If this is your first visit, be sure to check out the FAQ by clicking the link above. You will have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Go Back   Pro-Touring.com > General Discussion > Project Updates
RegisterPT Garage FAQ Members List Calendar Mark Forums Read Home Page Online Store         Chat Room
Mast Motorsports.com
Reply
Thread Tools Display Modes
Old 11-22-2007, 07:49 PM
Bruning Auto Design Bruning Auto Design is offline
Trader Rating: (0)
Default Bruning Auto Design: 70 Challenger Build - C5 suspension, SRT8 Hemi Crate motor, etc.
1970 Dodge Challenger - built by Bruning Auto Design
E-Tikit Challenger Concept: Stance is key with any build. Ultra-low ride height, maximum performance, and subtle body mods are underlying themes throughout the build.
- A Solid Foundation: We began by fabricating an elaborate tubular chassis constructed around Corvette C5 suspension and drive train components. The 5" of ground clearance at the lowest point of the car at ride height is achieved without the use of air suspension.
- Modern Muscle: Yes, It’s got a HEMI… An 800 horsepower twin-turbo charged 426 C.I.D Stroker based on the new generation 6.1L SRT-8 HEMI. One-off dual throttle body intake manifold, 321 stainless steel turbo headers and exhaust, aluminum oil pan, and new generation twin-plug HEMI valve covers are all hand-crafted originals.
- Body Mods: Subtle changes made throughout: fender openings which are moved forward 2 inches and up 1 inch; chin and deck lid spoilers; lower valance treatments; functional R/T Hood, modernized door handles; and lighting improvements.
- Industrial/Mechanical Finishes:The Challenger will live up to its “R/T” Road & Track MOPAR heritage. Show quality finishes with an emphasis on reliability and durability throughout the build. The ultimate driver that looks as good on track day as it does on display at a show.
Check out http://etikitchallenger.com for build and media details.
Thank you to our Sponsors:
* BAER Brakes : 15"two-piece rotors & forged MonoBlock 6S calipers
* Cone Engineering Inc.: Stainless Header & Exhaust Components; SEMA `08
* Rockford Racecraft: Turbos & wastegates; ceramic coatings
* Centerforce - Midway Industries: Clutch Components
* Autometer: Automotive Instruments/Gauges
* ATI Performance Products: Super Damper harmonic balancer assembly
* Ididit Inc.: E-Body Tilt Column & steering linkage
* R.C. Engineering, Inc.: High Performance Fuel Injectors
* American Autowire: Modular Wiring Harness & Accessories
* Automotive Design Engineering: Unigraphics CAD Engineering
* Mothers: Polishes, Cleaners, & Waxes
* Hot Rod Air Inc.: Air Conditioning Components
* Plum Floored Creations: 426 HEMI 6.1 Stroker - Your Source for New Hemi Swaps
* Revolution Industries: Graphic and Web Design; Print Media
* Design Engineering, Inc.: Thermal Tuning Products
* Pure Power! Incorporated: Billet Lifetime Oil Filtration Products
* Meziere Enterprises: High Performance Electric Water Pump
* Arc Audio: Sound System
Last edited by Bruning Auto Design; 03-16-2009 at 01:46 PM.. Reason: build list/sponsor update 3/16
  #2
Old 11-22-2007, 07:50 PM
Trader Rating: (0)
Default
The car was media blasted and motor & suspension is on hand and ready to go.....
The wheels and tires in this picture are not for this build. They are actually going on the Chevelle in the background.
Crate motor-
SRT 8 6.1 HEMI
370 cu in
10.3:1 compression
425 hp @ 6200 RPM
420 ft. lb torque @ 4200 RPM
forged steel crankshaft
aluminum intake
6400 rpm redline
Twin turbos will be added, but there is still a lot of research to do....
  #3
Old 11-22-2007, 07:51 PM
Trader Rating: (0)
Default
Next up was building a fixture/jig out of 60' of 2.5 x 2.5 .187 wall tubing.
All braced up and getting rid of the rot.
inner fenders going to need some "modification"
rear quarter cut out.. ride height mocked up using the donor 20" rim and tire
  #4
Old 11-22-2007, 07:52 PM
Trader Rating: (0)
Default
more...
new rear quarters...
Time to get the front & rear Corvette suspension components mocked into place....
  #5
Old 11-22-2007, 07:54 PM
Trader Rating: (0)
Default
New tires. Fronts are 19's, rears are 20's.
Cutting out the rest of the rot & making room for 12" wide 20" rims, IRS Corvette Suspenion & rear mounted transmission.
  #6
Old 11-22-2007, 07:55 PM
Trader Rating: (0)
Default
Bellhousing... Not using the corvette Torque tube.
  #7
Trader Rating: (0)
Default
More on the bellhousing/adapter combo... Not going to use the factory Corvette torque tube because of size limitations (Too bulky and would have to be shortened anyway). The adapter & carrier bearing will make it possible to use a slip yoke driveshaft instead. The bearing was purchased at a specialty race shop in Portland.
Hopefully the pics will make more sense.
Can't wait to see it with baer brakes.....
  #8
Old 11-22-2007, 07:56 PM
Trader Rating: (0)
Default
Rear Corvette C5 suspension ready for mock up...
Arms are set to factory Corvette spec. Chassis will be built from there... The front will be the same process.
  #9
Old 11-22-2007, 07:57 PM
Trader Rating: (0)
Default
Ride height is set with a nice level body line in the rear.....
