If this is your first visit, be sure to check out the FAQ by clicking the link above. You will have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Go Back   Pro-Touring.com > Events > Racing Events & Performance Reports
RegisterPT Garage FAQ Members List Calendar Mark Forums Read Home Page Online Store         Chat Room
Prodigycustoms.com
Reply
Thread Tools Display Modes
  #21
Old 06-19-2007, 03:11 PM
nitrorocket's Avatar
nitrorocket nitrorocket is offline
Trader Rating: (0)
Default
Ummm, what was that, a 16x15?? That is a low 7 second quarter mile 60' time.
Quote:
Originally Posted by rocketman
When I had 16's on my 68 camaro it would .9 -1.10 60 ft.
My 94 Z on 18's 60's mid 3's it sucks.
O the 68 is a pro mod.
__________________
Twin Turbo Ls1 '71 Chevelle
93 octane 1000 hp street car!!
  #22
Old 06-19-2007, 03:52 PM
rocketman's Avatar
rocketman rocketman is offline
Trader Rating: (0)
Default
16x16 on a 36x18 slick and it run 6.40's
  #23
Old 06-19-2007, 07:41 PM
jeff s's Avatar
jeff s jeff s is offline
Pro-Touring.com Sponsor
Trader Rating: (0)
Default
I did 0-60 mph in 2.9 with my old na engine in my Ultima GTR on 18 inch BFG
__________________
Jeff Schwartz
www.schwartzperformance.com
  #24
Old 06-20-2007, 04:43 AM
Trader Rating: (0)
Default
What does that car weight Jeff??
__________________
  #25
Old 06-20-2007, 06:29 PM
Van B's Avatar
Van B Van B is offline
Trader Rating: (1)
Default
I think it is about 2300 lbs.
__________________
Jeff
-67 Camaro Street Fighter 599 HP L92
www.pro-touring.com/forum/vbpicgallery.php?do=view&g=397
-99 Spec Miata finally on the track!
  #26
Old 06-20-2007, 07:25 PM
Trader Rating: (0)
Default
That has gotta be crazy to drive! Let me guess... 9.0'ish at about 165 mph trap speeds on 93 octane?? That is some power to weighr ratio. Mine has 1000 hp, but it weighs almost 3600!
WOW!
__________________
  #27
Old 06-20-2007, 08:53 PM
streetk14's Avatar
streetk14 streetk14 is offline
Trader Rating: (0)
Default
Quote:
Originally Posted by nitrorocket
That would be a negative.
I have a 3.08 rear gear with a 2.66 1st ratio. At 6000 rpm I am going 60, 2nd I am going about 90. It is jsut to much gear to pul wothout having to spin the tires.
I would LOVE to slap on some Hoosier or Mickey 315 drag radials, My 0-60 would be in the mid 3 second range!!
I wish they would handle corners better.
Like I said, you might want to look into a DOT approved autocross or road race type tire. It will be very sticky and handle well. It's not going to hook like a slick, but should be better than what you have.
Being able to hit 60 mph in 1st is usually a good thing for 0-60 times (no up-shift needed). This means you just need to concentrate on getting a decent launch. With 1000 hp and radials, I think your best bet is going to be walking it off the line, not dumping the clutch. Launching at higher rpms is just going to blow the tires off.
I think if you can ease out the clutch and roll into the throttle near idle speed, it might provide better results. You probably have more than enough torque to get the car moving (assuming you don't have any turbo lag down low).
I think you really need to try different techniques and see what works best with your street tires.
Andy
  #28
Old 06-21-2007, 05:00 AM
Trader Rating: (0)
Default
Andy, I already have a 315-35-17 DOT GSCS road race tire. They hook worse then my BFG's, but better then my Pirelli PZero road race slicks did.
I need to get some new waste gate springs to turn my boost down further, Even at 10 psi I have almost 600 RWHP and torque. I also cannot not actually do 0-60 while trying to go fast, I cannot control the wheelspin as of yet and have to pull 2nd about 10 feet out to try to stay off the rev limiter.
The reason behind my launch problems is the 3.08 gear and the SPEC 5 cintered iron clutch, it cannot be slipped!
__________________
  #29
Old 06-21-2007, 10:27 AM
jasonsnova's Avatar
jasonsnova jasonsnova is offline
Trader Rating: (1)
Default
sounds like another set of rims and tires to meet your all around goals is best! ......even if you cant get the 0-60 times , your car has got to be insanly fun to drive!!!
