If this is your first visit, be sure to check out the FAQ by clicking the link above. You will have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Go Back   Pro-Touring.com > General Discussion > Welcome To Our Message Board / New Cars
RegisterPT Garage FAQ Members List Calendar Mark Forums Read Members Map Online Store         Chat Room
HiTek Hot Rods
Reply
Thread Tools Display Modes
Old 12-27-2006, 01:55 PM
b-man's Avatar
b-man b-man is offline
Trader Rating: (0)
Default Greetings from So Cal, Pontiac owner.
Just thought I'd throw my hat into the ring and join your site. Here's a few pics and details on my very understated 1964 Tempest Pro-Touring car.
Rolling stock consists of 17X8" custom-made black-painted steel wheels (zero offset) running factory Pontiac dog-dish caps. Tires are 235/45-17 all around, will be going one size bigger the next time I need tires (245/45). A 1/4" wide red stripe was painted on the rim lip to simulate the look of a factory 14" redline tire, fools a lot of people until they look a little closer.
Up front are '78 B-body (Bonneville wagon) spindles & 12" rotors re-drilled for A-body 5 on 4.75" bolt circle, along with Hotchkis tubular upper A-arms and HO Racing front springs. The factory lower A-arms have been reinforced with plates welded in the lower bushing area.
HO Racing 1-3/8" front & rear sway bars were installed, along with owner boxed rear lower control arms and new stock regular-ride rear springs cut down by 3/4 of a coil. Urethane bushings and KYB gas shocks are installed all around.
A quick-ratio high-effort 12.7:1 power steering box and pump by Lee Power Steering upgrade the steering, I kept the big stock steering wheel. This car has non-power manual brakes, the stock 9-1/2" rear drum brakes were retained.
Power was provided by a +.030 '73 455 with '66 Tri-Power induction, 068 cam/1.65 RAIV rocker arms, stock '71 455 #66 heads (8.2:1 comp), reproduction '67 RA/HO exhaust manifolds. A column-shifted TH400/13" Continental converter/2.56 open rear complete the drivetrain. Ran 13.899 at 101.85 MPH on 87 octane, shifting into 3rd after the finish line. The Tempest has a 140 MPH top end, the stock 2.56 gears were great on my highway commute while driving to my old job 40 miles away.
The Tempest started out with a factory (standard equipment) 215-cube 140HP six cylinder and a Super Turbine 300 2-speed auto, ran 20-second 1/4 miles at nearly 70 MPH. Smooooth and quiet, good gas mileage (20 MPG).
I built this car to be a stealthy street warrior, looks like a stock mid-'60s econo sedan. Column shift, no tach, bench seat. Not an expensive build by any means, but plenty of bang for the buck.
Fun to drive, handles so well I can scare myself.
__________________
Bart F.
'64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
'64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
'02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
  #2
Old 12-27-2006, 02:04 PM
6'9"Witha69's Avatar
6'9"Witha69 6'9"Witha69 is offline
Trader Rating: (0)
Default
Very cool. I looked at the pics before I read the post and the wheels commanded a double take. Very nice element to maintain a sleeper look. I have been looking at something similar for my buddies 54 Chevy. He is a Rackabilly guy and likes big whitewalls but also wants low pro meats. We will be doing the outer rim white and inside red. Rest of the car looks really good. I admire the sleeper look but think about doing something about the seats as bench seats and good cornering are mutually exclusive.
__________________
Nick R. - Stay Classy PT.Com
  #3
Old 12-28-2006, 05:59 AM
ponchopwr70's Avatar
ponchopwr70 ponchopwr70 is offline
Trader Rating: (0)
Default
Nice gto, I've seen pics of your car surfing the web before. Very cool car.
__________________
Frank M
1970 lemans sport
1994 silverado stepside
2001 zq8 s10
http://www.pro-touring.com/forum/vbp...?do=view&g=111
http://www.youtube.com/watch?v=SER1gBLn2N0
  #4
Old 12-28-2006, 08:39 AM
Cometose Cometose is offline
Trader Rating: (0)
Default
Bitchin ride, sleepers rule! The dog dishes on 17s are the best and the red lines are a great finishing touch.
I bet the bench seat makes corners "exhilarating", I have '60s "bucket" seats in my Comet(more like 2 mini-benches they're so flat..)and left turns are really fun .The seatbelt only does so much to hold ya in place.
I wonder if newer pickup benches have more of a bucket shape that would fit in the Tempest and you could upholster to look stock,justa thought
Nice job!
