If this is your first visit, be sure to check out the FAQ by clicking the link above. You will have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Go Back   Pro-Touring.com > The Engine Section > The LSX Forum / [Ford & Mopar F.I. Sub Forum]
RegisterPT Garage FAQ Members List Calendar Mark Forums Read Home Page Online Store         Chat Room
Vintage Air
Reply
Thread Tools Display Modes
Old 11-18-2009, 03:16 PM
Chevelle LT1 Chevelle LT1 is offline
Trader Rating: (0)
Default Does Corvette LSX accessory drive fit Chevelle?
Has anyone here had firsthand experience using the Corvette accessory drive on a 1970-ish Chevelle (or other A-body), and also used A/C? I've been looking through others' photos and details, and have seen people using the Corvette accessories, but none with A/C (at least that I could confirm). Ultimately, I am trying to figure out if I would have to notch the frame for running A/C with the Corvette setup.
For what it's worth, the pertinent details for my ride include:
- 1970 Chevelle
- LQ9
- A/C (Classic Auto Air setup)
Thanks in advance for any feedback.
~ Jason
  #2
Old 11-18-2009, 03:35 PM
formula's Avatar
formula formula is offline
Trader Rating: (0)
Default
I cannot confirm, but I HIGHLY doubt it would be an issue, since both alt and A/C mount high, opposing each other.
__________________
Call me....Wes.
Fquick: http://www.fquick.com/garages/viewvehicle.php?id=796
  #3
Old 11-18-2009, 04:53 PM
1badchevelle's Avatar
1badchevelle 1badchevelle is online now
Trader Rating: (2)
Default
Check over at ls1tech. I think they do but use a aftermarket bracket for the a/c
__________________
http://www.pro-touring.com/forum/showthread.php?t=43881
  #4
Old 11-18-2009, 05:33 PM
b-man's Avatar
b-man b-man is offline
Trader Rating: (1)
Default
Quote:
The Corvette A/C compressor mounts down low on the passenger side from the factory. This requires that you notch the front crossmember in most cases, not easy to service that way.
The accessory drive picture you posted is likely equipped with the KWiK Performance mounting bracket:
http://www.kwikperf.com/lsx_ac.html
I bought one of the KWiK brackets to mount a Sanden compressor on the new LS3 that's going in my '64 Tempest, I'm using a Classic Auto Air setup.
__________________
Bart F.
'64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
'64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
'02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
  #5
Old 11-18-2009, 10:42 PM
red95t/a red95t/a is offline
Trader Rating: (0)
Default
I have done a LS2 (402) in a 69 camaro and the vette setup works great, same for the chevelles. I had to build my own bracket for the A/C almost like the one in the photo. I have also done 4 chevelles and am getting ready to do my 70 chevelle with a LS 427. I will use the vette setup as well. As far as the A/C compressors go I think it is the easiest to mount it up high, with an aftermarket compressor. I have also done them down low with a stock style compressor and you do have to notch the frame a little bit but the lines are the biggest pain to adapt. The aftermarket compressor down low is even worse to adapt. I know the chevy SSR has a really small compressor that might be easier to squeese down low, something to check into if you can find one cheap for mock-up.
  #6
Old 11-19-2009, 08:08 AM
formula's Avatar
Trader Rating: (0)
Default
I stand corrected!
__________________
Call me....Wes.
  #7
Old 11-19-2009, 10:55 AM
Trader Rating: (0)
Default
Thanks to all for the replies...I think this thread pretty sums up the confusion about what actually fits (all well-intended recommendations, of course). I was originally looking at the GMPP Corvette accessory drive kit, and didn't want to then have to add the Kwik A/C bracket as well. I think it will probably be easiest to simply stick with the Kwik setup exclusively for A/C, P/S, and alternator.
~ Jason
  #8
Old 11-20-2009, 03:50 AM
Robin Robin is offline
Trader Rating: (0)
Default
Here is a link to a video with the GMPP drive system. I can't say if it fits the chevelle but this gives a look at the completed system.
I should have had the video pause longer, also my belt routing was off.
http://videos.streetfire.net/video/L...ive_169738.htm
Good luck!
Robin
  #9
Old 11-20-2009, 06:28 AM
dhutton's Avatar
dhutton dhutton is online now
Trader Rating: (0)
Default
It would fit if you use the new BRP Hotrods mounts but they place the engine quite high and forward relative to most mounts. You are probably better off with the Kwik bracket.
