View Full Version : Strange C-clip Elim kit
badazz81z28
11-26-2011, 05:52 PM
Has anyone used this kit? http://www.summitracing.com/parts/STR-A1033/
Can it be used with drum and disc backing plates?
badazz81z28
11-26-2011, 06:15 PM
Specifically WS6 backing plates, I have rear disc from a 1979 TransAm.
Skip Fix
11-29-2011, 12:58 PM
I know a local guy used a regular C clip eliminator with them and the bearing block on that set doesn't look much different. Got a set just haven't used them yet.
badazz81z28
11-29-2011, 03:32 PM
Confirmed with Strange...No go for disc brakes. Too bad :(
Skip Fix
11-29-2011, 10:21 PM
The "regular" C clip eliminators also say no go, but they do. So they may still work. I'll look under the car tomorrow and see how much clearance with the TA discs. I really can't see why they wouldn't as the bearing housing is small enough to fit inside the rotor, and it should be tucked up in there pretty good.
Skip Fix
11-30-2011, 06:46 PM
The C clip eliminator housing fits easily within the rotor. Hard to tell fitment with the axles installed in the rear.
andrewb70
12-01-2011, 11:46 AM
I don't know why Strange says that. I used their kit on my old 12 bolt with a Baer disk brake kit and had no issue. I don't know if it will work with your brakes.
badazz81z28
12-03-2011, 01:01 PM
Do you have the new street version installed? Is that what stranges concern is? Fitting inside the rotor?
Skip Fix
12-03-2011, 07:25 PM
I don't have it(C clip elim) installed just new in a box and an extra rotor. Not enough room to slid it past the set up rear in the car.
BuzzKillian
12-03-2011, 08:13 PM
I have a C clip eliminated 12 bolt, that came with the car. I was talking to the guy at the Willwood boot at Goodguys in Columbus. He said the issue with that kit is running an interal parking brake. SO... You can run discs. If you are running an automatic, I would think "No Problem". I don't like the idea of not having a parking brake with a manual. IMO
badazz81z28
12-04-2011, 07:55 AM
Why havent you installed it? As for the parking brake...Makes sense. Good thing the TA disc parking mech is on on the caliper
badazz81z28
12-04-2011, 07:59 AM
Why have you not installed it? Looking to sell it?
Skip Fix
12-04-2011, 09:42 AM
Nope just for another of the projects in a long list:) Got it for the 78 when I upgrade it to 30 splines. Still debating using it or weld in ends. Don't have to cut the rear disc bracket for larger bearings if its on the outside part of the axle with this. I also can;t see how it is any less sturdy than just a regular bolt in axle either.
badazz81z28
12-04-2011, 04:51 PM
Nope just for another of the projects in a long list:) Got it for the 78 when I upgrade it to 30 splines. Still debating using it or weld in ends. Don't have to cut the rear disc bracket for larger bearings if its on the outside part of the axle with this. I also can;t see how it is any less sturdy than just a regular bolt in axle either.Where did you buy your kit? Is there someone cheaper than Summit Racing?
Skip Fix
12-13-2011, 12:20 PM
I think I got it from Strange directly.
