If this is your first visit, be sure to check out the FAQ by clicking the link above. You will have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Go Back   Pro-Touring.com > General Discussion > Project Updates
RegisterPT Garage FAQ Members List Calendar Mark Forums Read Home Page Online Store         Chat Room
Edelbrock December
Reply
Thread Tools Display Modes
Old 08-26-2004, 06:52 AM
astroracer's Avatar
astroracer astroracer is offline
Trader Rating: (0)
Default "Bad Ast" Frame and Suspension Design
I've gotten a lot done in the last couple of weeks. Namely just verifying dimensions on hard parts and virtual geometry.
I've replaced the Astro van UCA Cross Shaft with one from a "G" Body, gotten a roughly modeled 2" dropped Astro Spindle in place and started designing control arms.
As you can see I've got a good start on the frame rails, front and back, with more work to do for crossmembers, engine and body mounts.
The rear frame rails are the tough nuts... I talked to a company in Detroit about mandrel bending them but, at $295.00 dollars EACH... PLUS material, it isn't going to happen. Cutting and welding isn't an option so I am talking to a couple of guys who have CNC Plasma and laser cutters about doing all of my brackets and the rails that way. Making .DXF files isn't a problem...
__________________
Mark:
"Bad Ast" Astro Van. Heat, beat, file to fit, paint to match...
This is my Fotki album...
http://astroracer.fotki.com/
  #2
Old 08-26-2004, 07:33 AM
Matt@RFR's Avatar
Matt@RFR Matt@RFR is offline
Trader Rating: (0)
Default
Have you made any progress with mandrel bending that rect tube?
Nevermind...I went straight to the drawings!!
__________________
-Matt
  #3
Old 08-26-2004, 08:50 AM
jakespeeds's Avatar
jakespeeds jakespeeds is offline
Trader Rating: (0)
Default
Chris Alston of Alston chassis can take your drawings and make rails right from them. He has a big frame bending machine that is CNC operated.
Jake
  #4
Old 08-27-2004, 10:32 AM
Salt Racer's Avatar
Salt Racer Salt Racer is offline
Trader Rating: (0)
Default
Looks good Mark.
Just curious...What is your UCA/LCA length ratio? I've never messed with Astro spindles so I don't know what kind of UCA/LCA ratio those spindles prefer for good RC migration, but LCAs seem to be bit short on your modeling.
K
  #5
Old 08-30-2004, 05:18 AM
astroracer's Avatar
Trader Rating: (0)
Default
K,
The upper arm is 8.52" long and the lower is 11.85". That is a 1.39:1 ratio.
The roll center at design is 1.99" above ground
At full Jounce it is -1.47" below ground and
At full Rebound it is 6.69" above ground.
This works out to a little over 8 inches of RC migration throughout suspension travel. I wasn't real concerned with this as I will probably limit total suspension travel to around 5" or less during shock/spring tuning. Is there a target I should be looking to hit?
Running the geometry through a motion program gives me 2.61 degrees of Camber Gain at a full wheel travel of 3.75 inches in Jounce.
Camber Loss is 1.2 degrees in Rebound.
I utilized Corvette Z06 geometry points and wheel center travels as a start and then revised the Upper and Lower Control Arm pivot points to better match the C5 Corvette Steering Rack for bump steer and ackerman. I did narrow up the LCA pivot points considerably to do this. I have less then 3 degrees of toe in at full Jounce and around 3 1/2 degress at full Rebound. With my planned travel limits I was pretty happy with these numbers also.
Thanks for the input and let me know how my numbers sound to you...
Mark
__________________
Mark:
  #6
Old 08-30-2004, 07:40 AM
Salt Racer's Avatar
Trader Rating: (0)
Default
Mark,
You have a PM.
  #7
Old 08-30-2004, 09:35 PM
BlazerSpeed's Avatar
BlazerSpeed BlazerSpeed is offline
Trader Rating: (0)
Default Kick Astro!!
damn mark drawings look better everytime I see 'em. I remember what you were planning on doing for body/suspension, but what were your plans for the interior?
DEREK
  #8
Old 08-31-2004, 03:46 AM
astroracer's Avatar
Trader Rating: (0)
Default
Thanks Derek!
I've got some ideas rolling around in my head for the interior stuff but I haven't really thought about it too much. I've still got a lot of design issues with the front suspension so, until I get those worked out, I'm not going to worry about the rest of it....
I do have a pair of Neon buckets that I may use or I may go with a full set of Fiero seats a buddy can get for me. Resculpting the dash is a probability with all aftermarket gauges and what not...
