View Full Version : Unsolved Mystery...Pinion Nut size
badazz81z28
11-25-2011, 04:07 PM
Ok, I'm baffled! I bought a new pinion yoke and it came with a new nut. The nut that came off the pinion was 7/8" and was removed with a 1-1/4" socket.
I went to install the new nut and its the right thread but too big for the 1-1/4" socket. I went up to 1-5/16" and there was slop. Tried 32mm and too small....tired 33mm and again some slop.
What size is this thing???? I'm so confused!
badazz81z28
11-25-2011, 05:28 PM
My dorman replacement nut is slightly too big for 1-1/4" too...I don't get it
This nut measures at 1.285"...I need a 32.5mm socket???
https://static1.pt-content.com/images/pt/2011/11/nut2-1.jpg
https://static1.pt-content.com/images/pt/2011/11/nut-1.jpg
big gear head
11-26-2011, 05:17 AM
I'm assuming that this is for the 8.5 10 bolt. Go to GM and get a new nut from them. They still produce these rear ends for the 1500 trucks, so the nuts are still available from them. The cheaper installation kits and auto parts stores use a cheaper nut, probably from China. If you ever have to get an installation kit get a good one from DTS, Tom's Differentials or Randy's Ring & Pinion. Don't use Ratech stuff.
badazz81z28
11-26-2011, 08:47 AM
Thanks, do you know the part #? I'm assuming it will be for a 8.6 10 bolt?
badazz81z28
11-26-2011, 12:25 PM
I bought one from DTS, probably going to cancel my order and buy from Drivetrain america...
Whats up with DTS $5.00 handing charge?!?!? A $3.00 nut turned into $20!
andrewb70
12-01-2011, 11:48 AM
That's why you should have just gone down to your local Chevy store...
badazz81z28
12-01-2011, 04:41 PM
Yeah right.....GM dealer wanted $28!
JEFFTATE
12-02-2011, 05:48 AM
GM nut is pn-88891763 . ( $5.09 retail ) .
Just drive by a dealer and pick one up ..
The original 1979 pn was 1260823 ,
that change to pn - 9783762 ,
which changed to pn- 88891763
John Wright
12-02-2011, 07:09 AM
51964
..or how about this?
JEFFTATE
12-02-2011, 08:44 AM
GM Parts Direct charges an order processing fee of around ( $9 ?? ) , plus a lot for freight ..
Plus , on this item , their minimum buy is a quantity of 5 ..
John Wright
12-02-2011, 09:59 AM
Well, that is good to know....dang shame they turn a $2 part into something expensive.
andrewb70
12-02-2011, 10:24 AM
I am sorry, some parts just need to be sourced locally. If one dealer doesn't give you a good price, call around. I fail to see how any dealer can possibly ask $20 for a part that has a list price of just over 5 bucks. Either the part was not looked up properly, or the dealer was quoting a price for 5 nuts.
John Wright
12-02-2011, 11:02 AM
have a Northern Tool store near you?
$14 socket and use the nut that you have?
http://www.northerntool.com/shop/tools/product_200391536_200391536
Mr.VENGEANCE
12-02-2011, 05:12 PM
its a mystery
https://static1.pt-content.com/images/pt/2011/12/tumblr_lr89b8Zl3g1qgi5aqo1_400-1.png
