If this is your first visit, be sure to check out the FAQ by clicking the link above. You will have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Go Back   Pro-Touring.com > General Technical Discussion > Suspension
RegisterPT Garage FAQ Members List Calendar Mark Forums Read Members Map Online Store         Chat Room
Boze Wheels
Reply
Thread Tools Display Modes
Old 12-11-2004, 10:28 AM
My427stang My427stang is offline
Trader Rating: (0)
Default Panhard bar on a stock leaf spring suspension
Guys, would a panhard bar help me out? I am pretty nose heavy with the big block, and typically Mustang guys wont use a sway bar out back because of that inbalance. However, I am considering a panhard bar to keep the rear located during cornering.
I wonder though, how much does it limit suspension movement? Seems like the arc of the panhard bar would fight the vertical motion of the springs
  #2
Old 12-11-2004, 12:26 PM
Mean 69 Mean 69 is offline
Trader Rating: (0)
Default
A Panhard bar, or Watt's link, is very commonly used with the vintage race cars, and is pretty effective, especially if rubber type bushings are used on the leafs. You won't get any cross talk, or not appreciably, between the vertical motion of the leafs with regard to the PHB. There is a very slight lateral motion as a function of bump with the PHB that can be minimized with a suitably long bar (over 36" is probably fine for a limited amount of vertical travel, but make it as long as you can). In addition, the bar should be parallel to the ground at ride height, and most importantly, the roll center of the PHB should be as close as possible to the roll center height as determined by the leaf springs, or you will get some form of battle/bind = not desireable. The roll center height of a leaf setup, I am 95% certain, is defined by drawing a line through the front and rear leaf bushings (side view). Where this line intersects the axle, vertically, is your RRCH from the leaf standpoint.
As far as using the PHB for a tuning device to control roll, etc, it won't help. The only thing it will do in this application will to help limit lateral motion of the rear axle relative to the body. Now, if you had a link setup, you could use the PHB to tune for roll by changing the RRCH, but with leafs, this is not an option.
Maier racing offers one for early Mustangs that looks pretty nice, or it would be easy to fab your own.
Mark
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Jakes Rod Shop
Ricks Hot Rod Shop
Mike Norris Motorsports
Compstar
Speed Inc
Amsoil
MagnaFlow
Spoilers by Randy
Edelbrock
Bowler Transmissions
Redline Oil
Fuelairspark.com
Wheel Works
Road Killer Kustoms
Twist Machine
Forgeline Wheels
GMR
Electomotive
bonspeed wheels
Newstalgia Wheel
Inland Empire Driveline
Muscle Rodz
Savitske Classic & Custom
Marquez Design and Fabrication
BMR Fabrication.
Anvil Auto
ISIS Power
Nelson Racing Engines
Comp Cams
Summit Racing
Hermance Design
ProdigyCustoms.com
Hydratech Braking
Schwartz Performance
Optima Batteries
Detoit Speed & Engineering
V8 TV
Ride Tech
Advertising
Mast Motorsports
Keith Craft Motorsports
Belltech Musclecar
Driverz Inc.
Ring Brothers
KEISLER ENGINEERING
FocuzTech Performance
Intro Wheels
Allstar Performance
MuscleRides.com
Clayton Machine
Art Morrison
Paradise Road rod & Custom
Eddie Motorsports
Fletcher's Custom & Speed
Ron Davis Radiators
Scoggin-Dickey Parts Center
L & H Kustoms
Deeds Performance
Modo Innovations
Electric Life
Hurst Driveline Conversions
Mikes Custom Cars
American Autowire
Arizen Racing Sports
Exotic Car Transport
Motorstate Distributing
Morris Classic Concepts
Boze Wheels
Time Machines
Route 66 Motorsports
Second Skin Audio
LS1 Tech
Dynamic Performance Engineeering
Trick Flow
Nitro Active
Hellwig Products
HoodPins.net
AccuAir Suspension
Vintage Air
Fesler Built
Rushforth Wheels
GP Superstore
Empire Morpars
Screamin Performance
Pro-Touring F-Body.com
HiTek Hot Rods
Recovery Room
Hood-Latches.com
Global West Suspension
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2008 Pro-Touring.com / G-Machines.com