Mark
__________________
Mark:
  #9
Old 09-02-2004, 07:34 AM
astroracer's Avatar
Trader Rating: (0)
Default Thank You Salt Racer!!!
A big thank you to Salt Racer for his help in getting my front suspension optimized. He helped me with a lot of input on what I needed to achieve with all of my settings. I spent a lot of time on the initial design but, without any clear goals in mind as far as bump steer and roll center migration, I was leaving a lot of it to chance. With his guidance I've relocated the upper and lower control arm points and pushed the brake corner farther outboard for a deeper offset rim. We both feel this will be a killer set up and should handle very well... Which is what you want it to do, right? Thanks again Katz...
This is what I ended up with.
Initial settings:
Track = 32.24
Wheel mounting face = 34.24
Rim = 10" wide with 7" B.S. (2.00" offset)
275/40x17 tire.
Scrub Radius = 1.80"
Side scrub at 3" dive = .07"
Anti-Dive = 51.2%
SVSA Length = 98.4"
Bump Steer @ 3" Dive = 0.00 deg.
Bump Steer @ 3" Rise = 0.08 deg. (never see it)
R/C height @ design = 1.31"
R/C hgt in left turn (3 deg Roll/10.55 deg Steer) =1.30"
R/C migration in left turn (3 deg Roll/10.55 deg Steer) = 0.23" from Center
R/C migration in right turn (3 deg Roll/10.55 deg Steer) = 0.23" from Center
R/C in Off Camber Right turn ( 3 deg Roll Left/ 10.55 deg Steer Right) = 3.33" from Center.
R/C in Off Camber Left turn ( 3 deg Roll Right/ 10.55 deg Steer Left) = 3.33" from Center.
Bump steer and Roll Center Migration are pretty important. This should be a very stable and predictable suspension.
Mark
__________________
Mark:
  #10
Old 09-02-2004, 11:20 AM
airrj1's Avatar
airrj1 airrj1 is offline
Trader Rating: (0)
Default
Mark,
Very cool. I understand half of what you posted, but I am catching more of it everyday. I am hoping to work on a custom suspension in Pro/E this winter. I'll have to hit you up for some tips. :icon996:
__________________
R.J.
  #11
Old 09-07-2004, 03:48 AM
astroracer's Avatar
Trader Rating: (0)
Default
Quote:
Originally Posted by airrj1
Mark,
No problem... Ask away...
I was pretty busy this weekend redesigning the whole front suspension to the new points Katz helped me out with... Here are a few screen shots of what I've got now...
This is a bottom view
Front View...
Front Iso View of the new Control Arms
And a view of the complete corner... Arms, Shock, frame and tire/wheel.
__________________
Mark:
  #12
Old 09-07-2004, 03:53 AM
astroracer's Avatar
Trader Rating: (0)
Default Bonspeed Wheels
This is a section I cut through the brake corner, tire and wheel. I sent this to Bill at Bonspeed to help him develope the front rims for "Bad Ast".
Even though I am using mostly stock Corvette parts I still wanted to verify Caliper to rim Clearances.
__________________
Mark:
  #13
Old 09-07-2004, 05:47 AM
Salt Racer's Avatar
Trader Rating: (0)
Default
Looks good Mark. Good call on checking caliper/spoke clearance with the manufacturer.
Good job!
  #14
Old 09-07-2004, 07:11 AM
astroracer's Avatar
Trader Rating: (0)
Default
Thanks K...
After moving the Rack up last Thursday I re-optimized everything Friday and this suspension is ready to go now. I still have zero bump. The R/C actually moves inboard .31 inches @ 3 degrees Roll & 10 degrees Steer! And the outer tierod has plenty of clearance to the rim.
Anti-Dive is 51% and the Ackerman angles are near perfect... (.05 degrees of error at full steer...). Thanks again for all of your help. I still have a few things to work out but I hope to start developing welding fixtures in a week or so...
Mark
__________________
Mark:
  #15
Old 09-10-2004, 02:33 PM
TurboLark TurboLark is offline
Trader Rating: (0)
Default
What program are you using for that? Solidworks? Is it too big to email?? :D
__________________
1965 Buick Skylark
SBC race engine parts for sale - see here --- > http://www.pro-touring.com/forum/showthread.php?t=41513
  #16
Old 09-11-2004, 05:26 PM
astroracer's Avatar
Trader Rating: (0)
Default
It's not solidworks and it's way to big to email...
I have a beta version of Unigraphics V18. It's out of date now but it does what I need it to do so I keep it loaded. The big problem with it is it's NOT very user friendly. Ive been running UG since '92 so I am pretty proficient with it but anybody trying to learn it without training is not going to do well... Sorry
Mark
__________________
Mark:
  #17
Old 09-11-2004, 05:57 PM
astroracer's Avatar
Trader Rating: (0)
Default Re-developed the points one more time...