-Joe
  #5
Old 12-28-2006, 09:13 AM
73ta's Avatar
73ta 73ta is offline
Trader Rating: (0)
Default
Welcome B-man. Personally I like your avatare on the Performance Years site much better!!!
__________________
1973 TA G Machine
2000 BMW 540 G Sedan
  #6
Old 12-28-2006, 08:24 PM
Zee Zee is offline
Trader Rating: (0)
Default
Lots of converts coming over from the PY site. Welcome over hear B-man and I agree with 73, you should carry your avatar over here.
__________________
71 Formula, 455 Ported 96s, Crower solid cam, TKO 600, 3:73 Eaton posi. 17" 200s, RE730, 1LE brakes, Koni, Rancho adjustable bars, Hotchkis springs
  #7
Old 12-31-2006, 08:36 PM
b-man's Avatar
Trader Rating: (0)
Default
Quote:
Done on the avatar (in sig).
Thanks for the welcome guys.
I hope to learn a lot about the latest things going on in the hobby here. There's definitely a lot of knowledge among the Pro-Touring board membership. I'll do my best to answer some Pontiac-specific questions like I do on PY.
The Tempest is currently in pieces undergoing a complete drivetrain swap. Until I get the work done on it I'm driving my '02 WS6 convertible (factory Pro-Touring car) a lot more, especially when the weather's nice, which is most of the time here in So Cal.
__________________
Bart F.
  #8
Old 01-01-2007, 05:31 AM
philbay philbay is offline
Trader Rating: (0)
Default
First let me say that all of your photos are sweet and even your avartar......is interesting.. Alawys had a special place in my heart for pontiacs.. Well good luck and happy new year..phil
  #9
Old 01-01-2007, 07:18 AM
HarryPR HarryPR is offline
Trader Rating: (0)
Default
Very nice! I love sleepers AND Pontiacs!
  #10
Old 02-18-2007, 01:31 PM
Frank Grimes's Avatar
Frank Grimes Frank Grimes is offline
Trader Rating: (0)
Default
nice pontiac.
  #11
Old 02-20-2007, 06:35 PM
b-man's Avatar
Trader Rating: (0)
Default
Quote:
Originally Posted by Frank Grimes
nice pontiac.
Thanks.
__________________
Bart F.
  #12
Old 02-21-2007, 11:36 AM
Trader Rating: (0)
Default
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Global West Suspension
Edelbrock
Time Machines
Hellwig Products
Schwartz Performance
Vintage Air
Exotic Car Transport
Fesler Built
Electric Life
Clayton Machine
American Autowire
Forgeline Wheels
Belltech Musclecar
bonspeed wheels
Amsoil
Marquez Design and Fabrication
HiTek Hot Rods
ProdigyCustoms.com
Muscle Rodz
Comp Cams
Mast Motorsports
Eddie Motorsports
Savitske Classic & Custom
ISIS Power
Jakes Rod Shop
Dynamic Performance Engineeering
GP Superstore
Modo Innovations
Twist Machine
Electomotive
Paradise Road rod & Custom
LS1 Tech
MuscleRides.com
Redline Oil
MagnaFlow
Driverz Inc.
Second Skin Audio
Summit Racing
Ricks Hot Rod Shop
Deeds Performance
Pro-Touring F-Body.com
Recovery Room
Hood-Latches.com
Nitro Active
Newstalgia Wheel
Anvil Auto
Ring Brothers
Nelson Racing Engines
Inland Empire Driveline
V8 TV
Compstar
Bowler Transmissions
Keith Craft Motorsports
GMR
BMR Fabrication.
Rushforth Wheels
Spoilers by Randy
Wheel Works
Fuelairspark.com
Boze Wheels
Morris Classic Concepts
Motorstate Distributing
Advertising
Allstar Performance
Hydratech Braking
KEISLER ENGINEERING
L & H Kustoms
Detoit Speed & Engineering
Ride Tech
Screamin Performance
FocuzTech Performance
Intro Wheels
Art Morrison
Ron Davis Radiators
HoodPins.net
Arizen Racing Sports
Mikes Custom Cars
Fletcher's Custom & Speed
Trick Flow
Speed Inc
Hermance Design
Empire Morpars
Scoggin-Dickey Parts Center
Route 66 Motorsports
AccuAir Suspension
Hurst Driveline Conversions
Mike Norris Motorsports
Optima Batteries
Road Killer Kustoms
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2008 Pro-Touring.com / G-Machines.com
