Pro Tour 67
12-18-2012, 03:35 PM
I am offering up my highly modernized pro touring 67 Camaro. This amazing car has been an ongoing project of mine the last 5 years(5000 miles). I have upgraded nearly everything in an effort to make the car a kick in the ass to drive and have the look of a classic. The motor and trans had 50 miles on them when installed about 2200 miles ago. The car is very solid with a brand new 18 circuit Painless harness. It needs nothing and runs very strong. The extensive build sheet is as follows
Dave
$57,000 OBO
Engine
GM LS3 6.2L 376 ci smallblock
LGM G6X3 camshaft over 230 IN/ over 240 EX duration and over.600 lift
Comp 921 dual valve springs
Comp Cams pushrods
Xcelsior Motorsports portedLS3 throttle body
Xcelsior Motorsports portedLS3 intake manifold
Katech single roller timingchain
Moroso LS series oil pan #20141 with remote oil filter
ARP head bolt kit
Billet chrome fuel rails
Street & Performance-chrome intake tube connected to custom 3” body matched extension
NGK #4177 spark plugs
Hooker motor mount adapterplates #1261-HKR
Energy Suspension motormounts polyurethane #3-1115G
Turn Key coil pack coverspainted exterior color
Billet Specialties- 16 lbradiator cap and 13”x2” overflow tank
Mobil 1 5w-30
Cooling/Electrical
SPAL 16” #2082 true 2470 CFM
Griffin aluminum radiatorSummit #GRI-1-55242-x
DSE 7”headlight kit w/electric RS hidden headlights
Speartech wiring harness formotor & trans.
Speartech ECU with customdyno tune
Painless 18 circuit vehicleharness
GM 6L80 trans computer withSpeartech flash
O2 sensor #12617332
Billet Specialties Optimabattery relocation kit Optima red topbattery 34/78
Dakota Digital VHXgauges Carbon fiber back with blue LEDbacklight
LED parking/driving lights anddome light
Fesler LED taillightconversion
Starter #10465385 GMpart 1997-04 Vette & 1993-02 Camaro GEAR REDUCTION STARTER
Transmission
6L80 6 spd. Auto 2010 Chevy Corvette spec.
Custom computer programmedshift points and line pressure
LG Motorsports 2800 stallconverter
2010 CTSV shifter
Steel driveshaft with Spikeryoke # 3-3-1561KX
Transmission cross member-stock 67 type flipped backwards with custom bracketry
Transmission tunnel raised 2”in height to accommodate the taller 6L80 trans
Transmission mount 2010Camaro
Brakes/Steering
Front- C5 Corvette with PowerSlot slotted cryo treated rotors
Rear- C5 Corvette with PowerSlot slotted cryo treated rotors
Hydratech hydroboost powerbrakes, shallow style master cylinder
Perf. Steering Components(PSC)power steering remote reservoir 6”
DSE power steering pump TypeII without reservoir. Polishedaluminum #090301P
Lee Engineering 12.7:1 quickratio steering box and rag joint
Fuel System
DSE narrowed & baffled 17gal stainless steel fuel tank with 90 ohm sending unit
Walbro GSS-340 in tank fuelpump
91 octane
-6 steel braided fuel lines
AN fittings
Exhaust
Hooker Super Comp 1.75”ceramic coated headers #2288-1HKR
Gasket- Mr Gasket MRG 5966
3” piping with 2 chamberFlowmaster mufflers
Quick Time Performance (QTP)electric cutouts- pair
Suspension/Drive train
Front- Savitske Classic &Custom FX spindles(7/8“ drop), SPC UCA’sadjustable for camber & caster,SPC LCA’s w/ graspable racing bushings
Alston 16 position shocks setting 7 # VAS 14145-615
Global West 1” lowering coils
Hotchkis 1 1/8” hollow sway bar
SPC coil spring spacer
Rear- Leaf springs lowered 2”
Helwig ¾” solid rear sway bar
Sub frame connectors
Cal Tracks traction bars
Alston Varishock 16 position shocks setting 5
10 Bolt rear end, posi 3.73
Wheels
Billet Specialties Fast Lane
Front: 18x8 (4.5” BS) 235/40/18 Kumho Ecsta MX studs/lugs M12x1.5(Corvette hubs and brakes)
Rear: 18x9.5 (5.5” BS) 275/40/18 Kumho Ecsta MX studs/lugs 7/16 (Camaro hubs)
Miscellaneous
DSE core support closeoutpainted exterior color
DSE firewall block off plate
Corbeau TRS front seats in black full leather (stockseats in storage)
Corbeau black camlock harnessbelts
OER center console withoutgauges. Gauges in dash
Billet Specialties windshieldwiper post covers
Billet Specialties rear viewmirror with bowtie
Billet Specialties Fast Lanesteering wheel Black leather wrap/small bowtie horn button
Billet Specialties blackanodized window cranks, lock knobs and door handles
Ringbrothers billet hoodhinges
Motor & trans raised 1.5”compared to stock 67 Camaro location to accommodate taller 6L80 transmission
Paint is Indigo Blue off aChevy Tahoe est. 2002
Frame off restorationfinished 2004. Frame sanded and paintedblack
Vehicle weight withoutdriver 3340 lbs
Viper alarm with remote start& keyless entry
Original equipment/History
Built 3rd weekof May 1967 in Van Nuys, CA. It was a V6 sport coupe in Mountain greenexterior with standard black bucket seats, center console and fold down rearseats. TH400 automatic with the RPO-Z22Rally Sport pkg. Body unit # 34617
A quick walk around video before I installed Dakota Digital gauges and optional race seats. Stockers are included
http://www.youtube.com/watch?v=alyS_Eresrc
Photobucket link
http://s496.beta.photobucket.com/user/dross1_01/library/1967%20LS3%20Camaro/#/user/dross1_01/library/1967%20LS3%20Camaro?&_suid=135587282685809318161271487236
Online article
http://www.chevyhardcore.com/news/how-a-1967-camaro-helped-a-man-achieve-his-dream/otobucket link
Dave
$57,000 OBO
Engine
Comp Cams pushrods
ARP head bolt kit
Mobil 1 5w-30
Cooling/Electrical
O2 sensor #12617332
Transmission
2010 CTSV shifter
Brakes/Steering
Fuel System
91 octane
AN fittings
Exhaust
Wheels
Miscellaneous
Photobucket link
Online article
