Mr. Anderson
01-22-2012, 06:50 AM
Getting my El Camino up in the air and back down again doing the exhaust and other stuff under the car, I noticed how much flex their is in the frame from the firewall forward. I have jack stands on the frames torsion boxes but keep a jack with pressure under the front crossmember because it makes me nervous. There aren't any fenders bolted on currently.
I've been thinking about some bars going from the frame horns to the firewall.
I would weld some heave threaded plates to the top of the framerails above where the sway bar mounts. Then the feet for the bars would bolt on to those (want to keep it removable). At the firewall, I would use some 3/16" or 1/4" steel to sandwich the firewall, probably all along the top of the body seam. And then tubes in between. See attached picture. The dots indicate bolts.
My concerns are the strength at the firewall. I think mounting it right along the seam puts it at a pretty strong area. What do you think?
