If this is your first visit, be sure to check out the FAQ by clicking the link above. You will have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Go Back   Pro-Touring.com > General Discussion > Project Updates
RegisterPT Garage FAQ Members List Calendar Mark Forums Read Home Page Online Store         Chat Room
Rushforth Wheels
Reply
Thread Tools Display Modes
  #141
Old 04-06-2009, 07:40 AM
Steve1968LS2's Avatar
Steve1968LS2 Steve1968LS2 is offline
-Moderator-
Trader Rating: (4)
Default
PM checking will happen today.. I haven't really been home much in the last week.. I was busy doing this:
The new ZR1 style hubs are way stronger looking than my old C5/c6 hubs. The flanges are much thicker and the extra material was added to the back of the flange. Bolts up exactly the same. It comes with studs, but I pressed them out to add ARP versions. A highly reccomended part.
Here you can see the Raceseng spindle compared to a stock C5 unit. Much stronger and more rigid, especially in the brake mounting area. There's also a degree of neg camber built in and of course the 1.25" drop.
The lower spherical bushings were easy to install. We also ditched the eccentric bolts with Pfadt's camber kit. This way under hard cornering the alignment wont change. The kit comes with serveral sets of plates.
The uppers were bolt-in so long as you have a lathe, bridgeport mill, saws-all, grinder, dremel and a host of other tools. But they are in and should work great. To be fair there was nothing wrong with the parts, just had to work to get them bolted to the 21st Century subframe.
Here's the final deal all installed:
Now for the bad news... Since the drop spindles lower the lower CA in relation to the wheel I can no longer run my 17" wheels, so I will have to get a set of 18" track wheels. Oh well. I also had to clearance the lower control arms just a touch so the 18's wont rub under very hard turning. I will also be adding some stops that Kyle at DSE reccomended to limit the turning just a touch.
The good news: Even with my car lower the lower control arms are now perfectly parralel to the gound and the car feels amazing to drive. In my opinion it has the nicest most crisp and responsive steering I've ever experiences. The ride feels about the same, but I'm sure it's a touch more harsh over hard transitions. To me it's worth it for the trade off.
__________________
See Bad Penny run the cones: http://www.youtube.com/watch?v=8GUPPIX-92U
2000 SS, 1969 LS1, and 1968 LS2 Camaros
Oh, and a 1970 Fairlane just to show I could...
See my cars here: www.fquick.com/steve1968ls2
  #142
Old 04-06-2009, 07:44 AM
-Moderator-
Trader Rating: (4)
Default
Oh, and HUGE thanks to David Pozzi for stopping by and helping with the install.. that guy is always the "smartest man in the room" in regards to this stuff. He also did a pretty good alignment using a tape measure and some straight edges...
Thanks Dave.. you're the official crew cheif of Bad Penny.. :thumbsup:
__________________
  #143
GMracer's Avatar
GMracer GMracer is offline
Trader Rating: (0)
Default
Good god Steve! looks amazing, everyday I wish I went with c5 suspension components up front and this does NOT help. But keep it up, can't wait to see some action shots.
__________________
Nick Schiffer
2001 Silverado
Currently Fabricating Full Tube Chassis
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
...back in the day
  #144
Old 04-06-2009, 08:48 AM
bwhinnen bwhinnen is offline
Trader Rating: (0)
Default
Looks great Steve! Amazing work by all involved!
  #145
Old 04-06-2009, 09:34 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Site Supporter
Trader Rating: (2)
Default
Quote:
Steve: What was the issue with the upper swivel bushings and the 21st Century frame?
__________________
Mike Kelcy - '68 Camaro with some stuff done to it.
  #146
Old 04-06-2009, 10:03 AM
-Moderator-
Trader Rating: (4)
Default
Quote:
The 21st subframe uses slotted inserts. Since these parts are used more in race applications they have a 1/2" hole in them. To use this hole 21st enlarged the holes in the factory dog bones to 1/2". The parts from Pfadt use the factory 10mm hole. BUT, there's not enough material on the Pfady dogbones to drill them out to 1/2".
So, we milled up a set of sleevs and reduced the holes in the slotted inserts to 10mm. This let us use 10mm 10.9 bolts to attach the new dogbones to the 21st frame.
__________________
  #147
Old 04-06-2009, 10:11 AM
Mkelcy's Avatar
Site Supporter
Trader Rating: (2)
Default
Thanks. It's nice having all the research and heavy lifting done by someone else.
Now, if you'd only started with stock rear frame rails I wouldn't have to think at all.
__________________
  #148
Old 04-06-2009, 10:56 AM
Payton King's Avatar
Payton King Payton King is offline
Trader Rating: (1)
Default Can I tell you....
That last pic is the money shot for sure. Looks great!
I have a number of questions for you. I will let you get caught up and I will give you a buzz.
How big of a difference in grip at the autocross from the R888 to the Kuhmos. I thought the R888's needed some heat to work.
  #149
Old 04-06-2009, 11:10 AM
barraza's Avatar
barraza barraza is offline
Trader Rating: (0)
Default
Small hijack:
Care to share some tech on what it takes to get such good closeup suspension shots?
  #150
Old 04-06-2009, 12:04 PM
dipren443's Avatar
dipren443 dipren443 is online now
Trader Rating: (0)
Default
Quote:
Originally Posted by barraza View Post
Small hijack:
Steve always has some nice shots!! What kind of gear you shooting with Steve? Lighting? Using a macro for some of these shots I assume?
__________________
Nick DiPrenda
  #151
Old 04-06-2009, 12:37 PM
Motown 454's Avatar
Motown 454 Motown 454 is offline
Trader Rating: (6)
Default
They look sweet Steve, like a work of art.
