View Full Version : Improving GM's suspension, 64 Riviera
CTX-SLPR
12-01-2011, 10:12 PM
Howdy,
I'm working on my '64 Riviera and I'm really dissatisfied with the front suspension. I downloaded the Performance Trends Suspension analyzer and crawled all over my front suspension taking measurements. I won't claim my measurements are within the desired 1/16in accuracy but they are probably within 1/4in tolerances which is about as good as I can do with the engine in the car, tires on and so forth.
Since I don't have the time, money, or equipment to put say a C4 or C5 suspension stub on the car nor does the X-frame and rear steer make it easy to do anyway; I'm sticking with the stock suspension points and the stock center link as givens. Right now the spindles are 9in tall and I have 11in of vertical offset between the centerline of the upper control arm cross shaft and the lower control arm. Now to point out I have "virtual" (or at least I think I do) lower A-arm since it has a single lower arm with a brake reaction rod that I've modeled as the front leg of the control arm. This means the modeling software has an inaccurate position of where that arm converges (or so I think it does) since the reaction rod attaches just outboard of the spring not near the ball joint. I can pass on the save files if anyone wants to look at it more in depth but here's what I've come up with using my own excel modeling of the ball joints based on the arcs of the control arms to build a set of much longer control arms to fit a C5/C6 spindle with a 1in taller ball joint for an overall near 14in tall spindle and ball joint stack. Since the chassis is rear steer I was going to do what I think DSE does for their C5/6 retrofit kits and cut off the stock steering arm and machine my own steering arms to put the tie rod ends in the same place though I'm thinking of moving them closer to the spindle centerline to increase range of motion without changing my steering box stops. The Suspension analyzer gives me a camber gain of -0.91, a caster gain of .98, and a roll center of 4.49in.
From that stand point of wanting much better handling but still a good ride quality out of this set up, what kinds of changes would you make to things like the C5 scrub radius (tires are fixed, the spindle will move in or out), ball joint incompatibility, anything at all really.
exwestracer
12-02-2011, 03:18 AM
The outer attachement point of the brake reaction rod (strut rod) is not as critical because it is fixed to the lower link. If you are plotting ball joint migration, the pivots are the important points to measure. Sounds like you are on the right track trying to get the ball joints further apart than the pivots. I would also look at what it will take to level the lower control arm (ball joint to pivot) at static ride height. If this fits into your plan for chassis height, it will make the camber curve much more predicatable.
IMO, I would use a "build up" lower control arm from the circle track racing world and adapt it to the C5 upright. They are made to take a 3/4" spherical bearing and taper pin adaptor. As far as I can tell, your head is in the right place with what needs to be done to it. Here's a pic of of a C4 setup we put under an S10 several years ago.
51959
Seems like a lot of offset built into the upper ball joint.
CTX-SLPR
12-02-2011, 07:05 AM
Well I did just realize that the C5/6 upright has that inverted upper ball joint so using a taller ball joint would actually be working the wrong way on gaining spindle height. Can the upper ball joint be flipped over or would it be better to machine an insert to take a convensional "over the spindle" ball joint instead?
I've got to correct the ride heights since I didn't see them till after I'd made most of the modifications to know if it'll work practically but I did put the lower link parrallel to the ground which required lowering the car 2in (all the frame stuff). I'll have to check the centerline heights of both the C5 uprights and my current ones to see if that's a problem.
Is a spindle pretty much a spindle if you have control of the control arms and ball joints to attach them with? With that funky inverted ball joint I was looking around and found that C4 spindles have "convensional" ball joints with close to the same distance between ball joints and 4th Gen F-bodies have a huge 17in spindle. Let's forget the steering arms for now since I'm pretty much going to have to machine my own for anything.
12-02-2011, 09:30 AM
As far as your front set up you are not limited to a C5-C6 spindle. I own a 65 and we looked into doing some swapping. We liked the way the Tahoe/Yukon spindles looked. Just getting a taller spindle and a larger sealed bearing makes it worth the work.
Also, Katz built his 65 up and it was a great improvment over stock. I'll try to find that thread.
The car is blessed with a 3 link and alot of room up front.
To get chassis stiffness back on line a cage and maybe body out riggers can be used.
exwestracer
12-02-2011, 12:56 PM
I'm actually looking at a 63 Riv right now, so I may be joining this party in earnest. I'd think you could drill out the ball joint hole and go to a spherical upper and a press fit pin to get the ball joint on top. I wouldn't use a thru bolt in there, esp. on an aluminum upright.
