If this is your first visit, be sure to check out the FAQ by clicking the link above. You will have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Go Back   Pro-Touring.com > General Technical Discussion > Suspension
RegisterPT Garage FAQ Members List Calendar Mark Forums Read Members Map Online Store         Chat Room
Belltech Musclecar
Reply
Thread Tools Display Modes
Old 11-03-2009, 12:05 AM
LowBuckX's Avatar
LowBuckX LowBuckX is offline
Trader Rating: (1)
Default Droop stops Anyone?
Dont think using my new coil overs as droop stops is a good Idea anyone using something for a droop stop? Off road guys use wide nylon straps but that would look cheesy......
__________________
72 Nova in constant state of change.
Follow my 3 link build. http://www.pro-touring.com/forum/showthread.php?t=61592
  #2
Old 11-03-2009, 06:16 AM
John Wright's Avatar
John Wright John Wright is offline
Trader Rating: (0)
Default
Another thing to remember is that the offroad guys occasionally get airborne(sometimes on purpose)....PT folks spend alot of effort keeping air out from under the vehicle.
On my 70 camaro, the factory uses the shocks in the rear suspension as the droop stops...probably not the best treatment for the seals in the shocks...but that was how the factory did it. As for the front of my car, they had rubber stops that limited the suspension parts from colliding with the subframe at full droop and when fully compressed....but my after market arms don't include these full droop stops.
I'm curious too what you guys come up with for this...
__________________
All is bolted up and has been test fitted with the exception of a driveshaft....motor is back out and being refreshed.
  #3
Old 11-03-2009, 06:38 AM
parsonsj's Avatar
parsonsj parsonsj is offline
-Moderator/Sponsor-
Trader Rating: (0)
Default
As John says, droop stops aren't that important. The only thing I worried about on II Much was to make sure the coilover springs didn't fall out of position with the shocks fully extended.
I used helper springs and spring seat guides to solve that problem.
http://www.hrpworld.com/index.cfm?fo...action=product
jp
__________________
John Parsons
II Much Fabrication
Norris Motorsports
  #4
Old 11-03-2009, 06:59 AM
falcon65's Avatar
falcon65 falcon65 is offline
Trader Rating: (0)
Default
i built in a droop limiter into my front suspension. It is a stainless steel cable. Im on my phone on my way to SEMA so take a look at my motortopia page. But my afco shocks can be used as a droop limiter.
  #5
Old 11-03-2009, 08:37 AM
6'9"Witha69's Avatar
6'9"Witha69 6'9"Witha69 is online now
Trader Rating: (0)
Default
Which UCA's are you using? Factory and a lot of aftermarket have a snubber under the cross bracing. I know the SPC arms do not have that. Most others should.
__________________
Ron Burgundy (Nick) - Stay Classy PT.Com
08 HHR SS - Still Stock for now (damn unemployment)
  #6
Old 11-04-2009, 06:38 PM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
Trader Rating: (0)
Default
Check out this thread:
http://www.chevelles.com/forums/showthread.php?t=295167
Post four shows an interesting idea for the SPC arms.
Jon
__________________
Jon U.
1968 GTO - SC&C's Street Comp AFX suspension, Forgeline SO3 wheels from Prodigy Customs and Sparco seats from Motor Sport Seats
Build Thread
  #7
Old 11-04-2009, 08:35 PM
JRouche's Avatar
JRouche JRouche is offline
Trader Rating: (0)
Default
For a street car I dont think straps are needed. Rarely do we lift the front end so fast and severely that the shock of a coilover is gonna take any abuse. And with a coilover you dont have to worry about the spring dropping out of its perch. So I think they arent needed.
Contact the manufacture of the coilover, they may have a small rubber snubber in the shock for both ends of travel. I wouldnt be surprised. A shock manufacture doesnt want his shock bottoming out metal to metal. JR
  #8
Old 11-06-2009, 12:17 PM
strtlegal strtlegal is offline
Trader Rating: (0)
Default
The reason why I use them in my offroad truck is the shocks themselves do not have internal bumps/stops to stop the shock shaft from going through the cap. This is on a shock that is greater then 2.0's and have more then 10" of travel..Most of our cars may see 4"
__________________
1970 NOVA..Ls2/Tko..Lowered...18" Intros..Nitto NTo5's
  #9
Old 11-06-2009, 09:54 PM
LowBuckX's Avatar
Trader Rating: (1)
Default
I was talking rear but all the info is relevant to a street car so thanks... But what if I want to jump that old washed out bridge to escape the law.... HHHMMM>
__________________
  #10
Old 11-07-2009, 07:00 PM
JRouche's Avatar
Trader Rating: (0)
Default
Quote:
Oh... The rearend. Ok, much diff. Well not so much cause its the rear. but that you are running a shine hauler Now.... If you are running low on a few jugs of shine then yer rear is gonna be light. My advice??? Dont go out with half a load of shine, keep the a$$ end loaded down. Sweet!!! When are you gonna make another run to the west coast. Im down to my last jug.... LOL What came first, shine runners or nascar???? JR
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Anvil Auto
Hermance Design
Ricks Hot Rod Shop
bonspeed wheels
Empire Morpars
Amsoil - Joe Mac Ind. Dealer
Time Machines
Savitske Classic & Custom
Inland Empire Driveline
Marquez Design and Fabrication
Clayton Machine
Compstar
Pro-Touring F-Body.com
Art Morrison
AccuAir Suspension
Touring Classics
Comp Cams
Screamin Performance
Bowler Transmissions
Belltech Musclecar
Forgeline Wheels
HoodPins.net
ISIS Power
Schwartz Performance
Keith Craft Motorsports
Nelson Racing Engines
Boze Wheels
Fesler Built
Mast Motorsports
Second Skin Audio
Hood-Latches.com
Optima Batteries
Hurst Driveline Conversions
Newstalgia Wheel
Rushforth Wheels
FocuzTech Performance
Electric Life
Jakes Rod Shop
Scoggin-Dickey Parts Center
Summit Racing
Muscle Rodz
Hydratech Braking
Fletcher's Custom & Speed
Driverz Inc.
HiTek Hot Rods
American Autowire
Modo Innovations
Recovery Room
MuscleRides.com
Global West Suspension
Intro Wheels
Arizen Racing Sports
Road Killer Kustoms
Route 66 Motorsports
Electomotive
Trick Flow
Ring Brothers
Southern Performance Systems
Max G Systems
Deeds Performance
Speed Inc
Twist Machine
MagnaFlow
Exotic Car Transport
Allstar Performance
Morris Classic Concepts
Motorstate Distributing
ProdigyCustoms.com
V8 TV
Vintage Air
Advertising
Dynamic Performance Engineeering
Edelbrock
Mikes Custom Cars
GP Superstore
Paradise Road rod & Custom
KEISLER ENGINEERING
Redline Oil
LS1 Tech
Fuelairspark.com
Mike Norris Motorsports
BMR Fabrication.
Detoit Speed & Engineering
Nitro Active
L & H Kustoms
Ride Tech
Ron Davis Radiators
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright ©2008 Pro-Touring.com / G-Machines.com
