1 Attachment(s)
G Body/B Body Tall spindles with 12 inch rotors 5 x 4 3/4 bolt pattern & calipers
G Body/B Body Tall spindles with 12 inch rotors 5 x 4 3/4 bolt pattern & Police Caprice calipers an pads ,Buick Regal, Malibu, Grand Prix, Cutlass, Monte Carlo, Elcamino
These are the tall spindles that you need to convert a 1968-1972 Chevelle/GM A-body or a 1978-1988 Monte Carlo/GM G-body to 12-inch brakes using Hotchkis, Global West or similar tubular upper control arms for tall spindles. They accept the G-body 9/16" lower ball joint. All parts are used but serviceable. Consider the time and money that you would invest to locate, remove, and prepare these parts for installation.
Includes:
Spindles part numbers 369055 LH and 369056 RH (cleaned, media-blasted, and painted cast iron gray)
Dust shields
Spindle nuts, spindle washers, rotor dust caps
Brake hose mounting brackets
Brake hose mounting bracket bolts and brake hose retaining clips
Calipers part numbers 18007150 LH and 18007151 RH and caliper bolts
Thanks RW
Thanks RW $299
*********************Four One Two 638-2639**********************
Attachment 78614