CTX-SLPR
12-02-2011, 07:41 PM
Oye this car has some numbers way off of modern stuff. I measured the spindle centerline to lower balljoint surface to compare to this:
https://static1.pt-content.com/images/pt/2011/12/Comparoearlytolateg-1.jpg
What I found is the height for the '68 Riviera Spindles I have off the car that are interchangable with the ones on the car have a spindle height of 1.875in, way way less than anything in that picture. A C5/6 upright would give me a 3in drop in right height just with the spindles, another 2in to flatten the lower control arms would put me at 5in of drop on my current 8.25in ground clearance. I'm not riding that low!
I take this to mean that I'd have to put the ball joint on top of the lower mount to bring that back into the range of useable to bring the lower control arm level. Playing around with the excell model, I can't get a possitive camber till 3in of extension with the C5/6 spindles mounted conventionally. I'm afraid it looks like there isn't a way to mount any of the spindles I have the measurements on and get a useable ride height out with the 2in body drop in relation to the spindles needed for a flat lower control arm.
exwestracer
12-02-2011, 07:52 PM
Level lower is a good starting point, but it's not cast in stone... If the C5 solves your other problems, just raise the suspension 2" from level. That long lower arm isn't going to move the tire much, and it will go negative camber faster from ride height than a level arm.
CTX-SLPR
12-02-2011, 08:23 PM
If I understand what you are saying, It's not a bad thing to have the lower arm going uphill from the spindle to the body? That's the situation I'd be in with a trying to optimize the right height and use the C5 upright. With 6in ground clearance, I'd end up with the inner points 2.75in above the ball joints using the C5 upright.
Edit: Ooops, left the 17in F-body upright in the excel model but that might be a better candidate. Playing around with stuff still since at 6in ground clearance, the C5 upright is still too short with the inverted ball joint, assuming 2.5in of height gain for flipping it over things look better.
Anything bad about the 4th Gen F-body upright?
12-03-2011, 12:26 AM
Anything bad about the 4th Gen F-body upright?...just that the upper arm will be in your fender...very high up.
exwestracer
12-03-2011, 06:23 AM
I'm with Quick on the F-body spindle... Those cars were designed to carry the upper arm load much higher in the chassis. You're getting a long way above the Riv frame with the upper arm mounts, and you'll have to build a support structure for them.
How long of a lower arm are you planning on using? I'm sure you're aware that you can calculate the angle of the lower arm and the side movement of the ball joint for the 2.75" height difference. I'd be interested to see what the camber curve does. Actually sounds about like stock ride height as far as the lower arm is concerned.
CTX-SLPR
12-03-2011, 07:08 PM
The lower arm I've speced out is 18.75in long to put the upright in possition to fit an 18x8in wheel with the same scrub radius as the C5 without affecting the track width since there is not much room for a wide tire upfront. This coresponds to an 11.2in upper arm (centerline to balljoint) to dial in -1.11º of static camber with 1/8in of shims on the A-arms. Factors I use to calculate this include, spindle height, upper control arm length, lower control arm length, pivot point offset between upper and lower in both vertical and horizontal, spindle horizontal offset between ball joints, and the ride height of the ball joint in relation to the control arm pivot point. I then calculate camber based on the difference between the horizontal possisions of the ball joints at different amounts of ball joint vertical movement from ride height. I've not added caster calculations yet.
With an assumed 2in higher upper ball joint position on the C5/6 upright from inverting it I get ~1.06º of camber loss in 1in of compression from ride height. Was thinking machining a top hat style steel insert for the spindle with a heavy washer and retaining clip to use a through bolt style ball joint on the top. Since this is largely a street car, I'd like to stay away from rod end type suspension components. For the brake reaction rod I might have to though since a rubber bushing will allow that link to move all over the place. Just thought about using a ball joint in that location with a tierod type adjuster for changing the length of the rod to affect more or less caster. I would expect camber to be unaffected since the attach point to the frame is at the same height as the LCA mount.
exwestracer
12-04-2011, 07:17 AM
Well, that all sounds VERY good to me...
By camber loss, do you mean camber is going negative (top of tire in)?
As far as using Heims goes, you are pretty limited on choices at the upper ball joint and the strut (brake) rod mount. If you flip the upper ball joint, you lose the taper, so that kind of rules out a ball joint on top without putting some sort of big sleeve in the hole. A ball joint should work for the strut rod mount, but you won't have much "tie rod" adjustment, as the threads aren't very long. Your only other options are Johnny joint (plastic lined but HUGE), rubber (don't want to go there), or Heim...
