Donovan
08-28-2012, 01:35 PM
Power steering -Stock, works great. LS1 pump
Suspension - Stock GXL adjustable. NEW ROTORS and PADS
Wheels - 2000 Mustang GT in CHROME
Tires - NEW 225 in front and 275 out back
Conversion mounts - Hinson Motorsports, Poly isolators
Cooling System - JTR mount, Corvette Radiator
Exhaust - Trailblazer SS manifolds, custom 2.5" stainless dual pipes with Large magniflow cans and an X-pipe
Rear End - STOCK 1988 Turbo II rear differential
Fuel system - Supra Denso pump, stock lines combined with Teflon braided line and AN fittings. Corvette FPR
Body - all stock GXL, Original flaky white paint. No body damage
Interior - Stock(blue) Original 9 out 10 condition
Wiring - Stock Body wiring, Optima Battery in passenger bin, mounted with a billet case.
The Bad - No A/C, No rear Wiper, Surface rust where paint has flaked off. Passenger door interior handle broken, No radio or idiot lights installed.
selling the shell MINUS the engine, transmission, slip yolk and ECM/harness.
Include the
-Center mount gauge pod (empty)
-JTR cooling setup
-T2 diff
-Hinson mounts/ poly cushions
-Stainless exhaust with manifolds
-Power steering kit minus the pump(TurnOne restrictor goes with the car)
-Fuel system
-Clutch MC and lines
-Everything in the car
SPARES -GXL rims
-GXL NA diff
-console mounted idiot lights
-stock oil cooler
-stock a/c parts
Drop in your LS engine/T56
Wire in your ECM and harness
$3000
Located in Katy, TX (Houston)
Include the
-JTR cooling setup
-T2 diff
-Fuel system
SPARES -GXL rims
-GXL NA diff
-stock oil cooler
-stock a/c parts
$3000
