Anvil Auto
JRI Shocks
Spoilers By Randy
Ricks Hot Rod Shop
Art Morrison
V8 TV
Advertising
SPAGHETTI ENGINEERING
Detoit Speed & Engineering
Second Skin Audio
Wheel Werkes
Muscle Rodz
CJ Pony Parts
Chris Alston's Chassisworks
Mayhem Customs
XP Motorsports
Earls Plumbing
Hermance Design
Paradise Road rod & Custom
BFGoodrich Tires
Inland Empire Driveline
Newstalgia Wheel
Anvil Auto
Boom Mat
Speed Inc
Eddie Motorsports
Brown Line Metalworks
Centerforce Clutches
Modern Classic Interiors
No Limit Engineering
Optima Betteries
Texas Speed & Performance
BMR Fabrication.
SRD Parts
Global West Suspension
Forgeline Wheels
Weld Racing
Boze Wheels
Roadster Shop
G-Force Design Concepts
American Powertrain
Screamin’ Performance
Vintage Air
Total Cost Involved
L & H Kustoms
Auto Rod Technologies
Powertrain Control Solutions
Rushforth Wheels
Baer Brakes
Motorstate Distributing
Nitro Active
Baileigh Industrial
RnD Fabrication
Smitty's Custom Automotive
Mike Norris Motorsports
B&B Classics Inc.
Fesler Built
The Shop LLC
Twist Machine
Bowler Performance Transmissions
New Vintage USA
JCG Restoration & Customs
Scott's Hot Rod Shop
Speedtech Performance
Schwartz Performance
Classic Custom Consoles
Matt's Classic Bowties
Savitske Classic & Custom
Cone Engineering
Design Engineering
Wilwood Engineering
Fletcher's Custom & Speed
Bulldawg Musclecars
Modo Innovations
Holley EFI
Ring Brothers
Heidts Hot Rod & Muscle Car Parts
Billet Specialties
Marquez Design and Fabrication
Cipher Auto
Ron Francis Wiring
Intro Wheels
bonspeed wheels
Comp Cams
Restomod Air
East Bay Muscle Cars
Prolific Designs LLC
Classic Nova & Perfromance
UMI Performance
Speartech Fuel Injection
HoodPins.net
Route 66 Motorsports
CJ Pony Parts
aToolCrib.com
Musclecar Place
II Much Fabrication
FocuzTech Performance
MagnaFlow
All Speed Customs
Clayton Machine
RideTech.com
Forula 43
Mast Motorsports
Morris Classic Concepts
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Jun 2010
    Santa Rosa Valley, California
    Default oil cooler baypass thermostat
    just put a oil cooler with fan in my car do i need to run a fluid control thermostat?
    Jun 2010
    Austin, TX
    Default
    I'm adding a cooler myself and searched the site to find a few threads about thermostats before I bought. I'm adding an Earl's thermostat oil filter adapter to my car/ Some good points were brought up about keeping oil at temp and even extreme cold causing freezing in the cooler itself. Do a forum search and you'll probably find what you need.
    Jun 2010
    Default
    thanks i will search, but if thats the reason i live in cali and it hardly freezes here....
    Chicago suburbs
    Default
    Run a stat. The purpose is to get your oil up to temp quicker and keep it there. Running without a oil or coolant stat is usually a bad idea on the street. Fluid temps that are too cold are bad for a motor- even in cali
    Dec 2009
    Default
    Quote Originally Posted by another69 View Post
    All that, plus you need to get your oil up to temp to evap condensation and keep your oil doing what it's supposed to do...
    Ron in SoCal
    69 Camaro in progress
    Used to be known as flash911
    Loganville, GA
    Default
    I run a stat on my oil cooler, the Earls one. Even here in Georgia, it takes a bit to get the oil temp up. The highest the oil temp ever reached was about 190 degrees, which is about where the thermostat opens (Earls lists that is starts opening at 160, fully open at 180). I mostly autocrossed and drove on the street with the car. This was in the El Camino, engine is now in the Camaro with the cooler setup. Note, my oil cooler is probably a bit bigger than it needs to be, contributing to the lower oil temps.
    Randy Pajer
    79 GMC C35 Dually - truck stuff
    81 Camaro - CP car
    99 Bonneville SLE - DD
    Nor Cal
    Default
    A few of us run the Mocal unit (Gitter Dun, sik68, and myself). Vegas69 runs the Earl's unit. I remember he researched and supposedly the Earl's unit controls 100% of the oil flow whereas the Mocal and Cantons allow 10-15% of oil to bypass at all times....