Katz (Salt Racer) gave me some more direction friday concerning the Anti-Dive and Side View Swing Arm (SVSA) Length. I've re-developed all of the points and this is where I'm at. I think we've covered everything right Katz? Look this over one more time and let me know if you see anything else...
A few things I did while reworking the points was to bring the LCA pivot points parallel to ground AND Center of car and I also brought the UCA pivots in parallel to center of car.
I did another major move of the Steering Rack also. I moved it and the outer Tierod Point 1" rearward in car to gain more clearance to the rim.
Initial settings: (Specs in Black did not change)
Track = 32.24
275/40x17 tire.
Anti-Dive = 26.8%
SVSA Length = 97.7"
Bump Steer @ 3" Dive = -0.008" This is Bump out which is better then bump in. It actually starts bumping out (-0.001) @ 1.50" of Dive.
Bump Steer @ 3" Rise = 0.003"
R/C height @ design = 1.68"
R/C hgt in left turn (3 deg Roll/10.0 deg Steer) =1.66"
R/C migration in left turn (3 deg Roll/10.0 deg Steer) = 0.04" from Center
R/C migration in right turn (3 deg Roll/10.0 deg Steer) = 0.04" from Center
Outside tire Camber Gain in left turn (3 deg Roll/10.0 deg Steer) = -.41 degs
This suspension design is a far cry from the Corvette points I started out with... The Corvette doesn't even come close to pulling down these numbers... I just hope it works as well under a vehicle as it looks on paper...
__________________
Mark:
  #18
Old 09-13-2004, 05:38 AM
Salt Racer's Avatar
Trader Rating: (0)
Default
Mark,
It looks good to me. If anything, I'd try 10~30" longer FVSA and see if it decreases side scrub. If not, set in -1.0~-1.5* static camber and you're good to go.
  #19
Old 09-13-2004, 01:04 PM
astroracer's Avatar
Trader Rating: (0)
Default
Katz,
I didn't update the Side Scrub in my last post... It should be 0.04 @ 3" of Dive. How does that sound?
Mark
__________________
Mark:
  #20
Old 09-13-2004, 01:31 PM
Salt Racer's Avatar
Trader Rating: (0)
Default
That's pretty damn good. Also, be sure to check scrub at every 0.5" suspension travel - both jounce and rebound. Typically the curve is not linear. More than likely the number will increase quite a bit when you go over 2" travel on rebound, but don't worry about that.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
L & H Kustoms
Paradise Road rod & Custom
Musclecar Place
Boyd Coddington Wheels
Trick Flow
Hurst Driveline Conversions
Compstar
Hydratech Braking
Mast Motorsports
Newstalgia Wheel
Fuelairspark.com
Arizen Racing Sports
Scoggin-Dickey Parts Center
Eddie Motorsports
Cone Engineering
Empire Morpars
FocuzTech Performance
bonspeed wheels
Finch Hot Rod Restorations
Driverz Inc.
Road Killer Kustoms
Mike Norris Motorsports
KEISLER ENGINEERING
Allstar Performance
HoodPins.net
Vintage Air
Rushforth Wheels
Second Skin Audio
Exotic Car Transport
Twist Machine
Detoit Speed & Engineering
Hood-Latches.com
GP Superstore
Time Machines
Marquez Design and Fabrication
Bowler Transmissions
Global West Suspension
Ride Tech
Comp Cams
Muscle Rodz
Fesler Built
Belltech Musclecar
Clayton Machine
Edelbrock
Art Morrison
Modo Innovations
Total Cost Involved
Hellwig Products
Inland Empire Driveline
Savitske Classic & Custom
Deeds Performance
MagnaFlow
Route 66 Motorsports
Mikes Custom Cars
GMR
Forgeline Wheels
Hermance Design
American Autowire
ProdigyCustoms.com
Schwartz Performance
Fletcher's Custom & Speed
Pro-Touring F-Body.com
Intro Wheels
Redline Oil
Recovery Room
Motorstate Distributing
Wilwood Engineering
Ron Davis Radiators
Southern Performance Sytems
Boze Wheels
Anvil Auto
Electric Life
Keith Craft Motorsports
MuscleRides.com
JCG Restoration & Customs
Speed Inc
Wheel Works
Nitro Active
Optima Batteries
Screamin Performance
BMR Fabrication.
Ricks Hot Rod Shop
V8 TV
Advertising
Morris Classic Concepts
Jakes Rod Shop
Baer Brakes
Summit Racing
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2010 Pro-Touring.com / G-Machines.com