52047
I've been wondering about a weld in Johnny joint (uniball) mounted sideways, and using the hole where the pivot bolt would normally go to mount the strut rod. It would be pulling axially, though, and I've never read up on the axial load ratings on those.
CTX-SLPR
12-04-2011, 01:16 PM
52047
I've been wondering about a weld in Johnny joint (uniball) mounted sideways, and using the hole where the pivot bolt would normally go to mount the strut rod. It would be pulling axially, though, and I've never read up on the axial load ratings on those.Yes, the camber gets more negative as the suspension compresses
I actually was thinking big steel insert with something like a 1/4in lip on one side (probably top) with a washer with similar width on the otherside retained by either a nut or a clip in a retaining groove. Since the hole is so large in comparison to the taper and threaded section of the ball joint I could probably get away with a counter bored section for the castle nut to still leave enough height for the washer and it's retension mechanism. I'll draw it up this evening.
Your idea on the Uniball/Johnny joint is exactly what I was thinking with the ball joint since they are designed for loading in compression and tension. Just thread an adjuster like you use on a tierod end between it and the rod attached to the LCA. I agree that the threads wouldn't be very long but with proper engineering the small adjustment should be all that's needed vs. an "adjust to fit".
Tell me more about the '63 Riv you're looking at. I can give you pointers on where to check for trouble and there is some unique stuff to a '63 over the 64 and 65.
exwestracer
12-04-2011, 03:00 PM
So far, I have one crappy cell phone pic, and no returned messages... I'm just looking at it for a solid body. The chassis and suspension would be a "clean sheet" build.
CTX-SLPR
12-04-2011, 03:06 PM
So far, I have one crappy cell phone pic, and no returned messages... I'm just looking at it for a solid body. The chassis and suspension would be a "clean sheet" build.Check the cross bracing on the floor pans and under the trunk, they tend to collect debris at the ends and rot out. Also check around the rear window and the battery tray for rust.
exwestracer
12-04-2011, 03:07 PM
Thanks, I'll be sure to look closely if I ever get that far...
CTX-SLPR
12-12-2011, 08:21 PM
Sorry, been sick and busy. Lurked a bit but time to say stuff again.
Been thinking over the ride height and suspension bits and realized that my current set up is actually riding very high in the suspension due to the lighter V6 in the nose. I'm probably 1in from the bumpstops, granted they are huge 1.5-2in tall rubber bump stops. This means going up by 0.75in would practically put me on the current bumpstops. Now with the dramatically rearranged suspension pieces I won't be close to crashing the upper control arm into the frame since it's angled the other way but it did make me think through this.
The next bit was the design problem of how to mount the front coil overs onto the lower arm. Since the lower arm is a straight piece and probably tubular, how do you mount a coil over that drops down on the center of the tubular arm? Is the best way to put a saddle on top of the arm and just run something short enough to fit in the space? Does the arm need to be sectioned and a 'U'-channel welded in to pick up the lower bolts? I'm probably going to go with Air Ride Shockwaves on this since I like the ability to raise the ride height to clear objects or steep inclines. I will however be specing them out so that the three different settings end up with a usable track height/inflation combo on the bottom, potentially a compromise inflation for the street ride height, and the top one will be all up.
Thanks for following the ramblings,
exwestracer
12-13-2011, 05:44 AM
How about a pic of the stock control arm? I usually try to let the part tell me what it wants done to it...
CTX-SLPR
12-13-2011, 07:28 AM
here's the shop manual diagram for the front suspension:
https://static1.pt-content.com/images/pt/2011/12/RivSuspensionDiagramSjpgsaXeiHWznTt67Csq-1.jpg
Here's about the best thread I can find with pictures of the suspension: http://www.jalopyjournal.com/forum/showthread.php?t=293538&highlight=riviera+start
Remember I'm going to be making these arms more than a few inches longer to push the kingpin axis out to match C5 scrub radius specs.
exwestracer
12-13-2011, 10:38 AM
CTX,
I tried to import a couple of those pics form the HAMB link, but they wouldn't work. Seeing as how the outer end is already boxed, I'd give some thought to making a bracket to use the existing brake reaction rod bolts to mount the bottom of the coilover, possibly adding a 3rd bolt further out through one of the "ears", as those 2 are placed. That will move the spring path out closer to the ball joint, and would allow you more shock travel and to run a softer spring rate than if the shock were closer in.
