Installing
the T56 kit by Tyler Beauregard
Click
here for a FAQ if you have any questions after reading this
These
instructions are starting with the transmission removed.
- Press
new pilot bearing into rear of crank shaft (picture #1)
- Using
new hardware, install flywheel to crank shaft & torque bolts to
90 lb-ft. (note picture #2)
- Clean
flywheel surfacing with lacquer thinner.
- Using
a clutch alignment tool, install clutch (noting engine side)[pic #3]
and pressure plate, installing the new hardware and torquing the
bolts. [pic4]
- Remove
the 8 bolts that retain the bellhousing to the T56 case.
NOTE:
now is a good time to see if your starter will clear the bellhousing.
- With
bellhousing in hand, put 1 bolt through the hole indicated (arrow)
[pic5], as there is no clearance to put bolt in with bellhousing on
the block.
- Hoist
bellhousing to the back of the block, and fit over dowel pins.
- Now
start all 6 bellhousing to block bolts by hand, and then remove
clutch alignment tool.
- Tighten
all 6 bellhousing bolts.
NOTE:
is actuator bracket is attached to bellhousing, remove it at this time
by un-doing the 2 nuts all the way, and sliding the bracket rearwards
off the 2 studs.
T56
case prep
- Install
supplied trans mount with instructions and hardware provided.
- Place
gearbox in neutral, and remove the shifter stub by taking out the 4
bolts to the tailshaft.
- Cover
the rectangular hole of the shifter plate with cardboard, and tape
down to prevent debris from entering.
- Check
to make sure the case has 2 dowel pins in it (one each side).
- Using
a transmission jack and safety strap, raise transmission into
position. [pic 6]
- Working
slowly, raise T56 to bellhousing, and slide input shaft into clutch,
and into the dowel pin holes.
NOTE:
if you are converting from an automatic trans, do not start all the case
to bellhousing bolts, as you will be removing the tranny in a few steps.
- Start
the 8 case to bellhousing bolts by hand, and tighten in increments
on pass and driver side to "draw" case to the bellhousing.
- Support
the tailshaft after the trans mount. [pic 7]
- Using
a scribe, mark off the hole for the shifter on the tunnel. Keep in
mind that the hole will need to be 1" wider and longer than
base.
Use
the old carpenters rule: Measure twice, cut once
- Remove
the driver's seat, and the carpet, to gain access to the
transmission tunnel.
- Remove
the bolts from the case, and remove the tranny.
- Using
a cutoff wheel or saw, cut the hole for shifter.
- Reinstall
the T56 case to the bellhousing, installing all 8 bolts, and tighten
them as mentioned earlier.
- With
tailshaft supported before the poly mount, install crossmember.
- This
is easiest to do by sliding the two sides into the frame rails, and
tapping each side with a hammer until it is lined up with the holes.
- Start
the 2 bolts from the poly mount, to the crossmember by hand.
Do not tighten.
- With
the holes in the frame rails lined up with the holes in the
crossmember, use a deep socket and 3" extension, to insert
bolts. Do this by
placing a bolt into the deep socket, and push it through the frame
and into the crossmember.
- Holding
the bolt in place with the socket and extension, place the
lockwasher over the bolt, and then thread the nut onto the bolt.
- Repeat
for remaining 3 bolts, and then tighten them diagonally, followed by
the 2 mount to crossmember bolts.
The
T56 is now installed in the car. You
can remove the support devices.
- Remove
the cardboard cover, and install a quality aftermarket shifter, with
the instructions that are included with.
(We recommend Pro 5.0, and Hurst)
- A
new driveshaft will need to be made using new u joints, and
measuring 46-1/2" from center of U-joint to center of U-joint.
- Install
driveshaft into tail, and then to rear-end tightening the u-bolts
snugly.
- Remove
fill plug on driver's side of T56 case by using a 3/8" drive
ratchet.
- Purchase
a fluid pump from the local auto parts store to fill tranny.
- Fill
with quality synthetic fluid, such as Redline, or AmsOil, until the
fluid seeps out of plug.
- Reinstall
fill plug and tighten.
- Snap
clutch fork onto throughout bearing on pressure plate.
The
following instructions are to be done in the engine compartment.
Hydraulic
bracket install:
- Remove
brake master cylinder, hard brake lines, and vacuum booster from
firewall.
If
you are converting from an auto to manual, you must knock out the
1" plug in the firewall. This
is found by placing the clutch bracket over the booster studs (4) and
looking through the oval portion of the angled bracket (this should be
on the bottom.)
- Manual
cars should remove the Z bar, and all related clutch pieces at this
time.
- Slide
clutch bracket over booster studs (4) with angled portion facing
down.
- Start
2 nuts diagonal from each other by hand, but do not tighten with a
wrench.
Underdash
pedal install:
This
is easiest with the drivers seat removed.
These
steps only apply to automatic cars
- Remove
clip from brake pedal, remove brake switch, and slide pedal out from
driver's side.
You
will need to purchase a clutch/brake pedal setup from a Camaro
wherehouse. I use Classic
Industries at 1-800-854-1280. Part
numbers are as follows:
Clutch/brake
pedal:
includes 2 pedals, 4 bushings and new retainer clip
C681----
$65.50 set
Manual
trans brake pedal pad:
pad for disc brake equipped cars
C62----
$10.95
Manual
trans clutch pedal pad:
pad for clutch pedal
K981----
$4.95
Pedal
pad trim: Metal
trim surrounding pads (x2)
K911----$4.95
each (x2)
- Assemble
the new pedals with the supplied bushings, so they are ready to hang
under the dash.
- Slide
the pedals in, brake first, from driver's side to pass side, and
secure with new retaining clip.
Hydraulic
actuator installation
- Under
the car, install actuator bracket onto studs.
- Now
remove plastic shipping strap from the actuator rod, and insert into
clutch fork pocket.
- On
braided hose is a clip, slide the clip over the top stud on the
bracket, and start the 2 nuts.
- Tighten
snugly (not too tight, it is plastic) and put actuator rod up
through the engine compartment.
- Now
slide actuator pushrod through the oval hole in the bracket, and
past the fire wall toward the pedals.
- Secure
actuator to bracket with the 2 bolts provided.
- Under
dash, secure rod end to hole on clutch pedal with the special bolt
and nut.
- Test
clutch travel with your hand on the pedal.
It should go smoothly with no binding or sweeping.
If it does not, STOP.
Check the installation, and try again.
- Clutch
actuator is now set up.
Finishing
the installation:
- Mount
clutch reservoir to firewall with two screws.
- Remove
the two nuts on the hydraulic bracket, and install brake booster
with the 4 nuts. Tighten.
- Reinstall
brake master cylinder to booster, and all removed brake lines.
- Bleed
brakes. Fill brake
master with DOT 4 brake fluid, and bleed the fittings at each wheel
in this order:
Passenger
rear, drivers rear, passenger front, driver front.
Be sure to check fluid level often.
When the pedal is firm top off fluid and secure cover on brake
master.
- Reinstall
carpet, cutting around the shifter base with a knife.
- Reinstall
drivers seat.
- Install
shift boot to floor, then shift knob and jamb nut.
- TAKE
OUT FOR A SPIN!!!!!
NOTE:
I do not use the reverse lock out solenoid due to the fact that
it can be overridden under 5mph. I
also use an electric speedometer, instead of the expensive tail shaft
conversion, or box converter. These
wiring tasks are up to you on how they will be taken care of.
Click