Don
__________________
Don Hutton
1969 Firebird
1964 GTO
1968 Firebird
  #10
Old 11-21-2009, 12:22 PM
66ls2 66ls2 is offline
Trader Rating: (0)
Default
I run the brp mounts in a 66 with an ls2 with gto acc. drive and a sanden compresser down low on passenger side I bought the vintage air bracket to use with the gm bracket I had to modify the bracket slightly and massage the frame a little its all a pretty tight fit. If you were going to run a gm compressor it should work fine becouse it is not as long as the sanden compressor. I am running the kwik performance for my alternator very nice stuff for the money. If I did it again I would probably spend the $300.00 for the kwik bracket and mount up high to save some work.
  #11
Old 11-28-2009, 08:15 AM
93Polo 93Polo is offline
Trader Rating: (0)
Default
Andrew ran one on his '70 GTO with Edelbrock mounts.
http://www.ls1tech.com/forums/conver...ion-2-0-a.html
__________________
Lamar
00 C5 hardtop H&C 436 rwhp with an 04 Z06 Suspension
70 Chevelle SS396
  #12
Old 11-29-2009, 05:24 AM
Trader Rating: (0)
Default
I may be wrong in this case, but I have seen no photographic indication that he (Andrew) is running A/C, so I was assuming he is not. If that were the case, I wholeheartedly agree this is a slam-dunk for using the GMPP setup.
  #13
Old 11-29-2009, 09:27 AM
andrewb70's Avatar
andrewb70 andrewb70 is offline
-Moderator-
Trader Rating: (0)
Default
Quote:
Originally Posted by Chevelle LT1 View Post
I may be wrong in this case, but I have seen no photographic indication that he (Andrew) is running A/C, so I was assuming he is not. In that case, I wholeheartedly agree this is a slam-dunk for using the GMPP setup.
I am not running AC. In order to use the Corvette or the F-body AC location the frame needs to be notched.
As Bart already mentioned this the Kwik bracket is a good solution.
__________________
1970 GTO Version 2.0 in progress
V8TV feature video
Popular Hotrodding feature
Car Craft feature
"You were the gun, your voice was the trigger, your bravery was the barrel, your eyes were the bullets."
  #14
Old 02-08-2010, 04:06 PM
KENS80V KENS80V is offline
Trader Rating: (0)
Default
You can also buy the Corvette Accessory drive without the AC. Pace Performance sells it. Here is the link http://paceperformance.com/index.asp...&ProdID=248708
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Scoggin-Dickey Parts Center
Empire Morpars
Cone Engineering
Allstar Performance
Boyd Coddington Wheels
Advertising
Mast Motorsports
Detoit Speed & Engineering
Hermance Design
Speed Inc
Clayton Machine
Comp Cams
Total Cost Involved
Optima Batteries
Mike Norris Motorsports
Wheel Works
Schwartz Performance
Eddie Motorsports
Art Morrison
Savitske Classic & Custom
Compstar
Marquez Design and Fabrication
Inland Empire Driveline
Twist Machine
Anvil Auto
Recovery Room
Deeds Performance
Ron Davis Radiators
V8 TV
Finch Hot Rod Restorations
Musclecar Place
GP Superstore
Time Machines
Second Skin Audio
Ricks Hot Rod Shop
Road Killer Kustoms
Hurst Driveline Conversions
Hydratech Braking
Keith Craft Motorsports
Boze Wheels
Intro Wheels
Summit Racing
Mikes Custom Cars
Driverz Inc.
Forgeline Wheels
Southern Performance Sytems
Electric Life
Wilwood Engineering
JCG Restoration & Customs
American Autowire
Belltech Musclecar
Baer Brakes
Hood-Latches.com
Vintage Air
Pro-Touring F-Body.com
HoodPins.net
FocuzTech Performance
GMR
Ride Tech
Global West Suspension
Redline Oil
BMR Fabrication.
Trick Flow
KEISLER ENGINEERING
Fletcher's Custom & Speed
ProdigyCustoms.com
Jakes Rod Shop
Hellwig Products
Nitro Active
Arizen Racing Sports
MagnaFlow
Bowler Transmissions
Rushforth Wheels
Exotic Car Transport
Newstalgia Wheel
Screamin Performance
Morris Classic Concepts
Muscle Rodz
MuscleRides.com
Edelbrock
Modo Innovations
Paradise Road rod & Custom
Fesler Built
L & H Kustoms
Route 66 Motorsports
Motorstate Distributing
bonspeed wheels
Fuelairspark.com
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2010 Pro-Touring.com / G-Machines.com
