View Full Version : 1968 Pontiac Firebird Resto Modded Project Car
tennhouse
11-12-2012, 08:40 PM
MORE PICTURES AT BOTTOM OF POST
VIN: 223378U607666
CLEAN TITLE and TITLE IN HAND
I am selling a 1968 Pontiac Firebird Project $14,000 OBO NASHVILLE, TN **Price Drop**. I have been building this car over the past few years but due to other responsibilities was not able to complete as planned. Most of the parts are brand new out of the box which includes receipts (0 miles, used for assembly only). The most attention the car needs is body work, but with the parts supplied and some TLC this car has great potential. I am basically just try to pay for my drivetrain the body is free and if the buyer is interested in the rotisserie they can take it as well. If you need any additional pictures or questions answered please feel free to contact me at Alexander - 615-405-3578 calling or texting is fine. Below is a list of parts and labor in detail. I am also open to trades. trades + cash(on your end) preferred I am open to trucks, suvs, cars, beaters, etc...
Body
Chemical dipped in Indianapolis, Indiana
Year One body panels bought brand new
2 quarter panel
2 inner fender welds
trunk pan
deck lid
door skins
fenders
inner fenders
fender extensions (6 months back order)
hood
radiator core support
2 floor pans
windshield
Custom fabricated motor mounts for better weight distribution
Original driver and passenger glass as well as rear window (no quarter glasses)
Custom made 3 piece rear spoiler
1969 Camaro rear bumper cut to fit
Gas tank with straps
Front bumper
Full stainless steel body bolt kit
New left and right front grilles
Weather stripping
Shaved door handles
Shaved drip rails
Suspension- Powder coated
Heidts 0 miles
[COLOR=#000000][FONT=Arial]front subframe
spindles
upper and lower control arms
front sway bar
subframe connectors
Wilwood 0 miles
4 piston calipers all around
13 inch brake rotors all around
wheel bearings
brake pads[B]
QA1 coilovers all around 0 miles
Energy Suspension body mounts all around
Strange Engineering 0 miles
4 link rear suspension
custom ford 9 inch rear end with 373 gears
32 spline axels
Engine
1975 Pontiac Grand Prix 455 big block 0 miles
block and crank bored .030 to 4.181 "bore, stock stroke 4.210"
block has been tapped for screws in oil galley plugs. the lifter has been deburred also
crank has oil feed holes
crank turned .010" on main rods
stock connecting rods with Badger pistons and speed pro rings
speed pro rod, main cam bearings, fel-pro gasket set
summit timing chain, and oil pump 60lb pump
Comp cam magnum 280 cam and high energy lifters- cam spec- .480 lift, 280 duration 110 lsa, 106 intake centerline
Comp magnum roller tip rocker arms- 1.52 ratio
6x-4 heads, 89cc combustion chambers, 9:2:1 compression ratio- rebuilt with new guides and seals, valve job, resurface and Crane valve springs
Edelbrock Performer RPM intake, exhaust crossover blocked with stainless steel plates
holley 750 cfm double pumper carb- race prep, stock jets, HP main body upgrade
stock distributor with summit rebuild kit and summit plug wires, AC delco R44ts plugs
holds 6 quarts with filter change 15w-40
stock starter
Headman headers
Flowmasters exhaust
OE slave cylinder, clutch reservoir and brake reservior
Oil filter relocation kit
Painless Wiring Harness (front to back)
Drivetrain
Unisteer rack and pinion 0 miles
Summit racing steering column without tilt
Flaming River connections
Steering wheel
Tremec TKO 5 speed 0 miles
550 horsepower clutch and pressure plate upgrade 0 miles
billet aluminum flywheel 0 miles
Scatter Steal upgraded bellhousing 0 miles
Hurst shifter and shift knob
aluminum driveshaft 0 miles
Rims and Tires
CCW Classics 0 miles
17x9 275 Front
17x95 285 Rear
Miscellaneous
handful of original parts
window regulators
trim pieces
pedals
tail lights
cowl panel
hood hinges
hood scoops
door hinges
Interior
both front seats
rear seat cushions
door panels
Pictures
[LIST]
Pictures
Before
https://static1.pt-content.com/images/pt/2012/11/IMG_0090-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_0796-1.jpg
3 months ago (the furthest I got)
https://static1.pt-content.com/images/pt/2012/11/IMG_1063-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_1064-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_1090-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_1091-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_0129-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_0126-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_1060-1.jpg
https://static1.pt-content.com/images/pt/2012/11/IMG_1061-1.jpg
As it sits now
https://static1.pt-content.com/images/pt/2012/11/DSC01370-1.jpg
https://static1.pt-content.com/images/pt/2012/11/DSC01369-1.jpg
https://static1.pt-content.com/images/pt/2012/11/DSC01368-1.jpg
https://static1.pt-content.com/images/pt/2012/11/DSC01367-1.jpg
https://static1.pt-content.com/images/pt/2012/11/DSC01364-1.jpg
https://static1.pt-content.com/images/pt/2012/11/DSC01362-1.jpg
https://static1.pt-content.com/images/pt/2012/11/DSC01360-1.jpg
https://static1.pt-content.com/images/pt/2012/11/DSC01353-1.jpg
MORE PICTURES HERE http://www.firebirdnation.com/forums/topic/412514-1968-firebird-resto-modded/
Grifter757
11-26-2012, 11:05 AM
What body work is left to do?
tennhouse
11-26-2012, 04:03 PM
Basically almost all of the body work is needed. barely got started
tennhouse
11-29-2012, 11:23 AM
up!!
drflex
11-29-2012, 08:28 PM
would you sell the rotisserie?
pm me the $$
tennhouse
11-30-2012, 09:47 AM
^^ let me see if I can sell it as one. If not I will PM you a price
tennhouse
12-10-2012, 02:36 PM
price drop bump
tennhouse
12-25-2012, 09:33 PM
bump Merry Christmas
jaya22
01-03-2013, 05:22 PM
is the car still for sale ? How Much? anything else done to it?
tennhouse
01-03-2013, 06:01 PM
Yes the car is still for sale. I will take $15,000 OBO. No, still looks the same as pictured above
tennhouse
01-20-2013, 07:48 PM
Still for sale.
tennhouse
02-04-2013, 07:52 AM
super bowl bump
tennhouse
02-14-2013, 08:42 AM
bump updated PICTURES
and price drop!
Pikeslayer
02-22-2013, 04:37 PM
Nice to finally talk to you on the phone Alexander. I'll see you shortly to pick up my new project. - Don
firebirddady69
04-01-2013, 10:10 PM
still for sale
fastlane
04-02-2013, 04:28 AM
My father in law works for his dad, he told me he sold it.
