View Full Version : Can i use this to mock install my T-56??
Nutsy
08-03-2005, 01:13 PM
Just wanted to know if the C5 T56 casing is the same as a LS1 T56 casing for mock up purposes?
I am wanting to install my DSE weld in cross member and i would like to have the engine/tranny mocked up to make sure i hack the floors in the right spot for both the crossmember and the shifter hole.
I already have a dummy LS1 block, but need a t56 tranny for mock up. I found this on ebay.
http://cgi.ebay.com/ebaymotors/T56-6-SPEED-TRANSMISSION-MAIN-CASE_W0QQcmdZViewItemQQcategoryZ33733QQitemZ799101 3780QQrdZ1
Provided i get a bellhousing, will this work for what i want?
Any other suggestions? I just don't want to go buy a full blown T56 and have it sit for a year or two while i finish up the body/suspension work on the car.
B Schein
08-03-2005, 01:33 PM
The Vet main case is the same but the trany mount is on the tail stock so it wont do a lot of good with out a tailstock to check the crossmember fitment.
Brian