    Jun 2010
    Georgia
    Default
    I personally would run a thermostat, otherwise as mentioned above you aren't getting the oil up to temp, which is harder on the engine.
    www.RnDFabrication.com
    Custom Radiators, Valve Covers and Overflow Tanks
    Project Sabre
    Jan 2007
    Middlebury CT
    Default
    I'm running the filter adapter style with a built in bypass when the oil hits 180F. Now i live in ct and have have cold spring and falls i planned on using some sheet aluminum to block the core to help control the cooling if needed. In the summer months under some heavy loads i was hitting 240F+. I just did a track day and with the outside temps of 60F my car saw oil temps of 200F - 210F it was totally happy. I'm running a setrab oil cooler and its really nicely built.
    ________________
    Nick S.
    Gold/Gray 1967 Camaro
    Henderson,NV
    Default
    Even with my Earls T stat, my car will run to cool in the colder months. It's always run on the cool side but it's worse now. I haven't confirmed that the t stat is or isn't flowing before 185 degrees. I do know that it's designed to prevent thermal shock to the cooler when the t stat opens. That means the feed side to the cooler is open so the oil keeps some temperature in it. The return side is closed but my theory is there is some radiant cooling. I may end up building a shroud for the cold months. You really only want a cooler that is just big enough to do the job. Since I have a snarling big block that creates big heat, I put in a LARGE cooler purposely and wanted to error on the large side since my problem was on the road course.
    Todd
    Los Angeles
    Default
    Big power = big heat = big problems = more heat management.
    The Mocal thermostats do bypass some oil to the cooler at all times. Hence, on mine the oil temperatures are too cold for most street conditions. 180* on a hot day, 140-150* on colder days with the 202*F thermostat. That's too cold. The oil needs to be hot in order to burn off condensation and to have the additive packages work correctly.
    What I'm likely to do is eliminate the thermostat and put in a three-way valve. For street drivng it will bypass the cooler, but for track days all oil will go through cooler. It will require manually operating the valve periodically to have fresh oil circulate through the cooler.
    Carl Casanova's 1968 Camaro
    Jun 2010
    Default
    Thanks guys...where is your oil temp sensor located on your engine? my oil temp town driving is about 190 the fan comes on and keeps it at 185 also my cooler in mounted on the left side inner fender hump inside the engine just behind the head lights.
    I really dont think i need the thermostat for my application
    Nor Cal
    Default
    I was on the fence of where to place my oil temp sensor -- and after researching the ideas were very mixed I found -- I decided to mount mine POST-cooler so I know how well the cooler is working. I used this Joe's Racing part.
    http://www.joesracing.com/index.php?...product_id=752
    Others said they wanted to know the hottest oil that was reaching the engine so mounted it pre-cooler, often on the port off the remote oil filter adapter.
    Jun 2010
    Default
    so on the line i see....my filter is on the rad core and using a Canton i put my sensor there so its on the line coming from the engine then it goes to the cooler
    Henderson,NV
    Default
    You left a important piece of information out. ha ha If it's not hanging in the breeze, it's not nearly as important.
    I do agree with Dave, post cooler is where many recommend as that's what most of your internals see. Mines in the pan and my opinion is that any oil temp gauge is better than none! I'm not sure why Dave has one as he thinks pegging it is part of the fun. ha ha
    Todd
    Nor Cal
    Default
    haha yeah I got a little excited down there didn't I.... dammit.
    Oct 2007
    Atlanta
    Default
    Not to hijack at all, but I have a question. I have a new Setrab cooler and a remote filter mount ready to go in, and am going to get the bypass as well. My question is where should I put the bypass? Closest to the engine as it comes out of the filter adapter or up front near the cooler? I was thinking back by the engine to keep the pressure loss to a minimum when it's not going up to the cooler but I don't know that it matters much. Also, should it go from engine to filter to bypass to cooler and back to engine or what is the right order? Thanks a lot. I need to sketch it all out before I order the AN hoses and fittings.
    Oct 2007
    Atlanta
    Default
    Nevermind, I figured it out.
    Sep 2008
    JACKSONVILLE, FLORIDA
    Default
    I use a marine billet thermostat. They come apart and are easy to clean.
    http://www.hardin-marine.com/p-14580...12-degree.aspx
    Craig Scholl
    CJD Automotive, LLC
    Jacksonville, Florida
    904-400-1802
    www.cjdautomotive.com
    info@cjdautomotive.com
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
