If this is your first visit, be sure to check out the FAQ by clicking the link above. You will have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Go Back   Pro-Touring.com > General Technical Discussion > Wheels & Tires
RegisterPT Garage FAQ Members List Calendar Mark Forums Read Members Map Online Store         Chat Room
Compstar
Reply
Thread Tools Display Modes
Old 06-27-2006, 08:38 AM
ConceptArtistX ConceptArtistX is offline
Trader Rating: (0)
Default 1980 Malibu, Wheel & Tire Help
I just bought a 1980 Malibu last month. The engine is under construction right now and I'm trying to get the stance just right. Slammed and very G-machine looking. I ordered some 3in drop springs from opgi. And some high performance shocks and sway bars. So my question is what wheel and tire combo can I go with that should fit? I want to go with 17in wheels, maybe a 235/40/17 in the front and a 265/40/17 in the back, I dont know if this would fit? I am very open to suggestions. Please help and if you have some pictures of some options. I would love it. Thankyou.
  #2
Old 06-27-2006, 11:16 AM
CHROMAHOLIC's Avatar
CHROMAHOLIC CHROMAHOLIC is offline
Trader Rating: (0)
Default
Hi, first off depending on how you want the car to sit, if you want the front end low with the drop springs then you chould run a 7" on the front because an 8 will bottom out in the wheelwell before a 7 will. Most guys run an 8" on the rear with a 4.5 backspace and a 7" on the front with a 4. This is only a suggestion your best of to measure. I know it is possible to run a 9" on the rear and an 8" on the front but car won't sit as low. Try Malibu Racing.com lots of info on there and pics in the wheel and tire section, hope this helps a bit.....JIm
  #3
Old 06-27-2006, 11:54 AM
Samckitt's Avatar
Samckitt Samckitt is offline
Trader Rating: (0)
Default
I have 17X9.5 on the rear with 275/40/17, & 17x8 on the front with 245/45/17. Fronts rubbed a little, but that was with worn out shocks & springs. Changing all of that, but don't know how it will set yet.
Scot
__________________
Scot McKittrick
86 Monte SS with 95 LT1 & T56
8.5" 3.42:1 GN rear, 12" Vette rear brakes, 13" C5 front calipers & rotors, on S10 ZQ8 knuckles,
CC306 cam, roller rockers. 11:1 compression 3" duals, bla bla bla
  #4
Old 06-27-2006, 07:15 PM
mone mone is offline
Trader Rating: (0)
Default
Im planning on running 20s front and rear...20by8 +14mm offset...just need tires and Im done..
  #5
Old 06-27-2006, 11:15 PM
McssGmachine's Avatar
McssGmachine McssGmachine is offline
Trader Rating: (0)
Default
I have a similar setup like Scot, but in 18's. I had OPG 3" on my car and they settled right on my bump stops and they were to soft for my liking. So I cut my old hotckis springs to the height i wanted
__________________
BRIAN WEST
  #6
Old 07-02-2006, 11:31 AM
BLWN1 BLWN1 is offline
Trader Rating: (0)
Default
Im going 18/20s on my malibu eventually, may be a year. I think the other G-bodys have a lil more room, due to our lower wheel lip...update us on what you go with.. most on maliburacing run rally wheels still so not alot of help there, I know the 2 that would be helpful are on here, malibu9in and lt4malibu I think are the names... there may be a few others, but they are regulars...
  #7
Old 07-02-2006, 07:44 PM
Trader Rating: (0)
Default
Quote:
Im a member over there also, been owning my Bu since 10th grade, now Im 28...
  #8
Old 07-06-2006, 10:45 PM
RatMalibu's Avatar
RatMalibu RatMalibu is offline
Trader Rating: (0)
Default
18x10 (275/35) and 18x8's (245/40) here...4.75" backspace on the 8's and 5" backspace on the 10's
I'm a reg at maliburacing too
__________________
Matt
1980 Malibu, off the jackstands.....let's see if a T-56 will last longer than a TH-700R4
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Ricks Hot Rod Shop
Exotic Car Transport
Advertising
Fuelairspark.com
Anvil Auto
Empire Morpars
Deeds Performance
Inland Empire Driveline
V8 TV
Spoilers by Randy
Hellwig Products
Newstalgia Wheel
Comp Cams
Electomotive
HiTek Hot Rods
Hermance Design
Optima Batteries
Rushforth Wheels
Modo Innovations
MagnaFlow
Clayton Machine
L & H Kustoms
Mike Norris Motorsports
AccuAir Suspension
Motorstate Distributing
Bowler Transmissions
FocuzTech Performance
Summit Racing
Pro-Touring F-Body.com
ProdigyCustoms.com
Keith Craft Motorsports
Dynamic Performance Engineeering
Paradise Road rod & Custom
Nitro Active
Art Morrison
Mast Motorsports
Detoit Speed & Engineering
Hydratech Braking
Road Killer Kustoms
Time Machines
Hood-Latches.com
BMR Fabrication.
Speed Inc
bonspeed wheels
KEISLER ENGINEERING
American Autowire
Fesler Built
Scoggin-Dickey Parts Center
MuscleRides.com
Recovery Room
Ride Tech
HoodPins.net
Electric Life
Trick Flow
Edelbrock
Arizen Racing Sports
Second Skin Audio
Schwartz Performance
Belltech Musclecar
Eddie Motorsports
Vintage Air
Compstar
Savitske Classic & Custom
ISIS Power
Amsoil
Driverz Inc.
Nelson Racing Engines
Fletcher's Custom & Speed
Boze Wheels
Global West Suspension
Screamin Performance
Muscle Rodz
LS1 Tech
GMR
Twist Machine
Jakes Rod Shop
Morris Classic Concepts
Forgeline Wheels
Marquez Design and Fabrication
Mikes Custom Cars
Route 66 Motorsports
Ron Davis Radiators
Wheel Works
Intro Wheels
Redline Oil
GP Superstore
Hurst Driveline Conversions
Ring Brothers
Allstar Performance
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2008 Pro-Touring.com / G-Machines.com