__________________
71 nova ss
was..355 6 speed, in process of 6.0/ls3 head build
411's
always under construction....
  #30
Old 07-10-2007, 05:27 PM
DJ Mabe's Avatar
DJ Mabe DJ Mabe is offline
Trader Rating: (0)
Default
Look at the Toyo RA1's. I have a set of 18"er's and my 4100lbs car post 1.6 60's and that's with me running them at 38psi. It's also in the high 3's 0-60. That's a full auto car that can only stall to about 1000RPM's. These tires hook well and you can drive them everyday. Check out the link below for a video of the car hooking. It's not 1000hp but it has a ton of torque.
http://videos.streetfire.net/search/...2156f0372a.htm
__________________
2007 997 Twin Turbo
1967 Modded Mustang Vert
1972 Bronco Sport
See my rides at www.fquick.com/DJMabe
  #31
Old 07-13-2007, 01:46 PM
ITLBTU's Avatar
ITLBTU ITLBTU is offline
Trader Rating: (0)
Default
The last time I had my '00 SS Camaro at the track it had a 2.35 60' time. It had 35-17ZR315 Goodyear Eagle's on it. I don't remember the exact model though. What ever came stock on the SS, other than the width. That car was basically stock and had 309 RWHP. Hopefully I can get the Z06 to the track and I'll give you some new numbers.
__________________
1969 Camaro..getting closer to being done..I think
1994 Camaro... Future N.A.S.A racer
2002 Z06
2006 SS Trailbrazer (Wifes)
2007 LTZ Chev Silverado 4x4 with the sports suspension package
Greg is my other name...
Web page..
http://www.itlbtu.com
  #32
Old 07-13-2007, 06:07 PM
streetk14's Avatar
Trader Rating: (0)
Default
Well then, I'm not sure what to suggest. What BFG's do you have? The G-force TA KD is the stickiest tire in that line besides the drag radials. They hook pretty well in my car, but you have a good 500 hp on me.
I think you have the problem of a fairly heavy car, a ton of power and a manual trans. I think automatic cars are easier to get good 0-60 numbers from, but I still prefer manuals in my hot rods.
I have heard that the Nitto drag radials handle better than the others on the market, but I don't have any first hand experience with them. I think I'm going to be in the same boat as you soon. I'm starting my 122 Magnacharger install and will have torque coming out of my ears. Maybe it's time for me to step up to a 335/35/17. It can't hurt, right?
Andy
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Trick Flow
Redline Oil
Musclecar Place
Modo Innovations
Summit Racing
Ricks Hot Rod Shop
Eddie Motorsports
Cone Engineering
Compstar
GP Superstore
Wilwood Engineering
Empire Morpars
HoodPins.net
Morris Classic Concepts
Belltech Musclecar
Electric Life
Forgeline Wheels
Boze Wheels
Marquez Design and Fabrication
Nitro Active
Inland Empire Driveline
KEISLER ENGINEERING
Anvil Auto
Second Skin Audio
Exotic Car Transport
JCG Restoration & Customs
Recovery Room
Art Morrison
MagnaFlow
Fletcher's Custom & Speed
Muscle Rodz
Boyd Coddington Wheels
Rushforth Wheels
Route 66 Motorsports
ProdigyCustoms.com
Ron Davis Radiators
Mast Motorsports
Ride Tech
Hydratech Braking
Advertising
Newstalgia Wheel
Arizen Racing Sports
Schwartz Performance
Detoit Speed & Engineering
Speed Inc
Baer Brakes
Time Machines
Twist Machine
Road Killer Kustoms
Paradise Road rod & Custom
Total Cost Involved
Mikes Custom Cars
Motorstate Distributing
Mike Norris Motorsports
Scoggin-Dickey Parts Center
Hermance Design
FocuzTech Performance
Allstar Performance
Finch Hot Rod Restorations
Fesler Built
Screamin Performance
Deeds Performance
Pro-Touring F-Body.com
Fuelairspark.com
Jakes Rod Shop
American Autowire
Comp Cams
Vintage Air
Southern Performance Sytems
Intro Wheels
L & H Kustoms
bonspeed wheels
BMR Fabrication.
MuscleRides.com
Edelbrock
Keith Craft Motorsports
Hood-Latches.com
Driverz Inc.
V8 TV
Clayton Machine
Optima Batteries
Savitske Classic & Custom
Hurst Driveline Conversions
GMR
Hellwig Products
Global West Suspension
Wheel Works
Bowler Transmissions
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2010 Pro-Touring.com / G-Machines.com
