View Full Version : Anybody knw the wheel flange to wheel flange length on 94 newer mustang
blazer4corners
01-12-2012, 04:30 PM
Was curious i anyone knew this length. Im debating om using an 8.8 outa one of these in my 68 cougar.Its got the 8inch in it now. All the wheels i like in the size i want r all for 94 an newer mustangs. Thanx in advance....... Mike
Randy67
01-13-2012, 06:44 AM
Quick search shows 60.5" for 94-98, 99-04 is wider at 62".
If memory serves, the 94-98 housing is the same width as the Fox body ones, but it has longer axles. 99-04 the housing is wider and axles longer too.
blazer4corners
01-26-2012, 03:56 PM
Thanx Randy.....
dontlifttoshift
01-26-2012, 04:16 PM
If you were going to swap rear ends I think you will find a disc brake explorer 8.8 will fit better width wise.
Your cougar and a 94 and up mustang have the same bolt pattern. You don't have to swap rear ends just to run the later wheels unless there is a back spacing issue. In that case only careful measurments will tell you if the new axle width and wheel backspacing will work on you cougar.
Donny
