Results 1 to 20 of 75
02-27-2013 #1
SPC Adjustable uppers Installed wrong. Snapped on street tires in the canyons.
This incident happened up near the rock store in Malibu.I was driving down the canyon when all of a sudden I felt a snap in the front end, and I could feel the wheel pull hard to the right. I could hear the tire squealing from the camber of the wheel. I was on very windy roads and was lucky enough to be able to steer it just off to the right into a pull off. 10 seconds earlier or later I would have ended up in the Canyon or into the side of the canyon.
I thought at first it may be a flat tire but quickly spotted the snapped plate on the SPC upper control arm. The car was exceptionally balanced and sorted before this incident and I would like to continue using SPC products but not at the cost of my life. I just wanted to warn others because I know many of us are running these control arms....
The car was exceptionally dialed in and sorted before this, and I'd like to continue using the adjustable uppers, but we will see how SPC handles the situation. I am running QA1 coilovers, hotchkiss sway bar, leafs, subframe connectors, guldstrand mod, wilwood W6 manual brakes.
Those with SPC arms, check them out before any spirited driving. Guldstrand told me that if you're not driving off the track or breaking something you're not going fast enough. I guess he was right but not at the cost of my life! I haven't had many close calls in this car but I have decided that its time to cage it and invest in some safety mods.
Be safe all!
Some artsy photos.
