If this is your first visit, be sure to check out the FAQ by clicking the link above. You will have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Go Back   Pro-Touring.com > General Technical Discussion > Heating & Air Conditioning
RegisterPT Garage FAQ Members List Calendar Mark Forums Read Members Map Online Store         Chat Room
Empire Morpars
Reply
Thread Tools Display Modes
Old 10-22-2009, 08:12 PM
opnwide's Avatar
opnwide opnwide is offline
Trader Rating: (0)
Default looking for a compact AC compressor
I've got a pontiac 455 that I want to keep looking fairly stock (no flashy aluminum pulleys or $2000 serpentine systems) but I would like to change out the HUGE axial compressor for something smaller. I know a lot of folk like the sanden unit but I think it may be a little too long.
I am considering run twin turbos, and I would like to mount it IN FRONT of the block, using a v-groove pulley that lines up with the old pulley (outside groove of 3 groove crank). I've got 6 1/8" between the block and the outer lip of the pulley groove. Are there any commonly available radial compressors with a body and clutch length of 6" or less?
The compressors off the old L98 TPIs look fairly short? Diameter is not much of an issue in this location.
thanks
__________________
Greg
1976 Bandit 455
one of 110 made
work in progress
  #2
Old 10-23-2009, 05:56 AM
critter's Avatar
critter critter is offline
Trader Rating: (1)
Default
Well, if you don't like the Sanden and want to run turbos, I'm not much help. I used a Sanden mounted in the same location as the stock A6 compressor I had in my 74TA. I had to fab up the brackets. If you want a photo let me know.
  #3
Old 10-26-2009, 02:23 AM
Chevy Kid Chevy Kid is offline
Trader Rating: (0)
Default
The Sandens are nice because they only take about 3hp to run.
Tim
  #4
Old 10-26-2009, 08:45 AM
Twentyover Twentyover is online now
Trader Rating: (0)
Default
Candidly, the R4 used on GM's for a number of years are a little fragile. Think you may be happier in the long run with smething else
__________________
Greg Fast
1970 Camaro RS Clone
1984 el Camino
  #5
Old 10-26-2009, 09:05 AM
ProdigyCustoms ProdigyCustoms is offline
Pro-Touring.com Sponsor
Trader Rating: (0)
Default
All the front mount drive set ups use the Sanden SD7 "peanut" compressor.
__________________
Frank Serafine
Prodigy Customs
Pro Touring Muscle Car Specialist
FREE PRO TOURING TECH and PROJECT PLANNING For Forum Members
Weekdays 8AM TO 10PM EASTERN TIME
FOUR ZERO SEVEN 832 1752
GP SuperStore
Group Purchase Discount Auto Parts
  #6
Old 10-27-2009, 08:39 PM
opnwide's Avatar
Trader Rating: (0)
Default
I just found out that the Sanden 508 is about 7" from the back plate to the 1st v-belt groove. (About 7.5" to the second groove for those interested.) That's a tad too long for me, so I'm still looking. There is supposedly a shorty version that I am trying to find out about (SD5?)
__________________
Greg
1976 Bandit 455
one of 110 made
work in progress
  #7
Old 10-28-2009, 06:56 AM
Trader Rating: (0)
Default
There 7" and 5" versions of the 5 cylinder Sanden compressor. (The 5 & 7 inch designations refer to displacement.)
The 5" is infrequently used, so may cost you a little more. The pumps are fundamentally the same with different strokes to accomofdate the differing displacements, and body length variation resulting from stroke variation.
__________________
Greg Fast
1984 el Camino
  #8
Old 10-28-2009, 09:09 AM
opnwide's Avatar
Trader Rating: (0)
Default
I was just emailed from some Ebay seller, saying the SD5H14 is 8" long total with 2 groove pulley. It sounds like the SD5H14 is the same as the 508 compressor:(
I also discovered the SD5H09 is 7 3/8" long with clutch. So figure subtract 1" for the extra pulley and clutch assembly and that leaves 6 3/8". Still a little long. I wonder if those bolts that stick out the back can be ground down 1/4" or so....
Oh, and I get the nomenclature now. Sanden 508= 5 cylinders, 8 cu. in. displacement.
thanks!
__________________
Greg
1976 Bandit 455
one of 110 made
work in progress
  #9
Old 10-28-2009, 10:58 AM
Trader Rating: (0)
Default
http://www.rparts.com/Catalog/Major_...sion_guide.htm
Not quite the same
__________________
Greg Fast
1984 el Camino
  #10
Old 10-29-2009, 08:16 PM
opnwide's Avatar
Trader Rating: (0)
Default
Thanks, Twentyover.
It looks like that 505 is going to have to be the one. With a little grinding of those back bolts, it should fit!
__________________
Greg
1976 Bandit 455
one of 110 made
work in progress
  #11
Old 10-30-2009, 04:32 AM
Trader Rating: (0)
Default
Quote:
Here is a link to some peanut compressors.
You are looking for the
P411 or P412.
http://marchperf.com/pg51.html#accomp
__________________
Frank Serafine
Prodigy Customs
GP SuperStore
  #12
Old 11-15-2009, 09:49 AM
transamguy79's Avatar
transamguy79 transamguy79 is online now
Trader Rating: (0)
Default
are you looking for a compressor off of another car or a brand new one? my father owns a a/c and radiator shop and can get about anything custom or not. let me know what your looking for
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Nelson Racing Engines
Ron Davis Radiators
Modo Innovations
Screamin Performance
Nitro Active
Ring Brothers
ISIS Power
Redline Oil
Mike Norris Motorsports
Bowler Transmissions
Jakes Rod Shop
ProdigyCustoms.com
Compstar
LS1 Tech
Arizen Racing Sports
Optima Batteries
V8 TV
GP Superstore
Scoggin-Dickey Parts Center
HiTek Hot Rods
MuscleRides.com
Advertising
Detoit Speed & Engineering
Hermance Design
Pro-Touring F-Body.com
Electomotive
Hurst Driveline Conversions
FocuzTech Performance
HoodPins.net
Second Skin Audio
Fletcher's Custom & Speed
Exotic Car Transport
Deeds Performance
American Autowire
Clayton Machine
Global West Suspension
Fesler Built
Keith Craft Motorsports
AccuAir Suspension
Paradise Road rod & Custom
Allstar Performance
Twist Machine
Hydratech Braking
Motorstate Distributing
Dynamic Performance Engineeering
Road Killer Kustoms
Touring Classics
Newstalgia Wheel
Anvil Auto
Marquez Design and Fabrication
Recovery Room
Empire Morpars
Rushforth Wheels
Belltech Musclecar
Comp Cams
Mikes Custom Cars
KEISLER ENGINEERING
Ride Tech
Time Machines
Savitske Classic & Custom
Summit Racing
Electric Life
Schwartz Performance
Mast Motorsports
Boze Wheels
MagnaFlow
Muscle Rodz
Intro Wheels
Southern Performance Systems
Driverz Inc.
Speed Inc
Ricks Hot Rod Shop
Amsoil - Joe Mac Ind. Dealer
bonspeed wheels
Max G Systems
Edelbrock
BMR Fabrication.
Route 66 Motorsports
Trick Flow
Morris Classic Concepts
Art Morrison
Hood-Latches.com
Inland Empire Driveline
Vintage Air
Forgeline Wheels
Fuelairspark.com
L & H Kustoms
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright ©2008 Pro-Touring.com / G-Machines.com
