      Mar 2013
      Pittsburgh, PA
      G Body/B Body Tall spindles with 12 inch rotors 5 x 4 3/4 bolt pattern & calipers
      G Body/B Body Tall spindles with 12 inch rotors 5 x 4 3/4 bolt pattern & Police Caprice calipers an pads ,Buick Regal, Malibu, Grand Prix, Cutlass, Monte Carlo, Elcamino
      These are the tall spindles that you need to convert a 1968-1972 Chevelle/GM A-body or a 1978-1988 Monte Carlo/GM G-body to 12-inch brakes using Hotchkis, Global West or similar tubular upper control arms for tall spindles. They accept the G-body 9/16" lower ball joint. All parts are used but serviceable. Consider the time and money that you would invest to locate, remove, and prepare these parts for installation.
      Includes:
      Spindles part numbers 369055 LH and 369056 RH (cleaned, media-blasted, and painted cast iron gray)
      Dust shields
      Spindle nuts, spindle washers, rotor dust caps
      Brake hose mounting brackets
      Brake hose mounting bracket bolts and brake hose retaining clips
      Calipers part numbers 18007150 LH and 18007151 RH and caliper bolts
      Thanks RW
      Thanks RW $299
      *********************Four One Two 638-2639**********************
      Mar 2013
      Pittsburgh, PA
      bump bump
      Pretty sure they will also fit the 2nd gen Fbody
      Mar 2013
      Pittsburgh, PA
      They where on my G Body, the rest is up to who ever wants to buy them!!
      Mar 2013
      Pittsburgh, PA
      bump bump bump
      Mar 2013
      Pittsburgh, PA
      revised revised revised
