View Full Version : Any advice for rear end breather tanks?
rdchandler
04-07-2012, 10:30 AM
I am looking for a good air/oil separator - breather tank for my differential . Ideally a tank that I can mount in the trunk and vent back outside.
parsonsj
04-07-2012, 11:03 AM
Our Fuel / Differential Vent should solve your problem. Available late this month:
https://www.pro-touring.com/showthread.php?87832-II-Much-Fabrication-Fuel-Vent-prototype-installation
rdchandler
04-07-2012, 01:10 PM
John, That looks like what am looking for, is it baffled or have some means of not allowing oil through the outlet? Also would it allow oil to drain back through the inlet?
rob
parsonsj
04-07-2012, 02:04 PM
John, That looks like what am looking for, is it baffled or have some means of not allowing oil through the outlet? Also would it allow oil to drain back through the inlet?Yes, yes, and yes. :) The only caveat with a diff vent is that you need to design you connection hose to be in a downhill position at ride height so that diff fluid doesn't get trapped in the hose.