CTX-SLPR
12-13-2011, 06:50 PM
Ray,
If I understand you, you want to push the lower coil over attach point out to the brake reaction rod attachment for more travel. Since I do plan on using a shockwave, I'm not sure how I'd push it out without the bag hitting the spring pocket on the top? I'm not really interested in cutting the frame up for that kind of clearance. Also the arms will be totally fabricated pieces since the lower arm will be 3.75in longer than stock and the uppers 1.625in longer. I was thinking that tubular was going to be the easiest way of making the lower arms but would have to mount the shockwave on the top of it in addition to the strut rod pickup points. The anti-roll bar could be mounted to the side or over the top I would think.
exwestracer
12-14-2011, 03:42 AM
Oops, missed the Shockwave part for some reason...
Keep in mind, since your arms will be getting longer outboard of the spring, you are increasing the stress on the arm itself. I'd urge you to have another look at cutting that top spring bucket... The further out you can get that lower shock mount, the less bulk you have to build into the arm.
Having said all that, my opinion is that the stock design (hat channel) is about the best there is for handling the load if you keep the spring near the center of the arm. I'd probably taper the beam height from the ends in to the shock mounting location. Something like this maybe...
52563
CTX-SLPR
12-14-2011, 09:53 PM
On cutting the spring pocket... many of the same limitations that restrict me to the stock suspension mounts on the frame side drive my reasoning for not trimming the spring pocket. I am trying to do the best I can with the starting point GM has given me, I see the cutting of the spring pocket as a slippery slope to a whole new front stub. While I reallize this would probably be 20x better, it's not in my time or monetary budget.
I have throught about using conventional coilovers (the steel spring ones) instead of the shockwaves as both a cost savings and as a method of angling the attach point out farther due to the smaller diameter of the unit. Putting a plate in the top of the spring pocket and drilling some holes for locating bolts to keep it from rotating around the central shock bolt point, which would be the main load bearing point, and offset the upper mount as far inboard as possible and the lower mounting point as far outboard as possible to keep things in clearance in full bump.
I think the alternative is to use as long of a shockwave as possible in the stock location and drop it through the arm and gusset around U section where it's missing the upper boxing plate.
exwestracer
12-15-2011, 03:40 AM
It's really the distance from the ball joint that is the critical factor, IMO. I'd recommend doing whatever you "can" to get it further out on the lower arm. Personally I think coils are a better choice...
CTX-SLPR
12-29-2011, 07:26 PM
Again, mostly lurking and thinking. It looks like I'll have to cut the frame for air ride, though the Ridetech instructions only show the need to trim the lip off. If I have to do any cutting at all I might as well do something more productive with it. Now the frame is fully boxed pretty much except for where the bumper brackets bolt on at each end. However it's an X-frame so I have nothing under the door sills. That might be an improvement for a later date however. If I cut the majority of the outer wall of the spring pocket off, will I adversely effect the frame strength? I'll have to get some measurements from Ridetech to see if I can still fit a shockwave in there but I might be limited to steel coils and have to figure out a ride height that will work on the street or maybe enough shock travel to raise the ride height for the street.
How hard is it to build an upright/spindle? It would be nice if I could design out the "drop" in the C5/6 upright so I could run the suspension with flat lower arms while keeping the overall height. I have a mill that I'm learning to use and a MIG so fabrication is not beyond my ability though I'd probably leave final welding to a pro since I'm not that confident in my skills.
exwestracer
12-30-2011, 05:49 AM
http://www.colemanracing.com/Spindle-Assembly-Modular-Wide-5-And-5-x-5--P4710.aspx
These will pretty much do what ever you need them to. You set the ride height by the relative location of the ball joints to the snout. (You may have to build your own ball joint mounts to get the exact drop you are looking for, but it's a great start...)
CTX-SLPR
12-31-2011, 11:28 AM
These will pretty much do what ever you need them to. You set the ride height by the relative location of the ball joints to the snout. (You may have to build your own ball joint mounts to get the exact drop you are looking for, but it's a great start...) Good stuff though I have no experience with this stuff so what are the bearings associated with the 5x5in hubs and am I restriced to the brake parts from Coleman as well?
exwestracer
12-31-2011, 12:14 PM
Probably Chevy Impala, but I'd ask. They don't use anything too oddball. (the ones pictured are Wide 5 3/4 ton Ford pickup snouts) Everything bolts on to that spindle, so you can adapt whatever brake system you want to use. Coleman has brackets for GM and common aftermarket calipers, but the rotors are likely smaller than you'd want on a PT car. They build everything to fit in a 15" wheel.