__________________
Numbers matching 53000 mile 69 Camaro SS/RS 350/300 turbo 350 4:10 12 bolt all in storage. now striped to the bone, Mini tub, Fab 9 31 spline axles Auburn pro-posi 1350 yoke w 3:50s. 454 Motown sb 600/575tq Viper 6spd. 3" Magnaflow. C6 Z51 calipers and drilled rotors all around. Air Ride G bar 4 link Rushforth Livewire 18x8 F 19x12 5" bs R. Car being done at mikescustomcars.com
Project FNQUIK http://www.pro-touring.com/forum/sho...ghlight=FNQUIK
  #152
Old 04-06-2009, 12:48 PM
-Moderator-
Trader Rating: (4)
Default
Quote:
I typically use a Canon 40D with either a 10-22 wide angle lense or my 28-135 IS lens (macro). I always shoot tech with a tripod and use a slower shutter speed so I can strobe a flash around the image. This gets rid of harsh shadows. For each of those shots I typically take 5 to 8 shots of different "exposures" which is called bracketing.
By messing with the f-stop I can "kill" the background and make it out of focus. This causes the eye to focus on the subject and not get distracted with background.
__________________
  #153
Old 04-06-2009, 06:56 PM
Kenova Kenova is offline
Trader Rating: (0)
Default
It doesn't get much more hard core than that.
Yep, I'm jealous.
Ken
__________________
  #154
Old 04-06-2009, 07:27 PM
dipren443's Avatar
Trader Rating: (0)
Default
Quote:
Yep, I'm jealous.
Ken
With ya on this Ken... Pure, unadulterated pornography right there. Surprised it wasn't censored by my work server.
__________________
Nick DiPrenda
  #155
Old 04-06-2009, 07:32 PM
-Moderator-
Trader Rating: (4)
Default
Thanks guys.. I'm very happy with the outcome.. I really can't think of anything to improve in terms of suspension outside of some further fine tuning (springs/sway bars)..
The comments I got at the autocross was that the car was very smooth and "un-dramatic"...
The only times faster than what I turned in were done by other people in my car. lol
Here's a shot Licata got. Mary would be proud that I'm looking far ahead and not "living in the moment"
__________________
  #156
Old 04-06-2009, 07:33 PM
-Moderator-
Trader Rating: (4)
Default
And some video from the mini Camaro Performers Editors Challenge
http://videos.streetfire.net/video/C...ors_645084.htm
__________________
  #157
Old 04-06-2009, 07:36 PM
joe440's Avatar
joe440 joe440 is offline
Trader Rating: (0)
Default
man, that suspension is like an art peice, the whole car looks great as always
__________________
the dart
http://www.pro-touring.com/forum/showthread.php?t=50441
Joe V.
  #158
Old 04-06-2009, 08:19 PM
LateNight72 LateNight72 is offline
Trader Rating: (1)
Default
Looks good Steve.
Let me know we you want to get rid of your old knuckles & hubs...
__________________
Todd Sickles
  #159
Old 04-06-2009, 08:31 PM
86regalss's Avatar
86regalss 86regalss is offline
Trader Rating: (0)
Default
that is awesome. Will i get in trouble for having a license plate from the wrong year on my car? I want a black plate for my black car. I guess the '80's sunrise plate would be cool also. The new ca plates are boring.
__________________
Steve C.
http://www.cardomain.com/ride/2528923
  #160
Old 04-07-2009, 07:36 AM
HectorM52's Avatar
HectorM52 HectorM52 is offline
Trader Rating: (0)
Default
Video was removed???
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
bonspeed wheels
Hydratech Braking
Ricks Hot Rod Shop
Ron Davis Radiators
Vintage Air
Savitske Classic & Custom
BMR Fabrication.
Edelbrock
American Autowire
Hood-Latches.com
Mike Norris Motorsports
Motorstate Distributing
Musclecar Place
Advertising
FocuzTech Performance
Ride Tech
Second Skin Audio
Keith Craft Motorsports
Exotic Car Transport
Trick Flow
Pro-Touring F-Body.com
Morris Classic Concepts
Mast Motorsports
V8 TV
Boze Wheels
Route 66 Motorsports
Redline Oil
Global West Suspension
Optima Batteries
Cone Engineering
Compstar
Arizen Racing Sports
Fesler Built
Bowler Transmissions
JCG Restoration & Customs
Belltech Musclecar
Summit Racing
Allstar Performance
GMR
ProdigyCustoms.com
Boyd Coddington Wheels
Wheel Works
Southern Performance Sytems
Finch Hot Rod Restorations
Total Cost Involved
Anvil Auto
Mikes Custom Cars
Twist Machine
Detoit Speed & Engineering
Inland Empire Driveline
Fletcher's Custom & Speed
Scoggin-Dickey Parts Center
KEISLER ENGINEERING
Forgeline Wheels
Hermance Design
Fuelairspark.com
MuscleRides.com
Speed Inc
Marquez Design and Fabrication
Empire Morpars
Newstalgia Wheel
Schwartz Performance
Comp Cams
GP Superstore
Hellwig Products
Time Machines
Wilwood Engineering
Deeds Performance
Nitro Active
Rushforth Wheels
Paradise Road rod & Custom
Recovery Room
Intro Wheels
Hurst Driveline Conversions
Baer Brakes
Art Morrison
Muscle Rodz
Eddie Motorsports
Modo Innovations
Screamin Performance
HoodPins.net
Driverz Inc.
MagnaFlow
Electric Life
Jakes Rod Shop
L & H Kustoms
Road Killer Kustoms
Clayton Machine
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2010 Pro-Touring.com / G-Machines.com