  #10
Old 11-22-2007, 07:58 PM
Trader Rating: (0)
Default
Tire pics...
245/40 ZR 19's in front
335/30 ZR 20's in the rear
  #11
Old 11-22-2007, 07:59 PM
Trader Rating: (0)
Default
Can't leave anything alone.....
Daily Driver... 22" Intro's on bags.
  #12
Old 11-22-2007, 08:02 PM
Trader Rating: (0)
Default
Wheel Choices.... Coming soon. Some potential contenders..
Forgeline, DPE, & Enkreuz
  #13
Old 11-22-2007, 08:13 PM
Mr.VENGEANCE's Avatar
Mr.VENGEANCE Mr.VENGEANCE is offline
Trader Rating: (3)
Default
5 spoke addict...
nice cars..
  #14
Old 11-22-2007, 08:14 PM
Trader Rating: (0)
Default
Brakes arrived.... pics do not do justice. Beautiful!
More updates soon.....
  #15
Old 11-22-2007, 08:16 PM
Trader Rating: (0)
Default
We will debut the chassis at the Portland Rod & Custom Show & Seattle Roadster Show in February.
I will be posting more updates soon!
  #16
Old 11-22-2007, 11:52 PM
DFAuto DFAuto is offline
Trader Rating: (0)
Default
ooohh I build awesome cars I am sooo cool :P Just kidding that thing looks killer. Good luck with the build and I cant wait to see it when it is done.
__________________
Current project: 63 Chevy II 6.0l vortech supercharged on air ride She is finally back from paint prison!!!
Next project: 67 Mustang Fastback with splash of gt500
  #17
Old 11-23-2007, 05:15 AM
protouring70 protouring70 is offline
Trader Rating: (0)
Default
I have friends in the body shop business.... But how do you know what to do from here? Do you take measurements from every angle!
  #18
Old 11-23-2007, 05:29 AM
syborg tt's Avatar
syborg tt syborg tt is online now
Trader Rating: (0)
Default
car is awesome - glad to see it over here.
__________________
marty-mj Syborg Twin Turbo Project thread link
Chassis Fabrication - Competition Fabrication Interior - Recovery Room Interiors
Final Paint & Body - Kenny Davis Hot Rods Billet Hood Pins - Wilson Muscle Cars
Engine Assembly - Rockford Racecraft Transmission -Bowler Transmission
  #19
Old 11-23-2007, 08:09 AM
69camarokid's Avatar
69camarokid 69camarokid is offline
Trader Rating: (0)
Default
this car is rediculous.... just wow!
__________________
"He'll be very good..."
"No! He'll be the best... If they dont destroy him first."
69 camaro, daytona blue. LT1/T56.
CC305, 918 beehives, roller timing chaing, LT, 2.5 duals, CAI, 1.6 RR, PCM for less tune
  #20
Old 11-23-2007, 08:19 AM
65chevelle''ss'''s Avatar
65chevelle''ss'' 65chevelle''ss'' is offline
Trader Rating: (2)
Default
Simply amazing work guys!!!!
I'm just over the river in Portland, let me know if you need any help ;)
T
__________________
"ummm, how am I supposed to get in that thing?"
SSick build:
http://www.pro-touring.com/forum/showthread.php?t=33289
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Art Morrison
ProdigyCustoms.com
Inland Empire Driveline
Rushforth Wheels
Keith Craft Motorsports
V8 TV
Hellwig Products
Summit Racing
Redline Oil
Time Machines
Hurst Driveline Conversions
Compstar
Motorstate Distributing
Eddie Motorsports
Optima Batteries
Ride Tech
Morris Classic Concepts
Screamin Performance
GP Superstore
Paradise Road rod & Custom
Hydratech Braking
Scoggin-Dickey Parts Center
Finch Hot Rod Restorations
Jakes Rod Shop
HoodPins.net
Driverz Inc.
Musclecar Place
Bowler Transmissions
Speed Inc
Recovery Room
Belltech Musclecar
Hood-Latches.com
Ricks Hot Rod Shop
Baer Brakes
Mike Norris Motorsports
Exotic Car Transport
Total Cost Involved
Newstalgia Wheel
Southern Performance Sytems
Cone Engineering
Schwartz Performance
Forgeline Wheels
Boze Wheels
Allstar Performance
Fuelairspark.com
Clayton Machine
Electric Life
Twist Machine
Marquez Design and Fabrication
GMR
Muscle Rodz
Wheel Works
FocuzTech Performance
Mikes Custom Cars
MuscleRides.com
Savitske Classic & Custom
Anvil Auto
Wilwood Engineering
BMR Fabrication.
Second Skin Audio
Hermance Design
Edelbrock
Mast Motorsports
Intro Wheels
Boyd Coddington Wheels
Vintage Air
Pro-Touring F-Body.com
Fesler Built
Route 66 Motorsports
Global West Suspension
bonspeed wheels
KEISLER ENGINEERING
Detoit Speed & Engineering
Nitro Active
Arizen Racing Sports
Modo Innovations
Deeds Performance
Trick Flow
MagnaFlow
L & H Kustoms
Comp Cams
Ron Davis Radiators
Fletcher's Custom & Speed
Advertising
American Autowire
JCG Restoration & Customs
Empire Morpars
Road Killer Kustoms
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2010 Pro-Touring.com / G-Machines.com