CTX-SLPR
12-31-2011, 05:35 PM
Probably Chevy Impala, but I'd ask. They don't use anything too oddball. (the ones pictured are Wide 5 3/4 ton Ford pickup snouts) Everything bolts on to that spindle, so you can adapt whatever brake system you want to use. Coleman has brackets for GM and common aftermarket calipers, but the rotors are likely smaller than you'd want on a PT car. They build everything to fit in a 15" wheel.Looks like they use the same bearings as stock on the Riviera according to this post: http://www.lateral-g.net/forums/showpost.php4?p=33466&postcount=44. A BR5/3 combo vs. the later BR6/3 combo found on the 77+ B-body. That works well for not having to change over my rear axle bolt pattern and I already have a set of '68 Wildcat drum brake hubs that I planned on using to mount discs before I started on the idea of redesigning the front suspension. I think you just gave me a gold mine Ray!
Now do you think cutting the entire wall out of the spring pocket will hurt the frame rigidity?
Anything ever happen on that '63 you were trying to look at?
exwestracer
01-01-2012, 05:22 AM
If the Riv is anything like every other GM front clip I've ever worked on, no. What we typically do is add in a doubling plate around the inside of the old spring pocket. That area should be shaped like a truncated cone, with the top being the actual upper perch. If you can form a piece of 12ga steel to fit up in there and weld it around the bottom and top, it will likely be stronger than it was before.
Never heard back from the guy who supposedly had a line on the 2 Rivs....oh well.
CTX-SLPR
06-26-2012, 06:14 PM
So I've been dinking around with other threads largely because I've been questioning about specific pieces of suspension design. I've decided to come back to my original thread with specifics on how to design the suspension vs. cluttering up thread about general parameters.
Here's what I've decided to work with and have even started buying parts for.
Frame side is unmodified '64 Riviera
Upright side are C5/6 uprights, just reversed side to side since the car is rear steer. I'll probably be making my own steering arms and/or going rod end style depending on which way I need move the pickup point
Sticking to standard height ball joints since the top isn't really an adjustable point with the C5/6 upright and the lower doesn't do much more than chew up ground clearance for the LCA's
Upper control arm will be modeled after the SPC unit by starting with Riviera bushings and cross shaft and welding on tabs for 5/8in swaged steel rods out to a plate that has the tapered hole for the UBJ
Lower control arms will be box section ending in a tapered piece with a weld on screw in LBJ cup if the K727 will work with the C5/6 upright
Wheels will be Land Rover 18x8 or 19x8 since they have almost the same offset as the C5/6 wheels do without the 9.5in width. They also have 5x120mm bolt pattern with 14mm studs that hold the wheels on with a shank and washer type setup. I'm thinking I'll get a machine shop to redrill the C5/6 hubs for the Land Rover studs and move the pattern in to 120mm vs. the 120.67mm of the C5/6.
Side note, I really like doing the modeling for this stuff. Doing the modeling in excel is a bit crude but I've not gotten the hang of the open source version of my prefered programing language (IDL, open source GDL). Anyway back to what I've modeled it as doing.
So far I'm modeled camber curve, caster curve and anti-dive. I'm sure I'll find more things to model along the way (like instant center) but since I'm sticking with GM's frame side points I'm not exactly flexible on a lot of the parameters.
UCA Length: 12.05in
LCA Length: 19.39in
Static Camber: -0.114º
Camber Gain: 0.42+0.13º/in of compression
Static Caster: 7.38º
Caster Gain: 0.62º/in of compression, 1.25º in extension
Anti-dive: Estimated 51% with a 24in high CG and 67% front brake effectiveness, lower if the CG is higher (remember this is an X-frame car so it's essentially channeled over the frame)
Any of this look concerning? I can't really change the anti dive or change the caster gain since they are locked into the frame side of the suspension.
I plan on trying to reuse the stock springs, shocks, and sway bar for a bit to save money. I'll have to shim the bottom spring mounts since I get a 3in drop from the C5/6 uprights due to the spindle to LBJ height differences and I want 1in of that back. I do plan on going to a set of coil overs and a splined swaybar when I've saved up enough and converted the rear axle.
Thoughts?
