JORDAN
  15. #535
    Florida
    Default
    SCTA/BNI rules require roof rails as a safety item to reduce lift by acting as a spoiler if the car starts to spin. Dunno where my old rulebook is to check what classes require them but here's a recent thread over on the LSR forum about them and a little history. http://www.landracing.com/forum/inde...c,15508.0.html
  16. #536
    Nov 2012
    Sacramento, CA
    Default
    Oh ... 1/4" makes a difference. Of course 3/8" is better & 1/2" is better than that. We're mainly trying to keep the attached airflow ... attached. We're not trying to redirect major volumes of air.
    Ron Sutton
  17. #537
    Nov 2012
    Sacramento, CA
    Default
    What works best is smooth, mild transitions. So in stock cars, we actually run flat hoods .. well sorta flat ... and make them angle up from the nose to a higher point on the windshield.
    I would suggest using a Chevelle style cowl scoop ... except make your own ... and make the transition start all the way at the leading edge (or near it) of the hood and have it rise & separate from the hood gradually over the length of the hood.
    In other words, go from 0" split at the leading edge to 3-6" split (from hood scoop to hood) at the point you contact the windshield. Make the top of the scoop flat, smooth & the rise very gentle.
    Ron Sutton
  18. #538
    Dec 2013
    Default
    One of the weird subjects in aerodynamics that is brought up from time to time:
    http://www.racecar-engineering.com/a...s-reduce-drag/
  19. #539
    Nov 2012
    Sacramento, CA
    Default
    Quote Originally Posted by HellPhish89 View Post
    I have quite a bit if experience with this. The writer of the story missed four major points:
    1. What the real goal is.
    2. How it works.
    3. Size matters.
    4. The exceptions of when it doesn't work.
    I'm typing this answer on my phone, so I'm going to be brief.
    1. The goal is have the airflow follow a curved surfaced & stay attached to the surface. This creates force ... lift or downforce depending on the surface orientation.
    2. The key to achieving this is turn the airflow into vortices, at the leading surface of the curve we're targeting. Vortices cause the airflow to follow a curved surface ... when the typical turbulent airflow would not. It would become detached in the worst way ... tumbling & roiling, which causes drag with no lift or downforce benefit.
    3. The size of curve & volume of airflow matters. Larger curves & volumes of airflow need larger vortex generators to convert the airflow into the optimum size & quantity of vortices. Smaller curved shapes need smaller vortex generators. The 2 trailing, angled edges of the hex shaped dimple on a golf ball are appropriately sized vortex generators for optimum airflow attachment. A slightly larger size works well on the floors on intake ports. Car roofs & curved body shapes require larger vortex generators.
    4. There are situations where adding vortex generators have no effect. This is when there is no significant airflow attach to start with. A prime example is the nose of a car. The nose is punching such a forceful hole into the air ... that a bow wave is created ... forcing the air out & around the nose of the car. Farther down the car, the airflow reconnects with the body. How far depends on the size of the bow wave crested by nose shape & speed. For this reason if we put vortex generators on the leading edge of the nose, they are ineffective.
    Does that provide some clarity?
    Ron Sutton
    Ron Sutton
  20. #540
    Dec 2013
    Default
    Interesting. Using it on the underside of a wing or even splitter would possibly allow for more aggressive angles while mitigating the risk of detachment? Also, there is a direct relation between curve, vortex required, and size/shape of dimple required?
    Further, if shape matters, wouldnt a tear drop shaped dimple be closest to ideal?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
